After World War II, most U.S
The 1949 Pontiac Streamliner Eight DeLuxe station wagon was an anomaly in the postwar auto market. After World War II, most U.S. 1942s and proceeded to sell all the cars they could produce. Problem was, they couldn't build nearly enough because they were hampered by steel shortages and strikes. It wasn't necessary, Visit site but apparently Pontiac management felt some loyalty to the annual model change, so the 1946 and 1947 models featured recognizably different front ends. So did the 1948, which sported a "floating" bar at the top of the grille that doubled as a Pontiac nameplate. The overall effect was to make the front end look wider and more massive. Meanwhile, Chief Pontiac's silhouette moved up from the grille surround to the bottom of the Silver Streaks, which now numbered three, rather than five. The Chief received additional massaging as he now rode atop the hood with a red translucent plastic face.
In back, the rectangular taillights were traded for round lamps (wagons had different round units), which would be used in one form or another for a decade. On the fenders, the triple "speedlines" were replaced by a single front fender chrome spear on the DeLuxe (but not standard) models. Of the two series, the Torpedo listed semi-notchback sedans and coupes, plus a convertible. The Streamliner line was composed of fastback sedans. All models in both series could be ordered as a Six or Eight, and most in standard or DeLuxe form. With all these permutations, there were 30 models listed. For some unexplainable reason, the station wagon was placed in the Streamliner series -- though it was hardly a fastback. And it came in four models: Streamliner Six and Eight, regular and DeLuxe. The wagon seen here is the Streamliner Eight DeLuxe; at $2,490 it was the costliest 1948 Pontiac. The straight-eight engine displaced the same 248.9 cubic inches it had since 1937, though horsepower had crept up from 100 to 103 in 1947, and to 104 for 1948. For those intent on more go, a high compression (7.5:1) head boosted output to 106 horsepower. The big news for 1948, however, was the arrival of GM's four-speed Hydra-Matic. It was a hit: of the 235,419 Pontiacs built that year -- 171,946 were so equipped. The wagon, "a great comparative value," Pontiac boasted, was to be the last traditional woody the division would build. In 1949, a "partial" woody bowed, Prime Boosts Male Enhancement Prime Boosts Male Enhancement with the wood mainly around the tailgate; an all-steel wagon took over at mid-year.
Compound exercises like the squat-curl-press target different muscle groups to build endurance, increase strength, and improve stability. In fact, some research suggests that compound exercises that involve functional movement patterns are one of the most effective ways to improve muscular strength and burn fat, particularly among overweight adults. Add more power to your resistance-training routine with these quick compound moves using dumbbells to get a dynamic full-body workout at home. The squat with an overhead press is a great full-body compound workout using both the upper and lower body at the same time. These moves function in tandem to allow a natural transition from a squat to an overhead press. Stand with feet a little wider than hip-distance apart. Rest light to medium weights on your shoulders with elbows bent and palms facing each other. Lower into a squat. Keep your torso upright by lifting your chest (imagine showing someone the logo on the front of your shirt while at the bottom of your squat).
Make sure you are sending the hips back to protect your knees. Push into your heels to stand as you press the weights overhead. Lower the weights to your shoulders, and repeat 1-3 sets of 8-16 reps. Compound exercises are quick, www.PrimeBoosts.com full-body moves you can do anytime, anywhere-especially if you're short on time. The squat, curl, and press is a well-known compound workout that targets the legs, core, arms, and shoulders in one dynamic movement. This is an advanced exercise that requires physical strength and stability. Start with lighter weights as you practice this movement pattern before trying heavier weights. Stand with your feet wider than your hips and hold light to medium weights with your arms by your sides and palms facing each other. Squat down and touch the weights to the floor and turn your palms to face forward. Keep your back straight and your abs engaged. Curl the weights up in a biceps curl and hold.
- 이전글Commercial LED LIGHTING iS oUR FOCUS. wE CARRY the Newest Know-how Quality Products 25.08.12
- 다음글They Compared CPA Earnings To Those Made With Poker Gaming Software. It is Sad 25.08.12
