Bohemian Crochet Pillow Pattern
Why spend that much when you can grab 750 yds of any size 4 (medium) yarn on sale and make one yourself! The best part of this modern boho pillow is how incredibly easy it is to crochet. The front of this bohemian crochet pillow cover is made with only two stitches - single crochet and a Puff Stitch, which in this pattern is a half double crochet three together or hdc3tog (there’s a video tutorial below on how to do this stitch). The back of the pillow is made by alternating single and double crochet stitches, which works up really quickly and creates a lovely modern textured stitch. Affiliate Disclosure: This post may contain affiliate links meaning I may receive a commission for purchases made through links in this post at no extra cost to you. As an Amazon Associate, I earn from qualifying purchases. Purchase the printer-friendly, ad-free PDF of this pattern that you can instantly download!
It includes everything from this free pattern but you can easily save, print and access it anytime! You can also purchase it on Etsy or Ravelry. The pattern creates a removable pillow cover that is approx. Yarn: Approx. 750 yds of any size 4 (medium), 100% acrylic yarn. I used Impeccable Solid by Loops and Threads in the color "Green Lagoon." This yarn is size 4 (medium) and 100% acrylic. A skein is 285 yds / 260 m and 4.5 oz / 127.5 g. I used 3 skeins (2 and 3/4 to be exact). Crochet Hook Sizes: F/5 (3.75 mm) for the front and H/8 (5.00 mm) for the back. Or sizes needed to obtain gauge. Optional: 3 x 25mm buttons for Get Derila Official the back, thread and sewing needle. The size of your pillow insert depends on how tightly you crochet and Derila for Better Sleep how stretchy your yarn is. I found I needed a thick 18" x 18" pillow insert (with a depth of 6"). Mine also fit over a 20" x 20" pillow insert.
This pattern is written for right-handed crochet using standard US terminology. If you’re more familiar with UK terms, here’s my US to UK Conversion Chart. 12 sts and 15 rows (following the pattern for Piece A (the front) and measured on the wrong side). 12 sts and 11 rows (following the pattern for Piece B or C (the back)). Always work in the first stitch, the stitch attached to the chain. Chains never count as stitches. A Puff stitch in this pattern is an hdc3tog (half double crochet three together) in the same stitch. Here’s how to make a Puff: Yarn over. Insert hook into the designated stitch. Yarn over and pull through a loop (3 loops on hook). Yarn over and insert hook into the same stitch. Yarn over and pull through a loop (5 loops on hook). Yarn over and insert hook into the same stitch. Yarn over and pull through a loop (7 loops on hook).
Yarn over and pull yarn through all 7 loops. This Bohemian Pillow pattern is included in the Home Decor Bundle! For a limited time, save 72% and Get Derila Official EIGHT beautiful crochet patterns for your home for only $9.97! That’s like getting five PDF printable patterns for free! Get the Home Decor Bundle Today! Please note: This pattern and all images associated with this pattern cannot be copied, shared, altered or sold on your own. This pattern is also available as a PDF, which includes everything listed here but as a printer-friendly, ad-free PDF that you can instantly download, save, print, make notes on and keep forever. You can also purchase it on Etsy or Ravelry. Get ALL my PDF Patterns! Each row has 55 stitches. Your work may curl or look misshaped. This will be corrected once the pillow is assembled. For Row 1 (only) work into the back ridge loops.
- 이전글정품여성흥분제【E46.top】비아그라 구입 구매가능 25.08.12
- 다음글Why We Enjoy Windows And Doors (And You Should Also!) 25.08.12
