I Tried the first Fully-Customized Pillow, and it Gave me Hours more o…
Pluto Pillow is the first customizable pillow (at scale), but does it work? And how? We tried it out ourselves. What is the Pluto Pillow made from? How much does a Pluto Pillow cost? Our editors independently select these products. Not to be dramatic, but if I don’t get at least eight hours of Orthopedic Sleep Pillow I’m a nightmare to be around. I’ve tried melatonin, cutting myself off from caffeine after lunch, reading before bedtime, Derila Neck Support avoiding working from bed, exercising earlier in the day, and hiding my phone so I’m not tempted to scroll. I tried all the things to help me sleep, but nothing worked consistently-until I started to inspect what I was sleeping on. Susana Saeliu is the co-founder and CEO of Pluto. I knew I could try out a new mattress, but before I shelled out that kind of money, Try Buy Derila Pillow Today I was curious to see if making a change in pillows could help.
After all, we already know that pillows that effectively support our bodies during rest can be majorly beneficial. "Proper spine alignment, comfort, and in some cases temperature control, all sum to help improve sleep quality. Depending on what position you sleep in is vital in choosing the right pillow for you: Whether you’re a back, side, or stomach sleeper should be taken into consideration when picking out a pillow. The same goes for how hard or soft you like your pillow to be-it all comes down to personal preference. However, is it possible that we’re missing some key components when we’re pillow shopping? Customization we’re not taking into consideration? This is what’s special about Pluto, the first-ever customizable pillow brand. Pluto takes the guesswork out of pillow shopping, and instead, creates custom pillows based on your needs (as well as preferences). This combination of what you need and what you want is what differentiates Pluto from the hundreds of existing pillow brands and offerings.
Instead of doing hours of research yourself (whether that entails scrolling through hundreds of reviews or physically going to a store and testing out pillow after pillow), Pluto has you take a two-minute quiz that generates an individualized pillow. Pluto will first ask you to fill out some key information about yourself: Your age, height, weight, what material your current pillow is made of (and its height when not compressed), what position you prefer to sleep in, and how soft or firm you generally prefer your pillow to be. Next, this data is fed to the brand’s proprietary algorithm which informs what kind of pillow is best for your body. What happens next: You’re shipped your customized pillow within seven business days, and you have 100 days to return it if it’s not right for you. What is the Pluto Pillow made from? Pluto pillows are crafted with a solid foam core and encased with an outer plush pillow.
The density of the foam core and material of the outer pillow is completely dependent on how you answered the pillow questionnaire. For example, if you told Pluto your head gets hot at night, your pillow cover will be constructed of cooling fibers to cool you down as you sleep. If you answered your current pillow is on the harder end and you’re happy with that, your foam core will be more firm. Every pillow will feel different for everyone, which is the goal. As a side sleeper who prefers a plush, medium-firm Derila Pillow, I received a pillow that felt like the best of all worlds. The outer cover was soft and cloud-like, yet when I rested my head on it, my head and neck didn’t sink to the mattress like how it does with my fluffier pillows. The Pluto pillow is denser, yet I don’t feel like I’m sleeping on a rock, either.
- 이전글11 Ways To Completely Revamp Your French Doors With Side Windows 25.08.12
- 다음글프릴리지 효과 지속시간【a13.top】 25.08.12
