How Microtears help you to Build Muscle Mass > 자유게시판
작성자 Brenda Collingr…
댓글 0건 조회 8회 작성일 25-08-10 12:32
healthy-couple-jogging-in-nature.jpg?s=612x612&w=0&k=20&c=JmpZayrbSuJXqu1HsazoYUyPm87b5xNU1n8rbQn5F1M=It seems counterintuitive to purposely injure yourself during a workout, but that, in essence, is what you must do to build muscle mass. That doesn’t mean you should reach for the heaviest barbell at the gym and attempt 100 repetitions daily, orthopedic surgeon Michael Karns, MD says. Instead, it’s important to understand how these tiny injuries to muscle fibers, called microtears, help athletes build mass. "Microtears are what happen after a muscle gets physically worked," Dr. Karns says. "Once these occur, the body sends good nutrition and good blood to the area to heal. You have to break muscle down to build it back up stronger," he says. The process of repairing and Visit site adapting to microtears to increase muscle mass is called hypertrophy. Seek guidance: If you’re new to strength training, ask a strength coach, athletic trainer or gym teacher to model safe techniques and monitor your form. Going it alone may cause you to develop bad habits, which can lead to injuries that set back your efforts.
Remember weightlifting isn’t a standalone activity: Skipping the warmup or cooldown may sideline you. Begin your workout with a few minutes of cardio to increase your heart rate and get blood flowing to the muscles. After strength training, perform static stretches to prevent cramping. Go heavy: Achieving hypertrophy means lifting heavier weights and performing fewer repetitions. "Lifting heavy weight results in the microtears needed to build muscle mass," Dr. Karns says. Know your limits: See details Pushing yourself to lift the heaviest weight you can manage while still maintaining proper technique is the goal. Forcing yourself to do biceps curls with weights so heavy that your back is arching is counterproductive and dangerous. Take a break: Rest is necessary to repair muscle fibers and build muscle mass. Ensuring adequate rest between workouts is critical to your body’s muscle repair process. "If you’ve overloaded a muscle group with weights, you have to give it time to rebuild between workouts," Dr. Karns says. Fill your plate and water bottle: Exercise alone will not increase muscle mass. Maintain a balanced diet that includes lean protein. Drink plenty of water before, during and after your workout. Get your Zzzs: Lack of sleep can lead to improper technique, decreased motivation or an inability to lift your usual weight load. Keep a journal: "An athlete can track his sleep, food and hydration via a journal," Dr. Karns says. "Have the athlete write down how much they are drinking a day as well as what food they are putting into their body.
If you’re serious about weightlifting, you’ve probably heard the term "progressive overload" before. But what exactly is it? Progressive overload is the steady increase of stress placed on your muscles during exercise over time. You can achieve this through various methods, including increasing weight, reps, or sets. Mind you; this method is not for the faint of heart. As the name suggests, it demands more and more from your muscles. The line that sits between what is within the limit and beyond the limit is extended. Curious? Keep reading to find out more about it. What is Progressive Overload? Progressive overload is a fundamental principle in weightlifting that involves increasing the demands on your muscles over time. This means you need to lift heavier weights, perform Learn more reps, or do more sets to continue progressing. The concept of progressive overload is based on the idea that you need to challenge your body continually to see continued progress and improvements in strength and muscle growth.
When you lift weights, your muscles experience micro-tears, which heal and grow stronger during rest periods. Progressive overload ensures that your muscles are continually challenged, which means they will continue to grow and adapt to the increasing demands you place on them. By gradually increasing the demands on your muscles, you are forcing them to adapt. As a result, they will grow stronger. This is why simply doing the same workout repeatedly without any changes will lead to a plateau. Why is Progressive Overload Important? Progressive overload is essential for building muscle and strength. Without it, your muscles will eventually adapt to your current workout routine, and you will stop seeing results. By gradually increasing the demands on your muscles, you can continue to progress and achieve your fitness goals. To effectively implement progressive overload, you need to track your progress and make changes to adjust to your workout routine regularly.
This could involve increasing your weight, adding more reps or sets, or changing your exercises to target different muscle groups. What are the types of progressive overload? Here, we divide them into weight, volume, and intensity progressions. One type of progressive overload is weight progression. This involves gradually increasing the amount of weight you lift over time. For example, if you are doing a bench press, you start with one hundred pounds and then gradually increase the weight to 110 pounds, 120 pounds, and so on. Increasing the weight forces your muscles to adapt to the new stress, which leads to gains in strength and muscle mass. Another type of progressive overload is volume progression. This involves gradually increasing the total amount of work you do over time. You can do this by increasing the number of sets, reps, or exercises you do in a given workout. For example, with bicep curls, you might start with three sets of ten reps and then gradually increase to four sets of twelve reps, five sets of fifteen reps, and so on.
