Guide To Item Upgrade: The Intermediate Guide In Item Upgrade > 자유게시판
작성자 Aurora
댓글 0건 조회 10회 작성일 25-04-05 00:13
Guild Wars 2 Item Upgrade
item upgrades upgrade items, commonly known as "upping," improves an item's stats. Each upgrade increment provides a linear increase in any stat.
Players can recycle up to six items at a time to gain a level gauge for each of the item's upgraded components. The cost of recycling an item scales according to its rarity and.
Upgrade components
An upgrade for an item in Guild Wars 2 is a process that can increase the stats of your weapon and armor. This can be done through a number of means that include using upgrade components and upgrading an item's mark level or rarity. Additionally, many items can be reforged to boost their stats even more.
Upgradeable items are available all over the game, both within the world and as rewards for missions. They can also be crafted by players. The most common method of upgrading equipment is by making use of upgrade components, which are items that can be slotted into equipment. The majority of equipment comes with slots for upgrading and some require a certain level of upgrade. Some upgrade components give specific bonuses while others provide an overall bonus.
There are many types of upgrade elements available in the game. These include universal upgrades, inscriptions, and jewels. Universal upgrades, such as gems and enchantments, are able to be put in any equipment type and offer less bonuses than those that are equipment-type specific. Glyphs are only available on gathering tools. They provide a variety bonuses, ranging from boosting the speed at which an item gathers to providing extra crafting material.
To upgrade an item, click it in your inventory, then open the Upgrade window. The window will show a preview on the right side of the screen, showing what the expected stats will be after the upgrade, as well as any materials or components required. The Upgrade button at the bottom will be labeled as Blocked if you do not have enough of either.
The amount of upgrade components needed for a particular item can be seen in the upper-right corner of the window for upgrading. The price of an upgrade increases with the level and rarity of the item increases. However, you can reduce the cost of upgrades by purchasing them from a vendor, or trading them with other players.
Most weapons can be improved with a prefix, like a rune or an insignia. Some can be upgraded by adding an suffix. These upgrades include an adjective in the item's name like "Radiant" or "Minor Vigor".
Glyphs
Glyphs can be used to convey visual information. They move to catch the viewer's attention and spur interest in the brain. The animation of glyphs mimics the body language, making them more effective in conveying a linguistic barrier-crossing message. Glyphs can also trigger a feeling of familiarity in the brain, thereby increasing retention of the message.
Each glyph increases the value of a stat by certain range. This is shown on the item's page when you open it in the Glyph Storage. This range is the maximum value that the glyph can enhance a stat by but not the amount it will actually increase the stat by. The actual value of the glyph is determined by the tier and quality of the product you are enchanting it to.
The majority of upgrade components that are slotted into items can't be repaired or replaced without dismantling the equipment in question, except for legendary equipment and upgrades. If you do have a rune or glyph that has not yet been applied to your gear, you can move it to another piece of equipment by utilizing the Upgrade Glyphs context menu on the Glyphs panel. This will create a Glyph Set that includes the chosen glyph.
You can take out the glyph using the Black Lion Salvage Kit, or an Ascended Salvage tool. This will cause the item to be destroyed in which it is installed, but you can recover the upgraded item by using the glyph and its shards, therefore it should not be considered a loss.
The addition of a glyph to an item can cause it to become unstable, and the shards that are left of that glyph will disappear from your inventory when you remove the item. You can also put an inscription on your equipment to give it a bonus. For instance, the glyph Deferred Damage can store damage for the wearer and deal it slowly rather than all at one time. This can be helpful for those who take lots of damage from enemies however do not want to be overwhelmed.
Reroll tokens
Reroll tokens are used to alter the affixes that are placed on equipment and weapons. They can be obtained from various sources, including mystery boxes, rare drops from skulled monsters, or by killing bosses. Each reroll token gives players a new random affix that is usually superior to the one they had before. Reroll tokens are also a good way to reroll weapon stats and can be upgraded to provide better damage or additional perks.
Items that have been rerolled will not appear in the item upgrade menu, but they are still eligible to receive upgrades. These rerolled items can be recycled by pressing the "upgrade" button that alters the layout of the item window and allows up to six items to recycle. The level gauge is boosted by recycling an item. This amount is determined by the item's rarity and its level, which means higher-level items are more valuable to recycle than lower-level ones.
Players can also make use of Reroll Tokens and Star Remnants to roll rerolling weapons to upgrade units. Rerolls roll the % chance of a weapon trait. If it is higher, the weapon is upgraded, and if it rolls lower, it remains the same. Weapons can be repeated up to three times.
Rerolling is a great option to upgrade an item. However, players should be aware of the fact that the total ilvl will be diminished by the number of the rerolls required to bring it to the final ilvl. This reduction effect is most effective with Diadems and rings that don't have alternatives to raise their ilvls.
The reroll system has been criticized by players for being expensive and it's more equitable to let players pay for it in the form of money or food items which would allow players to modify their build without wasting time and energy. The developers aren't planning to offer paid rerolls in this stage of the game's development. They're planning to include a potion that will allow players to change their race in the future.
Leveling
There are many ways to level up an item upgrade. The first way to level up an item upgrade is by increasing the upgrade amount. This boosts the value of upgrading any stat. The second is to increase the upgrade effect that increases the damage or heal of a specific stat. Additionally, there is the ability to upgrade the base item to a higher upgrade type. Once this is done, the new item will keep its iLevel, but will be upgraded with the effects of the upgraded item type.
It is important to remember that upgrades are random. In most cases a better roll is based on the glyphs. However there are instances when a more or unique roll could occur. The type of item will determine the iLevel. If you upgrade a rare or exclusive item to a special kind of item, it is likely to getting a higher level.
Upgrading items can be costly, particularly when you're upgrading a piece of equipment from the standard to the legendary track. The cost of upgrading a piece of equipment will depend on its base iLevel and the amount of upgrade levels. In addition, some upgrade tracks require crests in order to reach the next upgrade level.
If you're lucky, your upgraded item may attain the highest level on its upgrade track and gain an additional benefit. This will result in a significant increase in the value of the item. The bonus effect can change with each upgrade items level though. In general the effect of upgrading is increased by a factor of +3.
Depending on the item's base level and upgrade process, the iLevel for the upgraded item upgrader mod will change as well. For example, an item that is upgraded from being a scarce or unique item to an exceptional one is likely to gain the enhanced defense of the new base item.
