How to Grow Cannabis - Marijuana from Seed > 자유게시판
작성자 Corazon
댓글 0건 조회 23회 작성일 25-08-05 18:18
originalInstructions included with the seeds suggested germinating the seeds between damp paper towels and planting them after germination, rather than planting them directly in soil. I did both. Some I wrapped in a damp paper towel, placed in a plastic bag and put in a dark spot. Some I planted directly in large pots. There was not much difference that I could See details. The seeds germinated and came up after just a few days. Same cannabis seedling 3 days later. My soil is a nice garden loam I get from Shisler Brothers, near Port Colborne. Choose a nice growing soil. I kept a couple of plants under lights and the others in my plastic pool greenhouse enclosure. The light plants were bushier because the light intensity was higher but they both grew well so I don't think it makes much difference. The photo shows the light set up when I was starting my tomatoes.
photo-1701154687217-2756a65e179f?ixid=M3wxMjA3fDB8MXxzZWFyY2h8M3x8Y2xpY2slMjBoZXJlfGVufDB8fHx8MTc1NDM1OTY4NXww\u0026ixlib=rb-4.1.0
originalI put the light on a timer for Prime Boosts 16 hour days. I used a mylar emergency blanket to wrap the rack up because the light is very bright and the mirrored finish of the blanket helps bounce back the light to the plants. Both the greenhouse and the light plants grew quickly and soon I put them all together because they had outgrown my rack. Pot plant after 3 weeks. When the weather warmed up a bit I put the plants outside. I tried several locations and the most successful was a partially shaded area which only got strong afternoon sun. All my plants were in pots and as they grew larger I had to re-pot them into larger containers. I had good soil but I fertilized regularly with Miracle Grow All Purpose Plant Food. The link is to Amazon. I use it in my gardens and it works well. I think there are many other brands that would do just fine.
My plants grew very quickly and needed to be watered up to twice a day or even more. I should have used larger pots. I think they would have benefited from an automatic drip system. A couple plants started to yellow, I suspect from too much heat and from occasionally going dry. I took more care and watered more often and the plants seemed to recover. Come September, the plants started to flower. Plants either flower when the days start getting shorter OR in some strains, after a certain number of weeks. Royal Queen Seeds page on flowering process. There are any number of fairly complex instructions on the web on what to do when the plants start flowering. If they are being grown indoors under lights then the number of hours should be reduced to induce flowering. There are various instructions on what to feed and when. I did not do anything special since my plants decided on their own to flower and seemed to be doing fine without my help.
They stopped growing and put their energy into flowering. At first there is a whole lot of little white filaments at the tip of the branches. That is the beginning of the female plant. If you get little balls with a sort of a stem then you have a male flower and should cut it down. See the link to Royal Queen Seeds above. If you have feminized seeds then it's unlikely you will get male flowers unless you have stressed them a lot. I worried a lot about female / male flowers but I did not need to. My friend had a male flower and Prime Boosts and the differences are very obvious when you see them side by side with female plants. The flower gradually darkened and Click here turned a reddish brown. They were also very sticky with resin and sort of sparkled in the sunshine. The leaves started yellowing at the bottom of the plants. Not all my plants looked the same and some did not get the reddish colour.
