How Ghost Immobilizer Was Able To Become The No.1 Trend In Social Medi…
The Ghost 2 Immobiliser
The Ghost 2 immobiliser is the first aftermarket CAN bus immobiliser and it protects your car from key-cloning, hacking, and even key theft. The only way a criminal could take your car is physically towing it away and they'd then have to enter the correct PIN code before they'd be able to start it!
Keys and LEDs are not illuminated or have no Key Fobs
In contrast to other immobilisers Ghost 2 doesn't use key fobs or LED indicators to inform the user of their PIN code , or when the system is deactivated. This feature hides the device to prevent thieves from noticing the device.
A PIN code is transmitted by the vehicle's switch to the Ghost immobiliser. This will stop your car from beginning. The system is extremely simple to set up and users can change their password at any moment.
In addition it is the Autowatch Ghost doesn't require any additional batteries or radio frequencies to operation. This allows it to be used in a wide variety of vehicles.
Its primary purpose is to stop your car from getting started if a wrong key is used. It also shuts down parts such as the starter motor or fuel system, making your vehicle immobilised.
This is an enormous benefit as it means you won't have to worry about your car being stolen. It is more secure to drive as a criminal will not be able to restart your car after it's been disabled.
The Ghost system uses CAN bus data for communication with your vehicle's ECU. It will only allow your car to start when you have entered a certain sequence of key presses into your vehicle's factory buttons. This sequence of keystrokes can last as long as 20 and is an individual PIN code that you'll only have.
Your engineer will explain to you how to input the disarm sequence into the buttons of your vehicle. This includes the centre console buttons and door-panel buttons. It will be impossible for anyone else to start your car once the pin code is entered.
The Ghost 2, a TASSA-approved vehicle immobiliser, is a great solution to guard your vehicle against theft key-cloning, hacking, and theft. The absence of LED indicators and key-fobs makes it difficult to locate by thieves.
It can be used with many different vehicles and can only be installed by a garage that is approved. It will not invalidate your warranty, and it can't be detected by diagnostic tools of a professional and therefore safe for you to drive.
No Circuit Cuts
The ghost immobilise 2 immobiliser works by using the buttons of your vehicle to create a unique PIN Code sequence that must first be entered before the engine is able to start. The sequence of presses can be up to 20 digits long and can be changed at any time without the need to redo any wiring. This means that it's impossible for thieves to know the code before they attempt to break into.
It also has the option of allowing your vehicle to be started and driven without the need for a PIN Code. This feature is designed to assist you deactivate the Ghost when your vehicle will be used as a valet parking vehicle or as the purpose of providing a service.
When you install your car, it will be tested thoroughly to ensure that the Ghost is operating properly. This is a crucial part of the process. We will go through everything with you to ensure that you are satisfied before you leave.
We will then create your personal PIN Code in the Ghost to ensure it's safe, giving you peace of mind knowing that it will not be broken into. This is a great method to eliminate the need for additional security systems like remote keys or key fobs which are vulnerable to hacking and theft particularly with the rate of theft through contactless increasing across Europe.
The CAN bus data network that Ghost uses is unnoticeable to thieves, preventing them from using radio frequency or code grabbing technology to detect the security system that is installed in your car. This is an important factor when it comes to the security of your vehicle. It also offers you a greater level of security than other immobilisers on the market.
The Ghost isn't able to cut circuits, meaning it cannot be tampered with by professional criminals who use diagnostic tools to identify and disarm alarms or immobilisers on modern vehicles. This is crucial because many of the most affordable and effective methods of breaking into a car is through cutting wires, or altering the relays on a standard immobiliser.
No RF Scanning
The Ghost 2 immobiliser is the most advanced in-car security that fully protects your vehicle from key cloning, hacking, and theft. Its unique system makes use of the buttons on your vehicle to input the PIN number that is unique and customizable similar to credit card.
The Ghost 2 is not like traditional car security devices. It does not include any key fobs, circuit cut or LED indicators that can be used for location information. The unit communicates with the ECU via the CAN bus. It only begins your vehicle when it has entered the proper pin sequence.
This makes it difficult for a thief to bypass the Ghost's security. They cannot use a cloned key or replace the ECU as they can't cross the wires, and they are unable to remove the device from your vehicle as there is no radio signal coming from it.
The ghost vehicle immobiliser can be used to secure any vehicle with a CAN Data Network. It's compatible with most modern automobiles and can be used to secure older vehicles with CAN data systems as well.
The Ghost is also very well-known because it doesn't alter the vehicle's appearance. It's so small that it can be installed anywhere in the harness of your vehicle and is so subtle that thieves need to be extremely adept and know exactly where to look to find it.
It also doesn't leave any evidence of its installation, which is crucial as thieves frequently make stealthy getaways using their vehicle after they've found it. If your car is a expensive or rare model then the Ghost can help ensure your investment is secure.
TASSA (The Tracking and Aftermarket Security System Association) has recognised the Autowatch Ghost as an effective instrument to stop motor vehicle theft. The TASSA association is comprised of traders and manufacturers who are at the forefront of developing solutions for vehicle crime prevention.
The Ghost is an TASSA approved device that is included in a few insurance companies. The Ghost is also endorsed by the police because it helps in identifying stolen vehicles. TASSA recommends working with an installer who is TASSA-approved to ensure the device is installed correctly. They can also provide a video recording of the installation. They will also check the vehicle for identity checks or CRBs.
No Radio Signals
A Ghost 2 immobiliser is a small electronic device that is hidden in the engine compartment . It keeps your car from running until you enter a unique PIN code sequence. It protects your vehicle against key theft, cloning, and relay theft as in addition to hacking. It also includes a secure emergency code for when you forgot your PIN or need to reset it.
It is compatible with all major cars. It's quiet, low-maintenance and can be set up in a secure location and is completely invisible to the untrained eye.
The Ghost 2 allows you to create a personalised PIN for your car that goes beyond security. The pin can be entered using the app on your smartphone or by pressing buttons on your dashboard, steering wheel and the dashboard in sequence.
This unique PIN is not compatible with other security systems or cloning equipment This makes it impossible for thieves to use it to take your keys. The PIN also blocks thieves from changing the ECU inside your vehicle to bypass your security system.
The Ghost 2 is a security feature that stops the Ghost 2 from communicating with your dealer's computers. In rare cases the dealer may need to perform vehicle fault finding and warranty work.
If you have any vehicle faults your dealer needs to put your car in service mode before they can begin the process of diagnosing the problem. This stops communication between the ECU in your car and the dealer's computer system. It also prevents any errors that could lead to your car being sold without a valid MOT certification.
This makes the Ghost an effective security measure against key theft, keyless theft and relay theft. It can be fitted to a variety of types of vehicleslike motorbikes and motorhomes, and ride-on lawnmowers.
No Circuit Cuts
No RF Scanning
No Radio Signals
- 이전글10 Essentials To Know Buy Category C Driving License You Didn't Learn In The Classroom 25.04.05
- 다음글15 Things Your Boss Wishes You'd Known About Automatic Mop 25.04.05
