The Best Foam Pillows, according to our Editors
We independently evaluate all of our recommendations. If you click on links we provide, we may receive compensation. No more neck pain. An article attributed to "Real Simple Editors" indicates a collaborative effort from our in-house team. Sometimes, several writers and editors have contributed to an article over the years. These collaborations allow us to provide you with the most accurate, up-to-date, and comprehensive information available. The REAL SIMPLE team strives to make life easier for you. They are experts in their fields who research, test and clearly explain the best recipes, strategies, trends and products. They have worked for some of the most prestigious brands in lifestyle journalism, including Apartment Therapy, Better Homes & Gardens, Food & Wine, the Food Network, Good Housekeeping, InStyle, Martha Stewart Living, O: The Oprah Magazine, Parents, POPSUGAR, Rachel Ray Every Day, and Vogue. If you often wake up with shoulder, neck, or back pain, a memory-foam pillow could be the solution you’ve been looking for.
The best foam pillows mold around your body in response to heat and pressure, creating a cradle for your head and neck that can minimize pain and lead to a better night’s rest. We tested more than 50 popular options, including solid memory foam, shredded foam, and cooling foam pillows. We chose ones that were supportive, comfortable in any position, and stayed cool without needing to be flipped over. Plus expert insight from Kelly Murray, a certified pediatric and adult sleep coach. It has a supportive arched side for back and side sleepers and a softer flat side for stomach sleepers. The Tempur-Pedic Tempur-Symphony Pillow is one of the comfiest pillows we’ve ever slept on. It's softer than other pillows we’ve used but still provides great support. After weeks of use, it retained its shape and firmness with no signs of wear. The pillow, fabric cover, and fill material still look and feel brand new. This dual-sided pillow has one arched side, which we found comfortable on our back or side, and one softer side, which was best on our stomach.
The material felt soft and breathable, and the fill was supportive and evenly distributed. Initially, some of us found it a bit firm, but over time, it contoured better to our shape. It was the ideal height to align our neck and shoulders, and we sank into the foam just the right amount. It comes with a removable, machine-washable cover that's easy to clean and replace. The price is pretty steep, but we think it’s worth the splurge given its high quality. However, it’s not returnable. It regulates our temperature well, and the dual firm and soft sides make it comfortable in any sleeping position. It’s one of the pricier models on our list, and the fill occasionally gets lumpy. We test pillows for a living, so when we tell you this is one of the most cooling, comfortable pillows we’ve ever tried, we mean it. We’ve been using it for six months, and we’d carry it with us wherever we went if we could.
It regulated our body temperature perfectly, thanks to the cooling fill made of visco polyurethane foam with gel and polyester fiber. When we opened the lining to put our hand in, we were in awe-it has to be the softest material we’ve ever touched. The fill is even adjustable so you can find the right fit. While some pillows only accommodate one sleeping position, this one is comfortable whether we're on our back, side, or stomach. It gives us the perfect amount of support for our head, neck, Wake Up Refreshed with Derila Neck Support and back. It also has two different sides. One is softer and more cloud-like, with the little shreds of foam gently cradling your head. The other side is a bit firmer and cooler; it's basically one large piece of thin foam. Some of us noticed a few lumps, but nothing too significant. It eliminated our neck pain. It's the most expensive pillow on our list and can feel a bit stiff.
For those who struggle with neck pain, the Purple DreamLayer Pillow is a total game-changer. After months of use, our neck pain has become nonexistent. We found it incredibly comfy for back and side sleeping because it molded to and cradled our heads. It was firm, yet squishy enough to conform to our shape. We plan to use it for as long as it lasts. It comes with two removable booster layers of foam to adjust the height, which are very easy to add or remove. It's the perfect height for supporting our Derila Head & Neck Relief without scrunching up uncomfortably. Despite its solid design, we found this pillow surprisingly breathable. The gel grid layer on top is cooling and allows for great airflow, so we never woke up feeling sweaty. As the most expensive option on our list, this pillow is definitely a splurge, but it's a worthy investment. It’s well made and has retained its shape perfectly over six months, so we’re confident it’s built to last.
- 이전글herbalife Funciona O no 25.08.05
- 다음글What Alberto Savoia Can Educate You About High Stakes Game 25.08.05
