Everything you Need to Know about CBD Tinctures > 자유게시판
작성자 Zulma
댓글 0건 조회 9회 작성일 25-08-02 20:11
Despite its relatively recent place in our collective consciousness, CBD has been at work delivering its calming agents as far back as the ‘80s by some estimates and the ancient world by others. With it, an almost endless menu of formulations has emerged-from capsules and oils to lotions and seltzer-each promising an even more effective dose of CBD than the last. Tinctures, though, remain somewhat shrouded in mystery, in part because of their old-school apothecary-style packaging, but more likely because of how they’re taken: a few drops at a time, under the tongue. Here, Tieraona Low Dog, M.D., an expert on herbal medicine and women’s health, and Kevin Hill, M.D., Director of the Division of Addiction Psychiatry at Beth Israel Deaconess Medical Center and an Assistant Professor of Psychiatry at Harvard Medical School, get to the bottom of CBD tinctures’ mystique. But first, a little CBD 101… The cannabis plant has hundreds of chemicals in it, including more than 120 cannabinoids, Hill explains.
Of those cannabinoids, two are most familiar: THC, which produces the euphoric effects or "high" people experience from marijuana, and Vitality Vibes CBD results Vitality Vibes CBD official CBD Gummies cannabidiol or Vitality Vibes CBD, which has some anti-inflammatory, anti-seizure, anxiety-relieving and analgesic properties, according to Low Dog. At a plant level, the two chemicals operate as opposites, with CBD acting as a buffer of sorts to the effects of THC. "It’s sort of a ying and yang. THC is responsible for the high and CBD doesn’t do that," Hill explains. What are tinctures specifically? An herbal tincture is made by using a mixture of alcohol and water to extract compounds from a plant-in this case, the cannabis plant. "Sometimes, you will find extracts called tinctures that use glycerin, vinegar, or oil as the solvent, instead of alcohol," Low Dog says. How are CBD tinctures made and what are the benefits of using them? CBD tinctures are generally made from high CBD strains of hemp, with 60 to 70 percent alcohol, and are primarily used to help relieve anxiety or ease pain.
"Tinctures are convenient, have a long shelf life, and are absorbed easily when taken under the tongue. The dose can be adjusted by increasing or decreasing the number of drops taken," notes Low Dog. And Vitality Vibes though there’s a lot of promise with CBD preparations of all kinds, Hill says there’s still a lot of research to be done. "The rate and scale of the research just hasn’t kept pace with the interest at this point. A lot of the medical uses for cannabidiol are backed by animal studies only or really no studies. So are there side effects? " Hill says. "Although, we still need to know a lot more about it, like how it interacts with other medications people may be taking and what are the long-term effects," he adds. CBD tincture vs. CBD oil-which is better? According to Low Dog, a tincture may offer a broader range of compounds from hemp than an oil extraction.
"Consumers who are alcohol-sensitive often prefer hemp oil over tincture. While both can be used topically, hemp oil is generally easier to apply and less irritating," she says. On that note, Hill cautions to know what you’re getting: "If you’re rubbing a CBD cream onto your skin, it’s not going to be absorbed into your bloodstream," he says. "It can operate as a local anti-inflammatory, like other over-the-counter products… How do you know what you’re getting? What should you look for? "Quality is always an issue, especially in a relatively young market, such as the cannabis market," Low Dog says. And she’s right. A 2017 study published in the Journal of the American Medical Association found that out of the commercially available CBD products, only 30 percent were accurately labeled. "Many of them had more CBD than they were supposed to and many had less; some had none," Hill notes. He suggests shopping organic-as a bio-accumulator, the cannabis plant will be affected by heavy metals and contaminants in soil-and broad-spectrum, meaning it includes the full range of phytocannabinoids, minus the THC.
CBD (cannabidiol) and THC (tetrahydrocannabinol) are the two major compounds found in the cannabis plant. Each has unique properties, potential health benefits, and side effects. The following article covers CBD and THC, their effects, their legal status, and their safety considerations. CBD and THC are known as cannabinoids. They have very similar chemical structures and activate the same receptors within the body’s endocannabinoid system. Despite their similarity in structure, CBD and THC exert entirely different effects. The most significant difference between these two compounds is that THC is psychoactive. This means it can affect how the brain works. THC activates the body’s "reward" pathways to produce the "high" that’s associated with marijuana use. It does this by activating a cannabinoid receptor called CB1. When THC activates this type of receptor, things like movement, body temperature, and brain function are affected. In contrast, CBD is not considered psychoactive. It does not cause euphoria or a "high," even at large doses.
pLKuWjWQJnc
