The Best Pillows, Tested and Approved > 자유게시판
작성자 Lavonne
댓글 0건 조회 32회 작성일 25-08-02 12:48
What is the best overall pillow? If you're not getting enough sleep or if your sleep quality seems low, there may be a few factors to blame. A better mattress may be the answer to your sleep woes, but a great pillow could also make a world of difference. You need to consider several factors to find the best pillow for your needs, including your sleeping position and your budget. Our sleep experts have five-plus years of hands-on (and heads-on) pillow testing, which we combined with brand and material knowledge, weeks of nightly testing and customer reviews to pick the best pillows for every sleeper. Whether you’re a side sleeper, hot sleeper, back sleeper, on a budget or have neck pain, we have a pillow for you. What is the best overall pillow? Our thorough testing concluded that the Sleep Number ComfortFit Pillow Ultimate is the best overall pillow. It includes three removable inserts that make the adjustable pillow comfortable for side, back, stomach and combination sleepers.
image.php?image=b17eva676.jpg&dl=1
The Sleep Number pillow is also hypoallergenic and made of memory foam and down-alternative fibers. While the price tag is hefty, look out for Sleep Number sales. We added direct recommendations in each listicle and a comparison table. Products on this list stayed the same. Why we like it: The Sleep Number Comfortfit Pillow Ultimate is an ultra-comfy pillow suitable for all sleeping positions. That's why it's our pick for the best overall pillow. With your choice of classic, Orthopedic Sleep Pillow curved or ultimate shape, it's the type of pillow everyone will love. It's also one of the best hypoallergenic pillows, with memory foam and premium down-alternative fibers on the inside. The cover is noticeably soft and Get Derila Official breathable when you lie down on the Sleep Number Comfortfit Pillow. Who it's best for: What makes the Sleep Number Comfortfit Ultimate pillow unique is its three removable inserts, letting you tailor it to your needs. This makes the pillow ideal for all sleeping positions, especially those who aren’t sure what loft (pillow height) they prefer or need.
Side sleepers should use two inserts; back sleepers are best suited with two or three inserts; and stomach sleepers should Try Derila Today one or two. Who shouldn’t get it: It is a more expensive pillow, coming in at about $100. I wouldn’t recommend this pillow to someone on a budget or someone who needs more than one pillow for their bed. Why we like it: From the popular mattress brand Casper, this cooling pillow is made with perforated poly foam, polyester fibers and gel. It utilizes what Casper calls Snow Technology, which includes phase change material that remains temperature-neutral around your head and neck and allows for airflow. This pillow has the best qualities of a solid memory foam pillow while adding comfortable cooling. Who it's best for: Unlike other "cooling" pillows, the Casper Hybrid is actually cool to the touch. When you put your head on it, it immediately feels cool.
If you're a hot sleeper -- or someone who cherishes the cold side of the pillow -- consider this product. We also recommend using a light and breathable pillowcase, such as silk, bamboo or Tencel. Who shouldn’t get it: I’m a combination sleeper and mostly sleep on my stomach, and when testing this pillow on my stomach, it did hurt my neck. It isn’t low enough for strict stomach sleepers. Why we like it: You may have heard of The Coop Sleep Eden Pillow, which often tops lists of the best pillows. If you thought that version was cool, it got even better. The Coop Eden Cool Plus Pillow is the new version of the Eden Pillow. It still has a similar cool-to-the-touch cover but now has a heat-wicking inner liner, a gel layer and shredded gel-infused memory foam, which is great for hot sleepers. The filling is Greenguard Gold and CertiPur-US certified. Who it's best for:This pillow is also adjustable, making it ideal for all sleeping positions and those who aren’t sure which firmness and loft they prefer.
It comes with extra filling and an option to pull the filling out. I like that the memory foam contours and lets you sink a little into the pillow, regardless of how much you fill it. Back sleepers, especially, will feel fully supported with this pillow. Who shouldn’t Get Derila Official it: If you prefer sturdy, thick or firmer pillows, a full memory foam pillow may be better for you. If you don’t enjoy sinking into the pillow, you will want to avoid shredded memory foam like Coop. Why we like it: Like the Purple Mattress, the Purple Pillow uses a unique, one-piece polymer grid to cradle your head and neck as you sleep. The grid distributes weight well and doesn't absorb heat like foam can, so fans say it stays extra cool and cozy at night. Thanks to its construction and loft, the Purple Harmony Pillow is the best pillow for side sleepers.
