Answers about Chemistry > 자유게시판
작성자 Lawerence
댓글 0건 조회 29회 작성일 25-08-02 12:30
The formula mass of urea (NH₂CONH₂) is calculated by adding the atomic masses of its constituent elements: nitrogen (N), hydrogen (H), carbon (C), and homepage (please click the next website) oxygen (O
Read more
Chemistry
How did leucippus and democritus use atoms to explain different physical properties?
Asked by Anonymous
Leucippus and Democritus proposed that all matter is composed of indivisible particles called atoms, which vary in size, shape, and arrangement. They suggested
Read more
Chemistry
What is the correct electron configuration for an element with 5 electrons?
Asked by Anonymous
The correct electron configuration for an element with 5 electrons, which is boron (B), is 1s² 2s² 2p¹. This indicates that the first energy level (1s) contains
Read more
Chemistry
What are the safety tips for a eye dropper?
Asked by Anonymous
When using an eye dropper, ensure the dropper tip does not touch any surfaces, including your eye, to prevent contamination. Always wash your hands before using
Read more
Chemistry
What do you call the liquid in the conical flasks?
Asked by Anonymous
The liquid in conical flasks is typically referred to as a "solution" if it is a homogeneous mixture of substances. If it is used in a laboratory sett
Read more
Chemistry
What are 10 examples of resilience?
Asked by Anonymous
Overcoming a serious illness through treatment and lifestyle changes. Bouncing back from job loss by acquiring new skills and finding a better position. A stud
Read more
Chemistry
Can a waterbed conduct electricity?
Asked by Anonymous
Yes, a waterbed can conduct electricity, but it is not a good conductor. The water inside the bed is primarily a dielectric material, meaning it does not easily
Read more
Chemistry
HOW boiling pont of candy mixture serves as the measure of doneness?
Asked by Anonymous
The boiling point of a candy mixture serves as a measure of doneness because it indicates the concentration of sugar and other ingredients in the mixture. As wa
Read more
Chemistry
What are the properties of translations?
Asked by Anonymous
Translations are rigid motions that preserve the shape and size of geometric figures, meaning that the original and translated figures are congruent. They maint
Read more
Chemistry
Explain how phasing and calibration is carried out?
Asked by Anonymous
Phasing and calibration in signal processing involve adjusting the timing and amplitude of signals to ensure they are aligned correctly for accurate analysis or
Read more
Chemistry
+1
What type of plastic can be melted and re molded using thinners?
Asked by Anonymous
Thermoplastics are the type of plastics that can be melted and re-molded using thinners. Common examples include polyvinyl chloride (PVC) and polystyrene, which
Read more
Chemistry
What type of govermemnt has one person in charge?
Asked by Anonymous
A government with one person in charge is typically called an autocracy. In this system, a single individual holds absolute power and authority over the state,
Read more
Chemistry
+1
Why could Bohr's model be called a planteary model of the atom?
Asked by Anonymous
Bohr's model of the atom is often described as a planetary model because it depicts electrons orbiting the nucleus in defined paths, similar to how planets orbi
Read more
Chemistry
What is the effect on the space between molecules when a body is cooled?
Asked by Anonymous
When a body is cooled, the kinetic energy of its molecules decreases, causing them to move closer together. This results in a reduction of the spaces between th
Read more
Chemistry
Is nitrile rubber suitable for MTBE?
Asked by Anonymous
Yes, nitrile rubber is suitable for handling MTBE (methyl tert-butyl ether) due to its good resistance to hydrocarbons and solvents. However, the compatibility
Read more
Chemistry
What 2 chemical properties of gasoline?
Asked by Anonymous
Two important chemical properties of gasoline are its octane rating and volatility. The octane rating indicates the fuel's ability to resist knocking or prematu
Read more
Chemistry
What are the four alternative name for ground substance?
Asked by Anonymous
Ground substance is also referred to as the extracellular matrix, interstitial fluid, amorphous matrix, or tissue fluid. It is a gel-like component of the extra
Read more
Chemistry
Why are the colors of the rainbow the same as the color change in universal indicator?
Asked by Anonymous
The colors of the rainbow and the color change in universal indicator both result from the interaction of light with different wavelengths and chemical properti
Read more
Chemistry
If you put a nail in a bottle without waterwout it rust?
Asked by Anonymous
Yes, a nail placed in a bottle without water can still rust, but the process will be slower than if it were in a moist environment. Rusting occurs when iron rea
Read more
Chemistry
What is Energy density of liquid hydrogen?
Asked by Anonymous
The energy density of liquid hydrogen is approximately 120 megajoules per kilogram (MJ/kg). This high energy density makes it an attractive fuel for various app
Read more
Chemistry
Can Cancellation refers to the suspension of a revocation?
Asked by Anonymous
Cancellation typically refers to the annulment or termination of a contract or agreement, while revocation involves the withdrawal of an offer or permission. Su
Read more
Atoms and Atomic Structure
+1
Because atoms are neutral the number of must equal the number of?
Asked by Anonymous
Because atoms are neutral, the number of protons must equal the number of electrons. Protons carry a positive charge, while electrons carry a negative charge. T
Read more
Chemistry
Who is aloser?
Asked by Anonymous
The term "loser" is often used colloquially to describe someone perceived as unsuccessful, lacking social skills, or failing to meet societal expectat
Read more
Chemistry
Is solids are regit?
Asked by Anonymous
Yes, solids are rigid because their molecules are closely packed together in a fixed arrangement. This close packing allows solids to maintain a definite shape
Read more
Chemistry
+1
WHAT IS THE PH OF AMMONIUM PHOSPHATE SOLUTION?
Asked by Anonymous
The pH of ammonium phosphate solution typically ranges from about 6.0 to 7.0, depending on its concentration and the specific form of ammonium phosphate used (m
Read more
PreviousNext
Trending Questions
What substance is a liquid at 105 Celsius? Explain the fermi level in intrensic and extrensic semi conductor? What is the different about the valence electrons for all elements in a group? What is the first basic metal on the periodic table? How to find the empirical formula from percentages? Does pomigranite juice with cold water become darker than pomigranite with warm water? How is antisera made? What percentage of gas is in the air? What household items contain elements from the periodic table? What is the unit of measurement represented by the abbreviation "m"? What kind of reaction has products that are simplier substances than the reactant? What is the purpose of a chemistry apron? Did the first steam engine ever built produce carbon dioxide? Which chemical treatment produces a white-appearing latent print? Is tyndall effect observed in true solution? Describe oxygen model in isotopes? What is opt model? What is 0.0030201 rounded to 3 significant figures? How are Rf values used? An example of an emergent property of life is?
Resources
Leaderboard All Tags Unanswered
Top Categories
Algebra Chemistry Biology World History English Language Arts Psychology Computer Science Economics
Product
Community Guidelines Honor Code Flashcard Maker Study Guides Math Solver FAQ
Company
About Us Contact Us Terms of Service Privacy Policy Disclaimer Cookie Policy IP Issues Cookie Settings
Copyright ©2025 Answers.com. All Rights Reserved. The material on this site can not be reproduced, distributed, transmitted, cached or otherwise used, except with prior written permission of Answers.
