6 Best Keto-Friendly Cooking Oils (and 5 to Avoid) > 자유게시판
뒤로가기 자유게시판
작성자 Marilou Ceja 작성일 25-08-02 03:54 조회 2 댓글 0
Keto is a low carb, high fat diet, but sometimes the "high fat" part can be a challenge - especially if you’re new to eating keto and unused to eating so much fat. To ensure you get enough of this macronutrient, you can be more generous with cooking oil on your food. However, it can be difficult to know which cooking oils are best suited for keto weight loss. Here are 6 of the best keto-friendly oils and cooking fats, along with 5 to avoid, as well as some helpful instructions regarding shopping for cooking oil. Coconut oil is a unique plant-based oil made from coconut flesh. However, one drawback of coconut oil is that it imparts a coconut taste to foods that are cooked with it. Olive oil is made from the oil pressed from olives, which are naturally high in fat. Look for extra virgin olive oil, which is the oil that’s extracted from the olives on the first press.
It’s generally the least processed and the highest in quality. Avocado oil, which is made from pressed avocados, is another excellent oil choice. One drawback of avocado oil is that it’s more expensive than both olive and coconut oils. Butter is a solid fat made from dairy cream. While it’s not technically an oil, it’s used in cooking the same way that many oils are. Butter adds a rich flavor to dishes, but it also browns very quickly - and therefore can burn rapidly. It’s not suitable for high heat cooking, especially if the food will be cooked for a long time. Ghee is made by heating butter and removing the milk proteins that accumulate during the heating process. The result is a flavorful clarified butter that solidifies at room temperature. Because the milk proteins are removed, some people who are sensitive to dairy report that they can eat ghee with no issues.
However, if you have a dairy allergy you should still avoid ghee in case it contains traces of the dairy proteins that trigger your allergy. Ghee doesn’t burn as easily as butter, so it’s more suitable for Keto by Supraketo Supplement high heat cooking. Animal fats aren’t technically oils but rather solid fats at room temperature. Still, they’re suitable for keto cooking. Note that these choices are high in saturated fat. As such, it may be best to moderate your intake. These oils are highly processed, unlike the more easily extracted oils from fatty foods like coconuts, avocado, and olives. They’re high in polyunsaturated omega-6 fats, which may cause inflammation if they’re not balanced with enough omega-3 fats from foods like salmon and flaxseeds. For these reasons, industrial seed oils should be limited not only on the keto diet, but no matter which eating pattern you adhere to. It’s best to balance your choices based on your health goals and medical and family history.
It may be a good approach to speak with your doctor or a registered dietitian about the appropriateness of following the keto diet before starting it. Here are a few guidelines to help you choose a cooking oil. The more fatty a food naturally is, the less processing that’s required to extract oil from it. That’s why you should favor oils made from naturally high fat foods like avocados, olives, and coconuts. On the other hand, vegetable oils made from foods that aren’t naturally high in fat - like corn and soybeans - require extensive industrial processing to be produced. Avocado or olive oil products that are significantly less expensive than similar products may be blends - meaning that they’re cut with a less expensive oil (usually one of the industrial seed oils listed above). Check the ingredient list to be sure your cooking oil of choice doesn’t contain any low quality types of oil.
댓글목록 0
PC 버전으로 보기
