Understanding Satta King Charts: A Beginner’s Guide to Reading Results > 자유게시판
작성자 Gertie Hillman
댓글 0건 조회 4회 작성일 25-07-30 16:19
If you’re new to Satta King, one of the first things you’ll encounter is the Satta chart — a list of past results organized by date and market. But for beginners, these charts often feel confusing. What do the numbers mean? How can you use them to improve your guesses?
Understanding how to read, analyze, and apply information from Satta King charts is a major step toward playing smarter.
This article will walk you through everything you need to know about Satta King charts — including how they work, what to look for, and how to use them to build better strategies.
What Is a Satta King Chart?
A Satta King chart is a historical record of winning numbers for different markets like Gali, Desawar, Faridabad, and Ghaziabad. Each chart displays:
The date of the result
The winning number
The market name
Some charts also include:
Time of result declaration
Weekly or monthly summaries
Ending digits and pattern highlights
These charts are the primary tool serious players use to build logic and make predictions.
Basic Layout of a Satta King Chart
Here's an example of a simple Desawar chart:
Date Market Result
1 June Desawar 49
2 June Desawar 62
3 June Desawar 18
4 June Desawar 86
5 June Desawar 91
Each entry represents the final declared number for that day.
Over time, these results form patterns — and that’s where the smart play begins.
Why Satta King Charts Matter
Charts help you:
✅ Spot repeating numbers
✅ Identify hot numbers (frequently appearing)
✅ Notice cold numbers (not appeared for many days)
✅ Use logical strategies like gap, mirror, or pair logic
✅ Make informed guesses instead of random picks
In short, they give structure to your gameplay.
Key Patterns to Look For in Satta Charts
  1. Gap Logic
This checks how long a number has not appeared.
If a number hasn’t shown up for 15–20 days, it becomes a strong candidate.
These are called "gap numbers."
Example:
If 74 hasn’t appeared for 18 days, it might be due soon.
  1. Mirror Logic
This involves using the mirror of a recent winning number.
Mirror pairs:
1 ↔ 6
2 ↔ 7
3 ↔ 8
4 ↔ 9
5 ↔ 0
Example:
If the result is 23, mirror logic suggests 78 could come soon.
  1. Ending Digit Trends
Track which last digits appear repeatedly.
If ending 4 appears for 3 days straight (like 24, 84, 94), there may be a pattern forming. Some players guess numbers ending in the same digit or one digit apart (e.g., 4 or 5).
  1. Repeating Cycles
Watch for numbers that repeat weekly, biweekly, or after certain gaps.
Example: If 39 appeared on 5th and then again on 12th, it might return after another 7-day gap.
How to Analyze a Satta King Chart (Step-by-Step)
Choose one market: Don’t analyze all markets at once. Focus on one, like Desawar.
Collect 30 days of results: Write them out or use an Excel sheet.
Mark repeat numbers: Highlight numbers that occurred more than once.
Note absent numbers: Create a list of numbers that haven’t appeared in 15+ days.
Group by endings: Check how often digits 0–9 appear as the last digit.
Look for mirror possibilities: Apply mirror pairs to the last 5 results.
Shortlist candidates: Based on your logic, pick 2–3 numbers that match patterns.
Sample Analysis
Let’s say these are the last 5 results in Gali:
23, 58, 14, 67, 42
Mirror logic suggests:
78 (mirror of 23)
03 (mirror of 58)
69 (mirror of 14)
12 (mirror of 67)
97 (mirror of 42)
Now compare these mirror numbers to the chart and check if any are "gap numbers" too. If 78 hasn’t appeared in 20 days — you may have a strong candidate.
Mistakes to Avoid When Using Charts
❌ Blindly guessing based on one result
❌ Overanalyzing with too many logics
❌ Copying other people’s patterns without testing
❌ Ignoring actual result flow
❌ Not tracking your own guesses vs. results
Charts are tools — not magic. Use them with logic, not desperation.
Tools That Help With Chart Reading
Notebook: Simple and personal
Excel Sheet: Great for sorting, filtering, and formulas
Chart Apps: Some websites offer digital chart tracking
Whiteboard/Pinboard: For visual patterns if you prefer offline
Use whatever helps you see the trends clearly.
Real-Life Case: Chart-Based Success
Player: Arjun
Market: Faridabad
Approach:
Studied 60 days of results
Used gap + mirror logic
Focused on numbers ending in 6 or 1
Guessed max 2 numbers per day
Result:
6 hits in 20 days
Regained ₹3,500
Built confidence in his own method
"Once I started understanding the chart, I stopped needing random tips."
