New Technologies
Component Attaching Process
entails a complex process of cheap electronic parts online components directly onto the surface of a printed circuit board using a solder paste and reflow oven. The components are set in a specific location on the PCB with a high degree of precision and accuracy. This process offers numerous benefits, including a compact PCB size due to higher component density, reduced weight, lower inductance, and improved thermal conductivity. However, the high precision required for Surface Mount Technology can be challenging and time-consuming, particularly for manufacturers with limited experience.
Advantages of Surface Mounting:
- Reduced PCB size
- Lower component weight
- Increased component density
- Improved thermal conductivity
- Lower inductance
- Higher production expense
- Requires advanced equipment
- Can be time-consuming and inaccurate without proper expertise
- May not be suitable for large-scale production
Through-hole technology involves placing metal pins or leads through holes in the PCB and soldering them to both the top and bottom sides. This process is more traditional, widely available, making it a viable option for manufacturers with existing infrastructure and experience. The primary benefits of THT include lower production costs, greater component options, and simplified circuit board building process. However, THT has several drawbacks, including larger PCB sizes due to lower component density, higher power consumption, and increased inductance.
Benefits of Leaded Technology:
- Lower production expense
- Greater component options
- Simpler circuit board manufacturing
- Suitable for high-volume production
- Does not require specialized equipment
- Bigger PCB sizes due to lower component density
- Higher power consumption
- Increased inductance
- May not provide the same compactness level as SMT
- 이전글(24시간 친절상담)【홈: q888.top】비아그라 구매 아드레닌구입 25.07.26
- 다음글Empowering Educators: Personal Loans for Teachers with Bad Credit 25.07.26
