Open Mike on Invetaris > 자유게시판
작성자 Alycia
댓글 0건 조회 5회 작성일 25-07-23 18:32
Title:
Types of Translation
Word Count:
332
In the chaging world of today, translation needs vary greatly, and so do the kinds of translations. Translation agencies use various terms to refer to different kinds of work they have to perform, and this article will help you to understand better what they mean.
Keywords:
translation agency
Article Body:
There are three main types of translations, technical translation, scientific translation, artistic (literary) translation, translation of documents, and general translation.
Technical Translation is the kind that can be considered one of the most highly demanded, as such translation requires technical knowledge of some specific field, be it reciprocating compressors or an anti-spam program. With such translations, usually translation agencies are preferred to free-lance translators because a good translation agency posesses not only a highly qualified translators with technical knowledge (or even education), investasi but also a special glossary of technical terms that ensure that the terms used in the translation are homogenious, and specialised proofreaders who make sure the translation not only sounds ok, but also will be of help to technicians who will work with it later.
Scientific translation. To this kind may be referred medical translations, translations of scientific works in various fields of studies (such as chemistry, physics, mechanics), different research works. If you have any sort of questions relating to where and komersial how to utilize komersial, you could contact us at the page. A good translation agency will make sure that the terms used in the translation are special terms that will be understood by foreign researchers, doctors, and other specialists.
Literary translations don't only require a thorough knowledge of the source and target languages, but also the ability to correctly translate the original feelings and to employ the most appropriate language means in the translation. A good translation agency will provide you with an experienced proofreader whose native language is the target language of the translation.
Translation of documents is a kind of translation that in all cases has to be ordered from a translation agency because almost always it requires a special certification.
General translation is the simplest kind of all because it deals with a language without any special terminology or literary means.
