15 Hot Trends Coming Soon About Ghost Immobiliser Liverpool > 자유게시판
작성자 Lanora
댓글 0건 조회 38회 작성일 25-04-04 21:17
Protect Your Vehicle With the Autowatch Ghost 2 Immobiliser
It is designed to be discreet, invisible and effective the autowatch ghost 2 immobiliser is designed to be invisible, secure and protects your vehicle from key theft, cloning and hacking. The device is hidden within your vehicle's CAN data network, so thieves are unable to remove it or disable it by cutting wires.
311159893_995841588058766_6213964028136182559_nlow.jpgThe device instead uses the buttons on your steering wheel as well as the centre console in order to create an individual code sequence that can only be manually entered by you.
It's low-maintenance
It's only natural for people to want to protect their cars with the latest technology as car care is an increasing priority in their lives. One way to achieve this is by installing a ghost immobiliser which can help to prevent theft.
Ghost immobilisers are an anti-theft device that operates by shutting off your vehicle's ignition and preventing the engine from running. It works by using a unique PIN code that only you know. This means that no criminal can use a duplicate key or hack the system to gain access to your vehicle.
It's also untraceable as it's small and is wrapped inside the wiring of your vehicle and wiring, making it virtually impossible for thieves to locate. It's also quiet and doesn't emit any radio frequency signals which makes it a great option for those who are worried about their vehicle being stolen.
This CAN immobiliser is easy to install and comes with two options for deactivation: Valet/Service or Transport. Selecting Valet mode allows your car to run within parameters, such as the speed limit of 30 mph. This is done without divulging your pin code to anyone who works on your vehicle.
You can disable your vehicle by entering the pin code sequence using the car buttons we have programmed. You can also enter the app to disable the system, which makes it more secure.
The Autowatch Ghost is Tassa Verified product that can be recognized by insurance companies, which is crucial for those who are concerned about their cars being stolen. It's also a great alternative for those who don't want be burdened by an expensive fob or complicated device.
If you're considering this security option, call us at MPH to schedule an installation appointment. One of our team members will run you through a thorough demonstration of how the Ghost 2 immobiliser works on your vehicle. They'll also give you owner's manuals, installation certificates and a Ghost 2 emergency card. Before leaving, they'll check that you're happy.
It's easy to set up
A revolutionary immobiliser that works independently of any factory-fitted alarm or tracker. It is activated with a Bluetooth tag that is worn on your body. It doesn't have buttons external to it or wires to cut, and is extremely difficult to bypass and hack. It is also undetectable using the hi-tech diagnostic tools that professional thieves use, as it emits no radio frequency signals.
The Ghost II CAN Immobiliser is a tiny weatherproof device fully integrated and incorporated inside the vehicle harness. It's a completely hidden secure and hidden solution that can be turned off in a specific 'Service Mode that allows you to temporarily open the vehicle for valet parking or servicing without the need to enter your PIN code. This is an excellent feature for people who use their car for work and would like to hand over the keys to valet service.
Once the Ghost is connected to Jaguar's CAN bus system, it is programmed to protect your Jaguar by entering an individual code sequence you set. The vehicle will not start unless the correct sequence is entered first. Even when it is in service mode, your engine won't start when the vehicle is at 30mph speed limit or above it will automatically reactivate.
Ghost is distinct from other immobilisers that rely on keys or LED indicators to provide security. Ghost uses buttons on the steering wheel, door panels and centre console that allow you to design an individual disarming sequence (like a pin code) that has to be entered before your vehicle can start. The sequence of disarming can be changed to include as many as 20 inputs, making it even more secure than a standard factory fitted immobiliser.
The latest generation of stealth immobilisers operates entirely independent of a factory-fitted alarm or tracker and is the most advanced technology to protect vehicles from hacking, key cloning and theft. Ghost connects directly with the car's data bus CAN system, preventing it from being started without the proper sequence of keys being first entered. Modern diagnostic tools aren't able to detect or deactivate it. It can also be used to stop the functioning of other security systems, like jamming and spoofing devices.
It's unrecognizable
autowatch ghost immobiliser cost Ghost 2 is a discrete immobiliser that's not recognized by thieves as it does not use LED indicators or key fobs to operate. Instead, it is connected to the vehicle's CAN data networks and operates through existing buttons on the steering wheel, doors or central console. It is not visible on your vehicle, and can only be activated by entering a specific disarming sequence via an application or Bluetooth tag. The spoofing and jamming devices are often used by thieves to steal the codes from your remote key fob will not have an impact with this innovative device.
The system can be programmed so that it requires up to 20 button presses before your vehicle will start. It is also able to be put into service or valet mode, meaning it will not display the pin code when the engine is off or on.
This is a great option for those who worry about their joy and pride being stolen. Many people consider their vehicle as an important element of their life and want to make sure it is safe. This is especially important especially if you reside in a highly-crime-prone area. Additionally, a good security system can help reduce your insurance premiums.
It is crucial to invest in a high-quality security system because there are a myriad of things to take into account. Luckily, there are a variety of options on the market, including a variety of low-maintenance immobilisers. Some of these even have a three-year warranty which is a great option for anyone who wants to ensure their car is secure.
Installing a Ghost-II is among the most effective ways to increase the security of your vehicle. This unique immobiliser was created specifically for high-end and luxury automobiles and is extremely effective in protecting against theft. It operates in a quiet manner and doesn't transmit radio signals, which means it's unnoticeable by sophisticated thieves who use scanners to hack into your vehicle's ECU. It can even be utilized in conjunction with alarms to provide an extra layer of security against theft.
It's quiet
Autowatch Ghost will take the stress out of securing your vehicle. This new generation device blocks key cloning, hacking and even when your key fob is stolen. Installed in your vehicle's information network CAN, it only allows the engine start after a unique PIN has been entered. It does not need extra key fobs, and works by using the buttons on your steering wheel and central console as well as door panels. It does not use any LED indications so cannot be identified by thieves. This is an insurance approved device (TASSA) and could even reduce your premiums.
It is not detectable by thieves using diagnostic tools because it communicates with the CAN data circuit of the vehicle without a sound and doesn't emit any radio signals. When the user enters their PIN code, it enters service mode. This allows the vehicle to be used for normal driving. It is particularly beneficial when your car immobiliser ghost is undergoing an MOT or is being cleaned. The Ghost will be able to exit the service mode based on speed and duration, so you don't have to enter your PIN code again. You can also change the PIN code at any point.
Additionally to that, the Ghost is secured by a failsafe feature which will block all outputs from the vehicle if it detects any interference, for example, someone trying to use a laptop in order to hack into it or someone trying to steal the car. This is a fantastic security feature that makes the Ghost an ideal option for cars with high-end features.
The Autowatch Ghost is easy to install and simple to operate. The system is accessed through the App on your smartphone, which connects with your Ghost device using Bluetooth within a range of 5-10m. The application is compatible with both Android and iOS devices. It is free to download and simple to use.
The ghost 2 immobiliser problems will disable the outputs of your vehicle when there is interference. This is incredibly useful for high-end modern automobiles. It is a great way to keep your love and joy safe and safe, so why not secure your vehicle now?
