Watch Out: How Ghost Immobiliser Tracker Is Taking Over And What Can We Do About It > 자유게시판
Watch Out: How Ghost Immobiliser Tracker Is Taking Over And What Can W…
작성자 Hollis
댓글 0건 조회 39회 작성일 25-04-04 19:58
310300814_438157535072560_441431797686435441_nlow.jpgAutowatch Ghost Immobiliser Fitter
Car thieves are becoming more sophisticated and smarter, therefore technology has to change to keep up. Autowatch Ghost immobiliser works with the buttons on the steering wheel, centre console and door panels to make a unique pin code sequence which must be entered prior to driving your vehicle.
The device is unnoticeable to thieves, it utilizes CAN data and doesn't have circuit breaks, making it extremely secure and easy to fit system. RCA Cheadle are an approved installer of Ghost immobilisers and a member of TASSA.
No Key Fobs or LED Indications
The Autowatch Ghost is the first aftermarket CAN immobiliser to safeguard your vehicle from key cloning and theft, as well as hacking. It is integrated into the car's CAN data network and is silently operated, so that it is undetectable and cannot be disabled through simple wire cutting.
It creates a unique, variable PIN code sequence (up to 20 presses) by pressing the buttons on your car's door and steering wheel that must be entered before you can drive. This is the same method that you use to access mobile banking or your credit card. You can change it at anytime. You can do this in a matter of seconds with your smartphone and the application you downloaded. Or, if you prefer to use your keyfob.
This is a key aspect of the system that thieves will be unable to break or get rid of as it does not require any additional electronics, like the key fob. The thief cannot guess the code and will have a difficult time finding a way to get around it. It's also unrecognizable by tests since there aren't any radio signals being transmitted and it isn't detected by RF scanning technology that has been used to deceive existing security systems in recent years.
It is also weatherproof and can be connected to the wiring of your vehicle at any point. It does not leave any marks or damage to your vehicle - making it a desirable option for those who value their vehicles and want to improve their security.
The greatest thing about it is that there aren't any signals sent. This means that thieves cannot see if they have cracked the security device, or try to bypass it. It's a great option to protect any car owner, especially since criminals are focusing their attention on the latest cars with their advanced technology.
No Radio Signals
As mentioned, unlike other vehicle security devices that require an ID card or special pin code to turn off the ghost immobiliser, the ghost works silently and does not emit any radio signals. This is due to it connecting directly to the CAN data bus. This means that thieves would be unable to trying to identify its presence in your vehicle. The immobiliser won't start your vehicle unless you enter the correct PIN sequence, which can only be accomplished via a series of buttons pressed in a specific sequence - and it is easily controlled via the application.
This makes it more secure than immobilisers that utilize an active system. In these systems the immobiliser can only shut off the ECU if the key is present with an active signal. These systems can be disabled using a tag or keypad or keypad, by entering a pin code on the keypad or by pressing a particular sequence of buttons. The ghost immobiliser cannot be disabled this way. If your vehicle is stolen or towed away it will not be able to return it until the pin code has been entered.
The ghost immobiliser has also been developed to resist the most sophisticated theft techniques, like cloning. This is because thieves can attempt to duplicate your key fob, or even hack into your vehicle's ECU and override its security. However the CAN immobiliser has been designed to stop this, as it creates a unique pin number each time you want to start your car, which means that it won't be possible to start your vehicle with any cloned key or overriding system.
Additionally, the CAN immobiliser is a great protection against signal boosters, which is used by thieves to overcome the factory-fitted immobilisers. It is therefore one cost of ghost immobiliser the most effective and reliable immobilisers that we install at Progressive Parts. This is why it is insurance-approved and is also a favourite with customers who have to hand over their car for valet parking or another service. It has a 'Service Mode' that permits your car to be driven for a short period without the need for a PIN code This can be handy when you have guests or valet drivers who wish to drive your vehicle.
No Circuit Cuts
Car theft in recent years has become increasingly common with organised thieves using sophisticated diagnostics devices to detect fitted security systems. The Ghost is designed to counter this by avoiding circuit cuts, it is completely unnoticeable by any diagnostics and works silently on the vehicles CAN data circuit. It connects with the vehicle's ECU and it is able to identify a pin code when entered. This must be used to start the engine. This means that thieves cannot just add a new key or replace the ECU in order to steal your vehicle, they will need to enter the correct pin code first.
The system also comes with the option of a service valet mode which will allow your vehicle to start and drive without needing your personal PIN. This is perfect for when you're planning to leave your vehicle with valet or mechanic service. You can switch it off and on as you want to ensure that nobody else will be able start your vehicle, even if you're not there.
Our team of skilled professionals at MotorGuard are the Midlands' leading ghost immobiliser tracker Fitters and can help you find the most secure solution for your vehicle's pride and joy. We can advise you on the best way to protect your vehicle from key cloning, hacking, and even stolen keys, without the need to cut wires.
During our entire Ghost Installation process we provide a full demonstration of the way the device functions and hand over the owner's manual along with the installer's certification and an auto ghost immobiliser emergency card to give you security. We are fully insured and certified to install the Ghost device. We also offer the warranty in case something goes wrong during or following the installation.
The Autowatch Ghost is a discreet next-generation device that is connected to the CAN data network in your vehicle and has a customised PIN code you can set with our team. The code is then entered via buttons on the dashboard and steering wheel to shut off your engine. It's a small weatherproof device that can't be detected by traditional methods. There are no LED indicators, and it's completely concealed during installation and fitting. The Ghost is inaccessible to advanced, high-end RF scanning and code-grabbing technology and Watch is also a fully reversible device that can be installed or removed at any point.
No RF Scanning
An immobiliser standard is designed to prevent your vehicle from being driven when you don't have proper key fob or code to turn it on. It does this by sending an alarm to the ECU, which is then recognised by the engine control unit, and closes down any component in the system that are compromised.
Modern criminals, however, are always trying to keep ahead of car manufacturers. They have modified technology such as key cloning (relay attacks), hacking (relay attacks) as well as key theft. The thieves are often resorted to breaking and entering your home and sifting through your letterbox, taking car keys from your handbag or even from inside your ignition.
The Ghost is the first aftermarket CAN bus immobiliser in the world that guards you against all of these dangers. It works in silence and is not able to transmit radio signals and is not able to be detected by RF scanners. It's TASSA tested and endorsed by insurance companies, so you can be sure that it is safe to use and will not impact your warranty.
Unlike a factory-fitted immobiliser, Ghost II doesn't come with an indicator for status so it is undetectable to any diagnostic tools. It also functions independently of any other immobiliser, alarm or tracker you may have installed so it is an effective, standalone solution that isn't able to be disabled.
It's simple to use and you only need to enter your pin code and your car will be starting. The immobiliser also has the option of a service valet which can be activated by pressing buttons on the steering wheel or door panels. This can be helpful when you have to take your car to the garage or when leaving it with a valet parking company. You can also alter the pin code as many times you'd like, to ensure that your vehicle is always secure. If you're interested in getting an Ghost immobiliser fitted to your vehicle contact us today to find out more information and schedule an appointment at our garage in Liverpool.
