Mastering Chart Patterns in Satta King: A Beginner’s Guide > 자유게시판
작성자 Stephaine
댓글 0건 조회 6회 작성일 25-07-05 06:16
In Satta King, every number that appears is part of a larger pattern. If you're still guessing without understanding how results evolve over time, you're playing blind. The most consistent players don’t guess based on luck — they read chart patterns like a map.
This article will introduce you to the concept of chart reading, common patterns, how to spot them, and how to use them in your strategy to increase your win rate over time.
What Are Chart Patterns in Satta King?
Chart patterns are repeated number behaviors found in past results. These aren’t "tricks" — they’re historical cycles where certain numbers or types of numbers appear with recognizable frequency.
Each market — Gali, Desawar, Faridabad, etc. — has its own rhythm. Learning to read these rhythms gives you an edge.
Why Learn Chart Patterns?
✅ Helps predict upcoming numbers
✅ Increases accuracy of your guesses
✅ Reduces the need for random tips
✅ Helps avoid emotional decisions
✅ Makes your strategy more professional
Basic Terms to Know
Back Number: The reverse of a number (e.g., 43 → 34)
Repeat: When a number shows up again in a short period
Gap: The distance (in results) since a number last appeared
Mirror Number: Based on a mirrored pairing (e.g., 1↔6, 2↔7)
Common Satta King Chart Patterns
Let’s look at the most frequently used and effective chart patterns:
???? 1. Repeat Pattern
Some numbers hit again within 3–4 results. If 28 appeared yesterday in Faridabad, there’s a chance it might repeat in another market or even the same market soon.
What to do: Note down recent hits. If a number appeared within the last 2 days, and logic supports it, consider repeating it.
???? 2. Back Number Pattern
Back numbers are often seen in the following day’s result.
Example:
Desawar: 43
Next day in Gali: 34
What to do: Always check if today’s guess has any back relation to the past 2–3 results.
???? 3. Mirror Pattern
Mirror numbers are number pairs based on visual symmetry or fixed difference. Examples:
1 ↔ 6
2 ↔ 7
3 ↔ 8
4 ↔ 9
5 ↔ 0
Example:
If 61 appears, consider 16 in the next round.
What to do: Use mirror logic if it aligns with other signals.
???? 4. Ending Digit Pattern
Watch for repeated last digits in sequences.
Example:
Gali: 29
Faridabad: 39
Desawar: 59
All end in "9". Ending digits often repeat in 3–4 result clusters.
What to do: Track ending digits across markets.
⏳ 5. Gap Pattern
This involves observing how many days or results it’s been since a number appeared.
What to do: Numbers that haven’t appeared in 10+ results (but used to show frequently) are likely to return.
Use this to identify cold number comebacks.
How to Study Chart Patterns Step-by-Step
???? Step 1: Download or Collect 30 Days of Results
Choose one market first. Faridabad is good for beginners.
???? Step 2: Build a Simple Excel Sheet or Notebook
Make columns like:
Date
Result
Ending digit
Mirror/back number
Notes (e.g., repeated, gap, etc.)
???? Step 3: Mark Patterns
Use colored highlights for:
Repeats (Yellow)
Mirrors (Blue)
Back numbers (Green)
Long gaps (Red)
This visual approach makes trends easier to spot.
???? Step 4: Predict Based on Logic + Pattern
Don’t guess blindly. Use a combo approach:
Today’s Guess = Pattern match + Logic filter
Example:
Ending 9 showed 3 times last 5 days
Mirror logic points to 39
It hasn’t appeared in 7 results
✅ Strong pick: 39
Mistakes to Avoid While Reading Charts
❌ Looking for too many patterns at once
❌ Changing your pattern daily
❌ Ignoring logic in favor of patterns
❌ Guessing just because "something feels right"
❌ Not tracking failed pattern guesses
Use patterns as a guide — not a guarantee.
Real Example: Neha’s Pattern Strategy
Neha focused on Desawar. If you have any sort of inquiries concerning where and how you can utilize SattaKing Record, you could contact us at our own web page. She built a 30-day pattern sheet and noticed:
Mirror hits every 4 days
Ending 4 appeared in 3 out of 5 Mondays
Repeats were frequent on Thursdays
She started guessing only when 2+ patterns matched.
Results in 3 weeks:
Played 10 times
Won 4
Fewer guesses
More clarity
Lower stress
"Once I saw the chart as a pattern, not chaos, everything changed."
