The 12 Best Item Upgrading Accounts To Follow On Twitter > 자유게시판
작성자 Charli
댓글 0건 조회 40회 작성일 25-04-04 16:20
Path of Exile Item Upgrading
In Path of Exile, item upgrading is one of the Best item upgrader ways to improve your gear without relying upon large-ticket drops or trade. This article will show you how to upgrade your gear.
Upgrading equipment grants an increase to the item's base stats. The bonus is based on the rarity and level of the upgrade component.
Components
Upgrade components are the things that make your weapons and armor more effective. You can locate them by destroying enemies, buying them from karma sellers or finding them in the form of item-spheres. You can also get them from equipment that has the components or by using salvage kits of high-end quality, such as Black Lion Salvage Kit and Ascended Salvage Tool. Upgrade components are not destroyed when they are removed from an item upgrader kit.
Upgrade components are typically used to improve an item but they can also be used for other purposes. They can be stacked to increase the level or the amount of experience gained by upgrading weapons or gear. They can also be forged to offer additional benefits. A glyph that is crafted can boost the chance of upgrading its target, and a boost upgrade increases the defense or attack capabilities of weapons.
You can bind an upgrade template to an item by selecting it from the edition GUI. This will display the upgrade components to which the item can be upgraded. Alternately, you can make use of the workbench to choose an upgrade template. In either scenario the item will be upgraded once enough upgrade components are collected.
Each component is assigned an experience multiplier. This determines how much experience an item will gain when upgraded using the component. Organic components, like, have an increased multiplier of experience than mechanical components. It is therefore recommended to upgrade with organic components until you reach the multiplier of experience for the next rank of equipment or weapon, and then move to mechanical upgrades.
In addition to the experience multiplier every item also has the maximum number of upgrades it can receive. The number of items that can be upgraded is determined by their upgradeable rank and the kind of upgrade they can get. For instance, the highest possible upgrade for a weapon is a weapon of tier 10. The most popular weapon upgrade is a tier 6 gun and an armor upgrade of tier 5.
Sets
A set is a collection of items that all share the same bonus. Each item can be upgraded at the least once. The Upgrade item boosts the bonuses that are guaranteed. The first time you upgrade an item, its initial stat will be +1. After subsequent upgrades, the primary stats are boosted even further (for instance +1 for 12+/13+/14+) and every time an item is upgraded one of its stats will increase randomly.
The upgrade of a weapon can increase the damage base, which can be crucial for certain builds. Weapons aren't upgraded to give a higher maximum defence roll than their base. Upgrades can be a great method to increase the value of some set and unique items, however it is important to keep in mind that they might not be more effective than a high-level raneword in any build.
If the item you're upgrading comes with a guaranteed bonus, it can be rerolled once and its guarantee will be reset to zero. The same power die is used to roll an item as it would be used to upgrade it. However, the new item has different bonuses. The NPC [Armor] Boboko can upgrade your armor in Central Flarine. To upgrade an item, you will need the appropriate amount Minerals and Erons, as well as a power dice of each kind. These are available at the crafting table or the Ultra Collector and can be purchased using Gold. NPCs also offer special rewards for each level of the upgrade process. This reward can be rerolled a second time, and the reroll will be made using the same materials used in the original item.
Rerolling
If a player has enough rerolling tokens, they can reroll any item that they've acquired during the game. If an upgraded item is to be rerolled, it will be exchanged for the level 1 version of the same item in a different set. Reroll tokens can be purchased from the store for small amounts of in-game currency. However, they are not refundable. The new item level upgrade will offer the same bonus features like the first, however the stats will be different.
In addition to rerolling items players can also change the identification of any equipment by interfacing with an upgrader NPC. This will change the identification as a weapon to armor, or reverse it. Its base stats and requirements remain the same. The change is permanent and will affect all characters that are wearing the gear.
Players can also boost the item level of any equipped equipment by acquiring upgrade components and interacting with the upgrader NPC of the item. This will cost a set number of crests and Valorstones dependent on the upgrade track and item kind. Each step will give 5percent more damage to weapons.
An upgrade can boost its power however it can reduce its effectiveness. It is therefore essential to find a balance between the two. Certain items aren't worth upgrading, while others require upgrading to make them more effective. For instance, a player might wish to upgrade a piece breakpoint armor that has an interesting modifier (% chance to block or FHR) to explore the possibilities of what it can be.
The main reason people are able to reroll in Genshin Impact, or in any gacha-based game, is that they're trying to get a specific weapon or character that they wouldn't otherwise be able to acquire. Getting these items can be expensive and time-consuming and the RNG gods do not always want to cooperate. The only options left are to invest real money or grind lots. Rerolling is extremely popular in Genshin Impact.
Leveling
You can select whether to upgrade the weapon or armor when you upgrade an item. This feature is not available in the current version of the game. I believe it was intended to to add value to rare items, but as equipment generally drops quickly and can only be upgraded once you've reached a certain level, you'll usually replace the item before it gets too old. It's also not worthwhile to upgrade items with gem sockets because the power of the gem will far outweigh the higher ilvl that comes with the upgrade.
You will see a small window when you click the upgrade item option on an item. It will display the template of the item, the Crest, as well as the Valorstone cost to raise the item's level. The cost of upgrades will vary based on the armor and weapons as well, with the former typically costing more than the latter. The upgrade template outlines the stats that will be added to the upgraded item. It it also lists the current ilvl.
The Crest and Valorstone costs are calculated by analyzing the current ilvl of the item and the upgrade template. The ilvl will also be decreased by the upgrade templates reduction percentage of lvl. For instance the weapon that has an increase of 8% will decrease its ilvl by 8 - 8 percent.
The item will receive upgrades to other stats, like critical strike damage, PvE damages and block, parry, and dodge rating in addition to the base ilvl. These upgrades are also based on the upgrade template.
In the upgrade template, you can check the amount of damage or defense that the item will receive after it is leveled up. This is listed below the cost and the upgrade percentages. All armor and weapons, except practice equipment, get these stats when they level up. The market will determine the value of these stats. A weapon or armor with perfect rolls can fetch more than an unupp'd version. This is also true for other armor pieces such as circlets or Tiaras.
