Keep Your Status Private on Telegram
To hide your "Last Seen" status on Telegram, 电报 下载 you need to follow these simple steps:
First, open the Telegram app and go to the Settings menu. You can find the Settings icon at the top-center corner of the screen, shown as a gear symbol.
Once you are in the Settings menu, you need to select the 'Privacy and Security' option from the list.
After selecting 'Privacy and Security,' move to the bottom of the list to the 'Last Seen' section and you will see a toggle switch next to it.
Now, you can toggle the switch to the left to turn off the 'Last Seen' status. When you do this, your contacts will no longer be able to access your last seen status.
It's worth noting that by hiding your 'Last Seen' status, you will not be able to access the 'Last Seen' status of your contacts as well. This means that hiding the 'Last Seen' status is a two-way process - both you and your contacts will no longer know this information.
If you want to see who has disabled their 'Last Seen' status, you can check the list in the Settings menu. This list will display the names of all your contacts whose 'Last Seen' status is hidden.
By following these easy steps, you can keep your 'Last Seen' status on Telegram and maintain your online privacy. However, remember that hiding your 'Last Seen' status is not a 100% guaranteed method to keep your online activity private, as your device usage can still expose information about your online habits.
- 이전글Все секреты бонусов интернет-казино onion casino: что нужно знать о казино 25.06.12
- 다음글Causes Why You Ought To Consume Healthy Meals 25.06.12
