Erase Storage Data > 자유게시판
Erase Storage Data
작성자 Berniece Sturgi…
댓글 0건 조회 5회 작성일 25-06-12 11:29
Using Telegram can be a convenient way to network with others. As time passes, data accumulation can start to take up valuable space your phone, which can eventually cause issues with storage.
The following steps will be covered below.
When you use Telegram, it stores data locally on your device to keep everything organized. This data is stored in a cache. However, the cache can become outdated and cause storage issues.
Here's how to erase cache, here are the instructions:
  1. Open Settings on your device.
  2. Scroll down and select the Apps or Application Manager option.
  3. Find the Telegram app.
  4. Click on the Storage option and then click on the Clear Cache button.
  5. Confirm that you want to clear the cache.
By clearing the cache, you will be able to free up additional storage on your device.
Stored data is another issue.
Erase data in Telegram is a simple way to reduce storage usage, but it may not be enough if you have accumulated a large amount of stored data. Stored data in Telegram contains various types of media that you have received or uploaded. To delete files and media, follow these steps:
  1. Open the Telegram app.
  2. Click on the three horizontal lines.
  3. Select the Settings option.
  4. Click on the Storage option.
  5. Click on the Auto Download setting.
  6. Click on the Media option.
  7. Click on the Delete Files and Media option option.
  8. Confirm that you want to delete the files and media.
Please note that deleting stored data in Telegram will also log you out of your account on the affected phone, so make sure to re-login after clearing.
Clearing cache and stored data in Telegram is important because it ensures that your device runs smoothly when your device's storage is full. When cache and data storage become too large, it can cause issues such as:
Slow app performance
Storage issues
App installation problems
Reduced battery life
By preventing data accumulation, you can help prevent these issues.
Conclusion
Clearing the cache and stored data in Telegram is a simple yet effective way to free up space on your device. By following the steps outlined in this article, you can quickly and easily clear unnecessary space in Telegram and keep your device running smoothly. Don't forget to erase data in other apps as well to maximize your device's potential.
