Guide To Item Upgrades: The Intermediate Guide To Item Upgrades > 자유게시판
작성자 Booker Lohman
댓글 0건 조회 25회 작성일 25-04-04 12:23
Path of Exile Item upgrade Upgrades
Item upgrades are a common and essential way to boost the performance of a variety of items in Path of Exile. They can cause additional damage, AD or even affixes.
Rare-grade equipment is usually superior to modernized Common or Magic gear due to their high demands.
Armor
Armor upgrades are a type of upgrade that can be used on armor and weapon items. They improve the effectiveness of the item they are connected to. Armor upgrades can be found in the world of games and are available from Blacksmiths on bonfires. They can also be salvaged by using a specialist or higher salvage kits to retrieve upgrades from the items.
The level of an armor's or weapon's upgrade determines the amount of damage it is able to absorb. The upgrade of an armor piece to its highest upgrade level will increase its ability to absorb damage. It is important to note that this will increase the weight of the armor, so it must be more heavy.
There are a variety of armor upgrade available in the game. Each one has a distinct effect. For instance, some upgrades will grant the armor a certain amount of health points while others make it stronger and lighter. The type of armor upgrade that an item level upgrade can receive is indicated by the name of the upgrade as indicated in the table below.
Some of the upgrades also require magic or a combination of technology and magic, which is shown by the "Magic" and "Hybrids" entries in the table. Certain upgrades require charges in order to be used. They are referred to as "Charges" entries in the table. These charges are either constantly updated or never expire based on the upgrade.
Iron Ore is the cheapest option to upgrade your armor. You can locate it by exploring and looting small treasure chests. Titanium is more expensive but is readily available at the smelters of Orgrimmar and Stormwind City. Certain upgrades, such as the Reforge or the Hot Potato Books can only be applied to armor pieces that are of high-level. These upgrades can give significant improvement in performance and are worth the cost, especially for single-handed weapons.
The player must be aware, however, that upgrading a piece to its maximum upgrade level will boost its defense. However, it can also decrease its agility and its speed. Therefore, it is not recommended to upgrade armor pieces beyond +9, since the defensive boost gained is usually not worth the weight and power costs of the upgrades needed.
Weapons
Weapon upgrades allow players to improve the effectiveness of specific aspects of an weapon. For example, an upgrade may improve the damage that is caused by a shotgun's shells or the accuracy of a rifle sniper. Certain weapons also come with enhancements that enhance their intrinsic capabilities. Frictionless materials (improves stability, reduces the risk of the possibility of overheating), and Kinetic coils (increases the projectile's speed to cause more damage) are two examples.
Most weapon upgrades require one of three Power Dices, a different amount of Minerals and Erons and a whetblade to apply. They can be obtained by completing Side Quests or by killing a certain number of monsters and bosses.
To upgrade the weapon, equipment set piece, or Whetblade You must go to the NPC [ArmorBoboko. Boboko located in Central Flarine, and pay her an upgrade fee of a certain amount of Bars. The more bars needed to complete an upgrade items the more advanced the level. The cost of upgrades will be lower if have more than one of the relevant upgrade materials.
In Chapter 2: Season 5, the ways to upgrade your equipment and weapon sets changed a little. Prior to Chapter 2: Season 5 you could upgrade your weapon or equipment by paying a specific number of Bars. You could do this until you reached a max upgrade level of the equipment or weapon, following which upgrades would reset.
You can still do this, but the process is based on RNG and low on agency. It is better to purchase gear with minimal upgrade levels and high base scores and stat distributions. These items have a higher chance of giving you the highest tier benefits and blessings.
To increase their level quicker, players usually be more inclined to upgrade their weapons. In addition to these players, they should think about upgrading the weapons favored by their teammates to make them more powerful as well. For instance, Shepard should consider upgrading the M92F to unlock the Beretta M93R to increase its utility when paired with biotic specialists like Grunt and Tali.
Jewels
Jewels can be used to boost a stat or provide secondary effects in weapons and armor. They can be made through an process known as jewelry crafting, which is where you combine a gemstone and several ingredients at a table for jewelry. The higher the level of the jewel the better the secondary effect. These reagents can be gotten from Treasure Goblins and World Bosses all over the world, or through collecting Legendary Gear. You can also buy them from The Jeweler for gold and a Scattered Prism.
The Jeweler can enhance the quality of gemstones in stages ranging from Crude up to Royal. The stat boosts will vary depending on the level the jewel is in when it's inserted into jewelry, weapons or equipment.
The Jeweler is able to create all tiers of gems, except for the rare and legendary ones which require certain levels to gain. Like other upgrade components jewels can be swapped out with a identical jewel without destroying the original one. However, you can only replace a jewel in an equipment piece once.
Utilizing more jewels in a movement can make it feel more comfortable and is usually performed to enhance the aesthetics of the movement. In addition to improving performance, the jewels create a surface that is harder than steel, so the repeated friction from pivots doesn't damage them as easily.
In addition to the upgrades mentioned above additionally, players can acquire glyphs for their shields and weapons from a Glyphmaster. These provide a small bonus and can be swapped freely however they aren't guaranteed to drop as loot. Glyphs can be upgraded, as jewelry, by visiting the Jeweler for gold and scattered Crystal. Glyphs can also be removed and returned to the inventory. Other upgrade components like aegis or traits cannot be swapped, and can only be retrieved by using an upgrade items extractor or salvaging using the Black Lion Salvage Kit, or Ascended Salvage.
Trinkets
Trinkets can provide your hero with a variety of small, but useful, benefits. You can find them in the starting area as rewards for personal stories or loot. They can also be obtained through vendors and after completing road interaction. They can also be crafted by jewelers and later found or purchased at the Trading Post.
The first trinket players will be able to unlock is the cloak. It provides a tiny but valuable boost in movement speed and the ability to escape. The player will then be able to acquire necklaces, amulets, and rings, in a similar way to how they acquired weapons and armor. Each piece of equipment has a slot for an upgrade that is either universal or jewel. Universal upgrades offer smaller bonuses and can be put into any type of equipment while jewelry cannot be changed or upgraded, and only works with certain kinds of trinkets.
These trinkets also grant additional buffs and skills that are active whenever the hero is not fighting. This enables the hero to be more effective while inactive and may also help to compensate for the absence of a solid team or the absence of any slots from the talent tree that normally are filled with the hero's ideal stats.
A good general rule of thumb for trinket upgrades is to prioritize BiS (Best-in-Slot) items that you won't be replacing soon, followed by any items with desirable stats, but less important than the iLevel of the item being upgraded. This is especially true when you want to upgrade multiple statistics on an item upgrading. It is more beneficial to upgrade a single important stat than two less important ones.
In the beginning of the game, junglers will usually want to upgrade their yellow trinket to a red, while top and middle players will usually opt for either a pink or green ward (depending on the game's matchup). These choices will have a major impact on the hero's map control abilities.
In addition to the items listed above, players will also find other trinkets that form of rewards and trophies throughout the game. These can be earned by completing certain milestones within the story. For example, completing the main quest of a chapter or beating the boss. You can see them by clicking on the achievement in the reward section of the hero's menu.
