Twilight Blend Live Resin Disposable Vape Purple Punch 3 grams > 자유게시판
작성자 Eduardo
댓글 0건 조회 4회 작성일 25-05-29 05:53
$34.99
1138 in stock
Reach a whole new dimension of tranquility. With aromatic notes of grape candy and blueberry muffins.
TOTAL TWILIGHT BLEND THC: 2285MG
INGREDIENTS
THC Twilight Blend: (THCP) Tetrahydrocannabiphorol / (D8) Delta-8 tetrahydrocannabinol / (CBN) Cannabinol, Live Resin, Plant-Derived Terpenes. THC Twilight Blend Total: 2285 Mg.
INSTRUCTIONS
Click button 5 times to turn on/off.
SUGGESTED USE
Take 1-2 small puffs not exceeding 3 seconds.
All users may not react the same to product use.
The onset of effects may be experienced at different times.
First time users may experience stronger effects. DO NOT EXCEED SUGGESTED USE.
STORAGE
Store at room (or cool) temperature and away from sunlight. Try to store upright to prevent leaking.
CAUTION
KEEP OUT OF REACH OF CHILDREN. THIS what is the cost of cbd oil A HEMP-DERIVED PRODUCT. NOT INTENDED FOR INGESTION – DO NOT EAT. This product is intended for use by healthy adults age 21 years & older. Consult a healthcare professional prior to use of THC Twilight Blend: (THCP) Tetrahydrocannabiphorol / (D8) Delta-8 tetrahydrocannabinol / (CBN) Cannabinol. THC Twilight Blend may be harmful if you are pregnant, nursing, taking any medication or have a medical condition. Discontinue use immediately if adverse reaction occurs and consult your physician. The FDA has not evaluated this product for safety or efficacy. As required by Florida state law, THC Twilight Blend potency is verified by an independent third party lab. The results of the independent third party lab tests are available to you on our website and by scanning the QR code on the package. There is no current standardized methodology for verifying THC Twilight Blend content therefore test results may vary by individual laboratory and/or test method. This product contains less than 0.3% total delta-9 tetrahydrocannabinol (Delta-9 THC). Drug tests vary in sensitivity, and you may test positive for Delta-9 THC when taking THC Twilight Blend products. Over time color variations may occur in this product. The amount (mg) of THC Twilight Blend may vary by dose and by packaging. If THC Twilight Blend is used beyond the expiration date, potency may decrease. May cause drowsiness. Do not drive or operate heavy machinery while taking THC Twilight Blend. THC Twilight Blend has pure concentrated cannabinoids which can be harsh on the throat if misused. Inexperienced consumers new to concentrated vape products may encounter throat discomfort if the product is inhaled in excess.
Description
Hold onto your hats, intergalactic adventurers! Prepare to have your minds blown by the HAZE Twilight Blend, a fantastic fusion of THCP, Delta 8, and CBN in a 3-gram rechargeable disposable vape. Revel in the flavorful escapades of Purple Punch as you embark on a wild ride through the cosmos.
Crafted in the secret labs of an alternate reality, this one-of-a-kind vape boasts a combination of potent compounds, expertly designed to elevate your terrestrial experiences to new dimensions. The HAZE Twilight Blend is the ultimate travel companion for the daring explorers and time-traveling renegades seeking to venture beyond the mundane.
So buckle up and get ready to vape away as you journey through a universe of boundless excitement, pulsating with the hypnotic taste of Purple Punch, an interstellar delight that will leave your taste buds yearning for more.
FAQ
The Twilight Blend Purple Punch vape is a potent combination of THCP, and D8, with added CBN for a relaxing and soothing effect. This indica-dominant blend provides a full-body experience, perfect for unwinding after a long day.
The Twilight Blend Purple Punch vape offers a deliciously fruity and sweet flavor profile, reminiscent of grape candy, blueberries, and a hint of tartness. This tasty blend is sure to please both new and experienced users alike.
Yes, the Twilight Blend Purple Punch vape is ideal for users seeking relief from pain, stress, and anxiety. The combination of cannabinoids and terpenes in this blend work together to provide a soothing and calming effect, making it perfect for nighttime use or moments of relaxation.
RELATED PRODUCTS
Meditation Blend Live Resin Disposable Vape Hawaiian Haze – 3 grams
Fantasy Blend Live Resin Disposable Vape Gelato – 3 grams
Surreal Blend Live Resin Disposable Vape Cotton Candy 3 grams
Haze Brain Stew Delta 9 Gummies – Hybrid
Brain Stew THCA Disposable Vape Hybrid – 3 grams
Hypnotic Blend Live Resin Disposable Vape Runtz – 3 grams
Haze Midnight Blend Gummies – Indica
25 First Ave. SW STE A
Watertown, SD 57201
Products on this site contain a value of 0.3% or less Δ9THC (or no more than 0.3% Δ9THC). FDA Disclosure: This product is not for use by or sale to persons under the age of 21 depending on the laws of your governing state or territory. This product should be used only as directed on the label. It should not be used if you are pregnant or nursing. Consult with a physician before use, especially if you have a medical condition or use prescription medications. A doctor's advice should be sought before using any of these products. All trademarks and copyrights are property of their respective owners and are not affiliated with nor do they endorse this product. These statements have not been evaluated by the FDA. These products are not intended to diagnose, treat, cure or prevent any disease. By using this site you agree to follow the Privacy Policy and all Terms & Conditions printed on this site. Void Where Prohibited By Law.
Autoship powered by qpilot.svg
