5 Built In Microwave Over Oven Projects For Every Budget
Benefits of a Built in Microwave Over Oven
A microwave oven that has a built-in microwave lets you cook and reheat your food quickly and conveniently. GE offers a variety of styles, cooking technologies and control options that will fit your kitchen's needs.
Built-in microwaves are positioned behind cabinets or in wall recess to give them a sleek and integrated microwave combi oven look. These types of microwaves require professional installation.
Space Saver
The microwave is among the most frequently used kitchen appliances however, it can consume valuable counter space. There are a variety of clever ways to make the most of your countertop space by moving your microwave to an alternative place, such as a kitchen island or recessing it into the wall.
One of the most well-known options is an over-the-range (OTR) microwave. This model, which is neatly tucked away above your stovetop can be extremely useful in kitchens with a small space. Furthermore, some OTR models can double as a vent hood for your cooktop, which can be beneficial in reducing the buildup of steam.
Another space-saving solution is to install a microwave with a built-in design which blends seamlessly into your cabinetry. This can give you an elegant, seamless appearance that will match your kitchen's cabinets and fixtures in terms of color, finish or design. It can also create a more streamlined look in your kitchen. This is great for homeowners who prefer an uncluttered, clean appearance.
However installing a microwave built-in may require professional installation or a renovation of your kitchen. You may be able depending on the layout of your home to make a hole in a wall for the appliance. However it will require professional framing and reinforcement. built In combi microwave oven and grill-in microwaves also need adequate ventilation to avoid overheating and damaging the appliance. According to Sam Cipiti of R. M. Tunis Kitchens and Baths in Chevy Chase, Maryland the minimum cabinet depth for an oven with built in double oven and microwave-ins is 15 inches. However some manufacturers offer trim kits that provide up to 1 1/2 inch of additional space for ventilation.
A third option to reduce space is a drawer-style microwave that can be set up beneath your countertop or within an island. This design is easily accessible, suitable for all and requires less counter space. It also helps prevent hot dishes or containers from falling off the edge of the microwave or getting damaged by a fall.
The door design is the final factor to consider when choosing a space-saving microwavable. Many brands offer an open, swing-out or slide-out door that opens in the same motion as other kitchen appliances to help you seamlessly integrate your microwave into your cooking process. Certain models feature a smooth, sleek exterior that resists fingerprints to give better and cleaner appearance.
Convenience
Built-in microwaves over ovens are stylish, convenient, and easy to clean. Contrary to countertop models, they're typically placed at eye level to make it easier to access and can be equipped with turntables that reduce the need to constantly shift food from plate to plate. Built-in microwaves are typically equipped with features that enhance their utility, for instance EasyConvection technology that converts ovens and a broiler component that can crisp or brown food items.
A built-in microwave that is integrated into the oven can save you counter space and also increase the value of your home by giving it a sleek, high-end appearance that other appliances may not be able match. If it's installed above the stove or in a separate cabinet, these microwaves blend seamlessly into your kitchen, creating a tailored appearance that shows you've put in the time to improve your kitchen and your home.
Built-in microwaves and ovens are available in a variety of sizes power levels, styles, and features that can be tailored to fit any kitchen. Install them under the counter in drawers to create a more integrated appearance that is a perfect fit within existing cabinets. It doesn't require any additional space. Designed with premium finishes and top-of-the-line features, these microwaves are sure to complement the style of your kitchen and elevate your cooking and entertaining experience.
While the benefits of a white built in microwave oven-in microwave over oven is clear however, you should be aware that these microwaves aren't as flexible as their freestanding counterparts. It might require more space for your microwave to function, based on where it is installed. In addition, they're not as portable and Built In Combi Microwave Oven And Grill you won't have the ability to easily swap the model to a new one if you decide that you'd like a different model.
If you place your microwave above the range, you'll need an extra kitchen space to accommodate the ventilation system that is required by this arrangement. You'll need a ducting option that directs smoke to the outside, or a ventilator that recirculates air from the microwave into the house. For smaller kitchens, consider an additional built-in microwave which can be fitted in the wall, cabinet or island.
Convenient Controls
Microwaves offer a wide variety of controls based on the model. The most common features are turntables, preset functions such as defrosting and reheating and plus-30-second buttons. Some models have safety features for children that stop accidental use of the appliance.
Many microwaves come with pre-programmed recipes and cooking times to help you prepare meals more efficient and less time-consuming. This feature is useful for those who are just beginning to cook and are uncertain of the proper time to heat specific foods or who aren't familiar with the specific cooking methods used in different cuisines.
KitchenAid offers a range of built-in microwaves as well as over-the-range microwaves designed to match your other appliances with style and design to create seamless appearance. There's a variety of stainless steel models as well as black and white built in microwave oven finishes to match the style of your kitchen. These premium microwaves are boldly designed to bring professional-inspired styles into your home, and they're made with high-quality materials for a longer lifespan.
Unlike models for countertop use built-in microwaves are inserted inside a fixed area of the kitchen cabinets or walls for a sleek, custom appearance. They typically have the same components inside as countertop models, with some exceptions. They are available in various sizes, including those designed to fit into a small space, and their exteriors may include a door that opens either in a right-to-left swing-out or drop-down style.
Certain microwaves that are over the range, such as those manufactured by Whirlpool(r) are able to be used as vent hoods. They come with an exhaust system best built in combi microwave-in to vent fumes outdoors and recirculate the air. Certain microwaves have a charcoal filter that removes odors and moisture in your kitchen.
Countertop models sit on your kitchen counter and do not require venting hookups, or any special installation making them an excellent choice for rental homes or those who want to avoid costly modifications to their kitchens. Certain models include trim kits that can close the gap between your microwave and other countertop appliances such as coffee makers bread makers, toaster ovens or bread ovens.
Energy Efficiency
Microwaves consume less energy to heat food and water than other cooking methods. They also use less energy than stovetop ovens since they focus the microwave's energy on the liquid in the instead of heating the air or other elements around it. This means that they can heat food much faster than conventional ovens. They can be installed either on the upper or lower cabinets, and are available in modern or retro styles to suit any kitchen.
In this supplemental notice of proposed rulemaking ("SNOPR") The Office of Energy Efficiency and Renewable Energy (DOE) proposes new or revised energy conservation standards for microwave ovens that help consumers save money on their operating costs. The Energy Policy and Conservation Act (EPCA) requires DOE to periodically assess whether stricter standards are technically feasible and economically justifiable, and if they will result in significant energy saving.
This SNOPR includes the analyses and findings that DOE performed to evaluate the effects on consumers of the new or revised energy conservation standards for microwave ovens. The analysis includes a market and technology assessment, a screening analysis, an engineering analysis and national impacts analysis.
The energy use analysis estimates the annual average microwave ovens operating hours in the sample of households. This analysis is used to calculate energy savings and other consumer analyses within this SNOPR. The analysis is based on RECS field data gathered from various regions. It also considers different microwave oven usage patterns in different households as well as regional variations in electricity prices.
To assess the impact of potential new or modified standards on the cost of operating a household, DOE conducted LCC and PBP analyses to estimate the lifetime cost of purchasing and using microwave ovens at different efficiency levels. The LCC and PBP calculations are made using the computer model that utilizes the Monte Carlo simulation to incorporate uncertainty and variability into the analysis.
In addition to the analyses of energy use and LCC/PBP in this SNOPR contains an evaluation of the national impacts of amended or new standards using the NIA spreadsheet model. The NIA model calculates the industry's net present value ("INPV") in terms of energy savings from the potential amendment or new standards in terms of site energy savings and FFC energy savings.
Space Saver
Convenience
Convenient Controls
Energy Efficiency
- 이전글10 Things That Your Family Taught You About Upvc Window Repair Near Me 25.05.21
- 다음글You'll Never Guess This Best Budget Robot Vacuum's Secrets 25.05.21
