It Is The History Of Built In Microwave Over Oven In 10 Milestones
Benefits of a built in microwave oven combo in Microwave Over Oven
A microwave oven with integrated microwave lets you cook and heat your food quickly and easily. GE offers a variety of styles, cooking technologies and control options that will fit your kitchen's setup.
Countertop microwaves are placed on the counter and plug into an outlet and built-in models are installed in a recessed wall or between cabinets for a sleek, best built in microwave-in look. These models require professional installation.
Space Saver
The microwave is a popular appliance in the kitchen, however it can also take up valuable countertop space. There are plenty of smart ways to make the most of your counter space by moving the microwave to a different place, like an island in the kitchen or recessing it into the wall.
One of the most sought-after options is an over-the-range (OTR) microwave. This type of microwave is tucked behind your stove, can be particularly useful in small kitchens with limited space. Certain OTR models can also function as an air vent for your cooktop. This can help to reduce the buildup of steam.
Installing a microwave integrated into your cabinetry will save you space. This option provides an elegant, seamless appearance that can match your kitchen's cabinets and fixtures in finish, color or design. It can also help create a cleaner appearance in your kitchen, which is ideal for homeowners who want minimalist and clear design.
However installing a built-in microwave may require a professional installation or remodel of your kitchen. Depending on your home's layout you may be able to cut a space in an existing wall to accommodate the appliance, but this requires the proper framing and reinforcement, which should be left to experts. Also, built-in microwaves require adequate ventilation to avoid overheating and damaging the appliance. According to Sam Cipiti of R. M. Tunis Kitchens and Baths, in Chevy Chase, Maryland the minimum cabinet depth for an oven with built-ins is 15 inches. However, some manufacturers offer trim kits with up to 1 1/2 inches of extra space for ventilation.
A microwave with a drawer design can be placed under your counter or inside an island. It is accessible and suitable for everyone and requires less counter space. It also helps prevent hot dishes or containers from falling off the edge of the microwave or getting damaged by a fall.
The design of the door is a final consideration when choosing a compact microwave. There are many brands that have a door that opens the same way as other kitchen appliances, like a slide-out or drop-down. This allows you to integrate your microwave seamlessly into your cooking workflow. Some models also feature a sleek and smooth exterior that wards off fingerprints for Integrated microwave a cleaner, more attractive appearance.
Convenience
Built-in microwaves over ovens are attractive, convenient, and easy to clean. In contrast to countertop models they're usually placed at the eye level for easy access and are often equipped with turntables that reduce the necessity of constantly shifting food from plate to plate. Additionally, built-in microwaves usually have options that improve functionality, such as EasyConvection oven conversion technology and broiling elements that allow you to brown or crisp foods.
In addition to saving counter space, a built-in microwave over oven can also boost your home's value and appeal by giving it a premium appearance that other appliances might not be in a position to match. The microwaves can be placed either above your stove, or in a separate cupboard. They blend seamlessly into the kitchen, giving an elegant appearance that demonstrates how much you've invested in your kitchen and home.
Built-in microwaves and ovens are available in various sizes, power levels, and features that can be adapted to suit any kitchen. Install them under the counter in drawer style to give an integrated look that can be easily integrated into existing cabinets. It doesn't require any additional space. These microwaves, with their premium features and finishes can enhance the appearance of your kitchen as well as your dining and cooking experiences.
Although the built-in microwave over ovens are convenient but they aren't as flexible as microwaves that stand alone. It might require more space for your microwave to function, based on the location it's installed. They are also not as portable, and you can't easily change the model if you want something else.
If you decide to place the microwave on top of your range, then you will need a larger space in your kitchen to accommodate the ventilation required by this arrangement. You'll need a ducting option that directs smoke to the outside or a ventilation system that recirculates air from the microwave into the home. For smaller kitchens you might want to consider an additional built-in microwave that can be installed into the wall, cabinet or island.
Convenient Controls
Microwave ovens come with various controls that are convenient depending on the model you choose. Common features include turntables, preset functions such as defrosting and reheating, and plus-30-second buttons. Certain models include child safety features to prevent accidental operation.
Many microwaves have pre-programmed recipes and cooking times, which make the process of cooking food quicker and more efficient. This feature is beneficial for cooks who are new to cooking and not sure of the time needed to heat specific foods or who aren't familiar with the specific cooking methods that are used in different cuisines.
KitchenAid offers a variety of built-in microwaves as well as over-the-range microwaves designed to match your other appliances in design and finish to create seamless appearance. Choose from stainless steel and black finishes that are perfect for any kitchen. These premium microwaves are boldly designed to bring professional-inspired styles into your home, and they're made with high-quality materials for a longer lifespan.
Built-in microwaves, in contrast to countertop models, are set in a fixed area of your walls or cabinets for sleek and distinctive appearance. The internal components are typically similar to conventional countertop models, with the exception of. These models come in different sizes, and some are designed to fit in small built in microwave oven spaces. The exteriors of these models may feature doors that open in a swing-out style from right to left or a drop-down fashion.
Some microwaves that are over-the-range like those made by Whirlpool(r) are able to serve as vent hoods for your kitchen stove. They have a built-in exhaust system to let fumes out and circulate air. Some models come with a charcoal filter to eliminate odors and moisture from your kitchen.
Countertop models are placed on the kitchen counter. They don't need venting or a special installation. This makes them an ideal choice for those who rent their homes or stay clear of costly modifications to their kitchens. Certain models include trim kits that can be used to close the gap between the microwave and other countertop appliances, such as coffee pots, toaster ovens or bread makers.
Energy Efficiency
Microwaves are more efficient at heating water and food compared to other cooking methods. They also consume less energy than stovetop ovens since they focus the microwave's energy on the liquid inside, rather than on heating the air or other elements surrounding it. Because of this, they can heat dishes much faster than conventional ovens. They can be installed in your lower or upper cabinets, and are available with retro or modern style to fit any kitchen design.
In this supplemental notification of proposed rulemaking ("SNOPR") the Office of Energy Efficiency and Renewable Energy proposes new or modified energy conservation standards for micro-wave ovens which will help consumers save money on operating costs. The Energy Policy and Conservation Act (EPCA) requires DOE to evaluate on a regular basis whether stricter standards are technically feasible and economically justifiable, and if they will result in significant energy saving.
This SNOPR provides the analysis and findings that DOE carried out to assess the impact on consumers of new or revised energy conservation standards for microwave ovens. The analysis includes a technology and market assessment as well as a screening analysis, an engineering analysis and national impacts analysis.
The energy use analysis estimates the average annual microwave oven operating hours in households from a representative sample. This analysis is used to calculate energy savings and other consumer analyses within this SNOPR. The analysis is based upon RECS field data gathered from a variety of regions. It also takes into consideration different microwave oven usage patterns in different households as well as regional variations in electricity prices.
To evaluate the impact of changes or new standards on household operating costs, DOE conducted LCC and PBP analyses to estimate the lifetime cost of purchasing and using microwave ovens at different efficiency levels. The LCC and PBP calculations utilize an algorithm that is based on Monte Carlo simulations to incorporate variations and uncertainty into the analysis.
This SNOPR includes an assessment of the impact of the new or amended standards at the national level based on the NIA spreadsheet. The NIA model calculates the industry's net present value ("INPV") in terms of energy savings resulting from the potential amendment or new standards in terms of energy savings at the site and FFC energy savings.
Space Saver
Convenience
Convenient Controls
Energy Efficiency
- 이전글Best Kids Bunkbeds: The Good, The Bad, And The Ugly 25.05.21
- 다음글One Off Psychiatric Assessment Techniques To Simplify Your Daily Lifethe One One Off Psychiatric Assessment Trick That Everyone Should Know 25.05.21
