See What Best Places To Buy Bunk Beds Tricks The Celebs Are Utilizing
The Best Places to Buy Bunk Beds
Bunk beds are a great option for rooms for children and are available in a wide range of styles. You can find triple bunks or futon bunks in small spaces, as well as the traditional twin-over-twin design.
Take into consideration the weight capacity when choosing a bunk bed. Most bunk beds are designed with an upper limit of 400 pounds per mattress. However there are some options that have higher weight limits for older children and teenagers.
1. Amazon
Bunk beds are a great option for parents who want to make space in a bedroom that is small or kids bunk beds wanting to add a fun element to their room. There are a variety of options available, from twin-over-twin to full-over-full designs. Some even have the excitement of slide. You could consider the twin over twin option with guard rails for children under six years old or even bunk beds for toddlers.
You'll want to think about whether you require storage or if durability and safety are important. Nikki Njeri Klugh is the chief designer and founder of Nikki Klugh Design Group Inc. She says that durability is what you should be looking for when selecting a bunk bed. She says the structure should be constructed of metal or wood and be sturdy enough to hold a full-size bed.
When considering a bunk bed, it's also important to note the size of your space and how tall you'd like the upper bed to be. If you have low-ceilinged rooms pick the loft bed that's closer to the ground, or one that has stairs instead of a ladder. Dr. Mehrin Ahmed, a pediatric emergency doctor at Weill Cornell Medicine/New York-Presbyterian suggests that the top bunk has side rails so the person sleeping there won't fall.
If you're searching for a low-cost bunk bed, consider this option from IKEA It comes with a simple frame and a ladder that is positioned on either side of the bed. It also is compliant with CPSC and safety standards of the industry. You can also upgrade to a larger model for a cost that sleeps two and comes with built-in drawers for storage under the bed.
2. Target
Lofts and bunk beds are excellent ways to make space in children's rooms. They can also make the space more enjoyable. You can find a variety of designs of finishes, designs and configurations at Target. Look for options that offer storage, shelving or other features, in addition to sleeping spaces. You can also find options that can accommodate the twin trundle bed beneath, ideal for sleepovers.
Target offers twin-overtwin bunk beds, as well as a full-overfull option for larger rooms. No matter what size you choose it's important to think about your ceiling's height. Dr. Colleen K. Kraft Pediatric emergency medicine specialist at Weill Cornell Medicine/New York-Presbyterian recommends that you make sure that the bunks are able to fit in your space, and there's enough space to safely climb up and down. If you have a ceiling that is low you might want to choose a model that is specifically designed for this kind of space.
Another aspect to be considered when looking for a loft or bunk bed is the weight limit for the upper bunk. The Daxter bunk beds from Pottery Barn Kids, for example, are rated for up to 165 pounds of weight per bed, which is lower than some other brands. The Oeuf Perch bunk bed, for instance is constructed of Forest Stewardship Council (FSC) sustainable Baltic birch plywood and eco-friendly medium-density fiberboard and has a weight limit of 250 pounds on the top bunk, which is greater than other options.
Wood or metal can be used to construct loft beds and bunk beds. Steel beds tend to be more durable, however they may feel more cold and snarlier than wood options. Some bunk beds made of wood are GreenGuard Gold certified.
3. Wayfair
Sturdy, versatile, and stylish bunk beds offer a space-saving sleep option for both adults and children alike. From traditional twin-over-twin beds to lofts of a full size that incorporate the lower bed in an L-shaped design, countless options are available. Some have extra features like storage or a sofa bed under (like the Crate & Barrel Babyletto White & Washed Wood Kids Bunk Bed).
While deciding on what kind of bunk bed that's ideal for you could be the most difficult thing but there are a variety of other aspects to take into consideration. You'll need to decide if you have the space for a large bunk bed at the bottom, and the type of ladder you'd prefer. You'll need to think about the weight capacity of your beds. Because bunk beds are heavy, you'll need to ensure that the top and bottom beds can support at minimum two people.
We consulted three experts including a writer and author of the book on bunk beds to give their opinion. They shared their recommendations for frames ranging from twin-over-twin budget models to more expensive ones that included a slide or even a futon.
Look for bunk beds made of solid materials, such as plywood or dried kiln-dried wood. Don't forget the safety features, like guardrails both on the sides of the frame and a sturdy ladder that is non-slip. Think about the amount of storage that you need in your bunk bed. Some beds have under-bed trundles that can be removed to accommodate guests.
4. Crate & Barrel
Loft beds and bunk beds for kids can create enjoyable practical spaces for sleeping and play that can be used to save space in smaller rooms. These beds are ideal for rooms that are shared, cottage/coastal style rustic log cabin, farmhouse and log Barnwood styles. There are wooden bunk beds and lofts in a variety of sizes, including twin over twin and full over full models. Some have storage options, such as under-bed drawers and an trundle that can be rolled out for sleepovers. Many come with stairs or ladders that must be strong and durable to withstand the weight of children.
Some loft and bunk beds for kids come with desks where kids can complete their homework or do other activities. Some bunk beds and loft beds are equipped with built-in wardrobes which can be used as storage of clothes. A lot of cheap bunk beds for kids and loft beds for kids come with a selection of colorful paint finishes, so parents can pick the one that best matches their children's rooms. Bunk and loft beds for kids can be customized by adding a variety of features like stair or ladder configurations, storage drawers or an upholstery headboard.
Loft beds and bunk beds for kids are great for rooms with high ceilings. However they can be a challenge to move around in smaller bedrooms. Make sure to choose one with a minimum recommended ceiling height of 8 feet to ensure safety for your child while climbing to the top of the frame. The majority of loft and bunk beds are made for children ages 6 and up, who can safely adhere to the proper bedtime routine while sleeping on top.
Crate and Barrel's housewares and furniture stores carry bunk and loft beds for kids that are a perfect match for traditional and modern home decor. Shop a wide range of bedroom furniture, kid's decor and toys at the New York-area Crate and Barrel store in Soho or at the Manhasset store. Add the crib to your baby's registry if you're hoping to receive free design assistance as well as 10% off the completed crib.
5. IKEA
If you're looking for a traditional twin-over-twin bed or something more unique, IKEA offers a variety of options. Their Daxter cottage-style deals bunk beds bed is a great choice, especially for families on a budget. It comes with angled ladders as well as guardrails, as well as plenty storage space underneath. However, it's smaller than other options and may not suit children younger than six.
The Mydal Bunk Bed is a different option. It can be incorporated into rooms with lower ceilings thanks to its compact design and low ladder height. It's also a little cheaper than the other options on this list and offers many options with its removable side panels and drawers that can be added for additional storage. The only drawback is the lack of storage built-in under the bed. However, there's plenty of room to add your own.
For bunk beds that are more traditional, Pottery Barn Kids has a good selection of twin-over-full styles that can be a smart choice for siblings who live together but prefer their own space. These bunk beds are usually equipped with an ordinary ladder or staircase, and rails on top of the bed to ensure safety. They are also available in a wide range of finishes to match any decor.
If you want to save space and provide your children with the space to be social, you should consider bunk beds with extra features like desks, or stairs that can be transformed into a storage area. Some bunk beds can even accommodate a trundle, which is able to be removed from the bottom, giving you the possibility of sleeping three or four people in a room.
1. Amazon
2. Target
3. Wayfair
4. Crate & Barrel
5. IKEA
- 이전글The 12 Worst Types Replacement Upvc Door Handle People You Follow On Twitter 25.05.21
- 다음글Why No One Cares About Adult ADHD Signs 25.05.21
