See What Double Glazing Window Handles Tricks The Celebs Are Utilizing
Types of Window Handles
Window handles are a key aspect of the overall design of your home and it's important to consider not only the style, but also the function. There are many different types of handles that are available, such as Cockspur handles, Tilt-and-turn handles and Espag handles.
Espag handles are the most commonly used kind of handle used in modern double glazed windows and work with espagnolete locks, which offer multi-point security. They can be mounted in-line or operated by cranking.
uPVC
uPVC has become a popular alternative to aluminium and timber because of its low cost. This product is not only environmentally friendly, but also a good investment. It is durable, strong and weatherproof. uPVC has been tested in extreme temperatures to make sure it does not fade due to solar radiation. It also resists rust and other chemicals such as acids.
Window handles are typically made out of uPVC. They are used to secure or open your windows. They are available in a variety of sizes and styles. They are sold at a variety of hardware shops and are relatively affordable. If your windows are not closing correctly or the locks don't engage, it could be due to the handle being damaged or broken. A simple replacement will bring back the functionality of your windows and make them look great.
You'll need to measure the backset of your window prior to buying new uPVC handles. This measurement is the distance between the underside of handle's nose and the bottom of the screw plate. The most commonly used uPVC handles come with a backset of 43mm. You can also find a window handle that has a smaller or a larger backset depending on the type of window you have. It is also important to decide if you have a cockspur spade or blade handle. Cockspur handles have a spindle that protrudes from the handle, while blade and spade handles are made for fixed windows.
If your uPVC handles are jammed, the spindle inside the handle is likely to be worn out. This is a common issue in older windows. It can be corrected by replacing the handle. It could be that the roller on the shoot bolt has split from the handle.
Timber
If your windows are made out of timber, then you'll need window handles that work with the material. Sealco Scotland has a selection of handles designed to fit on timber frames. You can select from a wide range of colours and finishes to match your home.
There are a variety of handles for windows with double glazing window handle glazing made of timber such as Espag handles, Cockspur handles and tilt and turn handles. All of these handles are available in many different styles, including period designs. Choosing the right type of handle is vital, since it will determine how easy it is to open and close your windows.
When choosing a pair window handles you should also be aware of the step height. This is the distance from the base of the spindle up to the handle nose. This will help you determine whether the handle will be able to fit into your blinds, and also prevent them from being poked through. You should also check the spindle of your handle. This is the distance from the base of your handle to the point where it is fixed to the window frame.
For more information about selecting the right window handle for your double-glazed windows, talk to a specialist from Sealco Scotland today. We will be happy to answer any questions you may have and provide you with the best solution. Contact us via our online form or calling us at 07875 773433. Our experts can give you assistance with other products, such as glazing beads and hinges.
Aluminium
The handles on your double-glazed windows are an important element of the overall design of your home. The handles do not just let you open and close your windows, but also provide security as they lock the window. This helps prevent burglars from gaining access to your home through the windows.
Window handles are generally made of a tough material like aluminium. They come in a variety of different colours and styles to suit any style of home. They are also designed to stand up to prolonged use for a long period of time. They come in various finishes and can be installed on the inside of the window frame or the outside.
There are a myriad of types of window handles that you can pick from, but they usually are classified into three categories: cockspur, tilt and turn and espag. Cockspur window handle systems are latch and catch systems installed on aluminium, timber and uPVC casement windows. They differ from espag handles in that the cockspur handles close to a catch, whereas the espag handle closes to wedge blocks.
The cockspur and espag handles are designed to work combination with espagnolette locks which provide greater security for your home. These are operated by a small lock inside the handle. They are a good choice for older homes with traditional glazing. They can also be locked using keys, which is especially beneficial for the safety of children.
Aluminum handles are popular because of their durability and attractiveness. They are available in a range of colours, including grey, to complement any interior design. They are also less expensive than uPVC and are great at keeping your home warm since they hold heat. They also do not need painting and are easily repaired.
Cockspur
Cockspur handles are found on both timber and upvc windows. These handles for windows have a nose which locks and locates a plastic striker that is fixed to the frame. The cockspur handle can be deadlocked for added security. Yale Securistyle cockspur handles are available in different sizes to fit your new window.
The cockspur handle may be used to fit modern double glazed door handle-glazed windows, but is more commonly used on older windows. If you are installing a replacement handles for upvc windows window with an internal mechanism that is different from the original and you'll need wedges to ensure that the cockspur handle within the frame. Window wedges or cockspur wedges can be a simple fix and are available in various sizes to meet your requirements.
These window wedges can be fixed to the frame of your replacement timber or upvc windows to ensure that the handle is situated within the frame. The flat side on the back makes it easy to identify. They are usually supplied with a cockspur-style handle. They are also available as a separate item and are easy to put in.
The cockspur handle is placed on both the right and left doors. It is a strong, durable handle that can be equipped with keys or a thumb-turn lock to offer additional security and privacy. The cockspur is made of premium materials that can withstand repeated use for a long time. It comes in various finishes to match existing hardware. This handle is suitable for both timber and uPVC casement windows and can be purchased with either keys or a thumb turn lock option.
Espagnolette
Espagnolette handles are present on many double-glazed windows. They are operated by multi-point locking mechanisms. They feature a spindle on the back that connects to an internal gearbox within the window which, when turned, activates the shootbolt mechanism that secures the perimeter of the window that opens. Espagnolette handles are flexible and can be used with tilt-and-turn windows as well as traditional cock spur windows. They come in a range of styles including cranked, offset and locking designs Peardrop, monkeytail and teardrop handles. They are reeded, reeded and to suit both contemporary and traditional tastes.
The term "cranked" refers to an ergonomic lever design that is located a bit farther away from the handle frame, allowing for a more generous clearance between the window frame and the hand while operating. This is a huge benefit where the original handles were positioned right against the edge of the frame making them difficult to operate. The cranked designs are available in right-hand or left-hand models based on the orientation of the window they replace.
When replacing uPVC window handles or changing the appearance of your home, it is crucial to consider the types of handles and styles that are available as there are a variety of ways to make a external door handles euro lock or window feel more secure, comfortable and secure. If you are looking for the contemporary touch of black handles or the rustic elegance of a cast iron design there are plenty of options for every taste and budget.
Espag handles are typically found on uPVC or double glazed window frames made of aluminium. They feature seven millimetre squared spindles that activates the multi-point locking mechanism when they are moved. They are suitable for both tilt and turn window systems and traditional cockspur window systems. They are also very adaptable and can be used with a broad variety of window stays.
uPVC
Timber
Aluminium
Cockspur
Espagnolette
- 이전글The Reasons Renault Car Keys Is The Obsession Of Everyone In 2023 25.05.20
- 다음글9 Lessons Your Parents Taught You About Double Oven And Microwave Built In 25.05.20
