Built In Microwave Over Oven Tips From The Top In The Industry > 자유게시판
작성자 Thalia Gamboa
댓글 0건 조회 9회 작성일 25-05-20 21:16
whirlpool-amw423ix-built-in-microwave-steam-cooking-fast-defrost-child-lock-22l-750w-stainless-steel-4975-small.jpgBenefits of a Built in Microwave Over Oven
A microwave oven that has a built-in microwave lets you cook and heat your food quickly and conveniently. GE provides a variety of styles, cooking technology and control options to fit your kitchen.
Countertop microwaves are placed on the counter and plug into outlets and built-in models are installed in a recessed wall or between cabinets for an elegant, built-in appearance. These types of microwaves require professional installation.
Space Saver
The microwave is among the most commonly used kitchen appliances but it can consume valuable counter space. There are many smart ways to make the most of your countertop space by moving your microwave to an alternative place, such as a kitchen island or recessing it into the wall.
One of the most popular choices is an over-the-range (OTR) microwave. Tucked away neatly above your stove, this model is especially beneficial in smaller kitchens where space is limited. Some OTR models also double as an air vent for your cooktop. This can help reduce the buildup of steam.
Installing a microwave that is best integrated combination microwave into your cabinetry can save you space. This type of appliance offers a sleek, best integrated microwave oven look that can match the style, 45Cm built-in microwave color, or finish of your kitchen fixtures and cabinets. It can also create a more streamlined appearance in your kitchen, which is perfect for those who prefer an uncluttered and clean look.
However installing a microwave built-in may require professional installation or a remodeling of your kitchen. You might be able depending on the layout of your house to cut a hole in a wall to install the appliance. However, this will require professional framing and strengthening. In addition, microwaves with built-ins require adequate ventilation to avoid overheating and causing damage to the appliance. According to Sam Cipiti, vice president of R. M. Tunis Kitchens and Baths in Chevy Chase, Maryland, the minimum cabinet depth for a microwave built-in is approximately 15 inches, but some manufacturers offer trim kits that offer up to 1 1/2 inches of extra space to allow for ventilation.
A microwave with a drawer design can be set up under your counter or inside an island. This configuration is easy-to-access, suitable for all ages and requires less counter space. It also helps prevent hot dishes or containers falling off the edge or being thrown down.
The door design is the final factor to consider when selecting a microwave that is space-saving. There are many brands that have a door that opens in the same way as other kitchen appliances, such as dropping-down or slide-out. This allows you to integrate your microwave seamlessly into your cooking workflow. Some models also come with a sleek and smooth exterior that is resistant to fingerprints, giving an attractive, cleaner appearance.
Convenience
A built-in microwave that is over the oven has a stylish design, easy to clean and convenient. They are usually set at eye level for easy access and are equipped with turntables to reduce the need to transfer food from one plate to the next. Additionally, built-in microwaves usually have options that increase functionality, like EasyConvection oven conversion technology, and broil elements that allow you to cook or brown food items.
In addition to reducing counter space, a built-in microwave over oven can also boost your home's value and appeal by giving it a premium look that other appliances may not be capable of matching. Whether installed above your stove or in a separate cabinet these microwaves blend seamlessly into your kitchen to create a tailored appearance that shows that you've put money into your kitchen and home.
Built in microwave over ovens are available in a wide variety of sizes, power levels and features to match any kitchen configuration. You can even install them under your counter with a drawer design for a more integrated combi microwave look that fits snugly into existing cabinets and requires no additional space. Designed with premium finishes and top-of-the-line features they are sure to complement your kitchen's aesthetic and enhance your cooking and entertaining experience.
Although the built-in microwave over ovens are useful however they aren't as versatile as their counterparts that stand on their own. Depending on where you install yours, it might require more space than other types of microwaves. They are also not as portable, and you won't be able easily swap the model for a different model if you want something different.
If you place your microwave above your range, you'll require a larger kitchen to accommodate the ventilation system that is required by this arrangement. You'll need an option for ducting that directs smoke out to the outside or a ventilation system that recirculates air through the microwave and into the house. Consider a built-in microwave for the kitchen that is small. It can be put to a cabinet, wall or an island.
Convenient Controls
Microwaves offer a wide variety of controls based on the model. Common features include turntables, preset functions including defrosting and reheating, and 30 second buttons. Certain models include child safety features to prevent accidental operation.
Many microwaves have pre-programmed recipes and cooking times, which makes the process of preparing food faster and simpler. This feature is useful for those who are just beginning to cook and are not sure of the time needed to heat specific foods or who are unfamiliar with the specific cooking techniques used in different cuisines.
KitchenAid offers a variety of built-in microwaves as well as over-the-range microwaves designed to match your other appliances in design and finish to create an elegant look. Choose from stainless steel or black finishes that are perfect for any kitchen. These premium microwaves are boldly designed to bring professional-inspired styles into your home, and they're made with high-quality materials for a longer lifespan.
Built-in microwaves, in contrast to countertop models, are set in a fixed area of your walls or cabinets for an elegant and unique look. They generally use the same components inside as regular countertop models, with some exceptions. They are available in various sizes, including those designed to fit in a compact space and their exteriors could have doors that open in a left-to-right swing-out or drop-down style.
Certain microwaves over the range like those made by Whirlpool(r), even double as vent hoods to your stove in the kitchen. They also have an exhaust system that is 45cm built-in microwave (Https://clinfowiki.win/) to let fumes out and circulate air. Some microwaves come with charcoal filters that eliminate moisture and odors from your kitchen.
Countertop models can be placed on your kitchen counter and do not require venting hookups, or any special installation, making them a great option for rental properties or anyone who wants to stay clear of costly renovations to their kitchens. Certain models include trim kits to fill in the gap between your microwave and other freestanding countertop appliances, such as coffee pots bread makers, toaster ovens or bread ovens.
Energy Efficiency
Microwaves are more efficient at heating water and food as in comparison to other cooking methods. They also use less energy than stovetop ovens due to the fact that they focus microwaves integrated' energy on the liquid within, rather than on heating the air or other elements around it. Because of this, they can cook food much faster than conventional ovens. They can be placed within the upper or lower cabinets and are available in modern or retro designs to match any kitchen.
In this supplemental notice of proposed rulemaking ("SNOPR"), the Office of Energy Efficiency and Renewable Energy (DOE) proposes new or amended energy conservation standards for microwave ovens, which will save consumers money on their operating costs. The Energy Policy and Conservation Act ("EPCA") requires DOE to examine on a regular basis whether more-stringent standards would be economically viable and technologically feasible and could result in significant energy savings.
This SNOPR provides the analysis and results that DOE carried out to assess the impact on consumers of new or amended energy conservation standards for microwave ovens. The analysis includes a market and 45cm built-in microwave technology assessment screening and engineering analysis and an analysis of the impact on the nation.
The energy use analysis calculates annual average microwave oven operating hours in representative sampled homes. It is the basis for the energy savings analyses and the other consumer analysis in this SNOPR. The analysis is made using RECS field data from multiple regions and considers the different usage patterns of microwave ovens across different households and the variation in regional electricity prices.
To assess the impact of potential changes or new standards on household operating costs, DOE conducted LCC and PBP analyses to determine the lifetime cost of purchasing and using microwave ovens at various efficiency levels. The LCC and PBP calculations are based on an algorithm for computer models that employs a Monte Carlo simulation to incorporate uncertainty and variation into the analysis.
This SNOPR includes an assessment of the impact of the new or amended standards at the national level, based on the NIA spreadsheet. The NIA model determines industry net present value ("INPV") in terms of energy savings resulting from possible new or amended standards in terms of site energy savings and FFC energy savings.
