See What Built In Microwave Over Oven Tricks The Celebs Are Using > 자유게시판
작성자 Franklyn Barbos…
댓글 0건 조회 3회 작성일 25-05-20 20:21
Benefits of a Built in Microwave Over Oven
A built in microwave over oven allows you to cook and reheat food quickly and easily. GE offers a wide range of styles, cooking technology and control options that can be adapted to your kitchen.
indesit-built-in-mwi3213ix-750w-microwave-stainless-steel-4947-small.jpgBuilt-in microwaves are positioned behind cabinets or in recessed walls to give them a sleek and integrated look. These types of microwaves require professional installation.
Space Saver
The microwave is a well-loved appliance in the kitchen, however it can also take up valuable countertop space. There are plenty of smart ways to make the most of your counter space by moving your microwave to an alternative place, like a kitchen island or recessing it into the wall.
One of the most popular choices is an over-the-range (OTR) microwave. It is tucked away in a neatly placed above the stove, this option can be especially useful in kitchens with smaller spaces where space is at a premium. Certain OTR models also double as a vent for your cooktop. This can reduce the buildup of steam.
Installing a microwave that is integrated into your cabinetry will save you space. This can give you a sleek, integrated appearance that can be matched to your kitchen's cabinets and fixtures in color, finish, or style. It can also help create a more streamlined appearance in your kitchen, which is great for those who prefer a clean and uncluttered look.
However, installing a built-in microwave could require a professional installation or renovation of your kitchen. Based on the layout of your home it is possible to cut out a space within walls to accommodate the appliance but this requires proper framing and reinforcement which should be left to experts. Also, built-in microwaves require adequate ventilation to ensure that they don't overheat and damage the appliance. According to Sam Cipiti of R. M. Tunis Kitchens and Baths in Chevy Chase, Maryland the minimum cabinet depth for a built-in oven is 15 inches. However some manufacturers offer trim kits that provide up to 1 1/2 inches of extra space to allow for ventilation.
A microwave that is built like a drawer can be set up under your counter or inside an island. This design is easily accessible, suitable for all and requires less counter space. It also stops hot dishes from falling off the edge or being thrown down.
The door design is the final factor to consider when choosing a compact microwave. Many brands offer a swing-out, drop-down or slide-out door that opens in the same motion as other kitchen appliances to allow you to seamlessly integrate your microwave into your cooking workflow. Some models also have a smooth and sleek exterior that resists fingerprints for a cleaner, more attractive appearance.
Convenience
A built-in microwave over oven is attractive design, easy to clean and convenient. Unlike countertop models, they're usually placed at eye level for easier accessibility and are often equipped with turntables that eliminate the necessity of constantly shifting food from plate to plate. In addition, built in microwave and oven combo in microwaves usually have options that increase functionality, like EasyConvection oven conversion technology and broil elements that allow you to brown or crisp food items.
A built-in microwave on top of the oven will save counter space, and can also boost the value of your home by giving it a sleek and high-end appearance that other appliances may not be able match. It can be placed above your stove or in a separate cabinet these microwaves blend seamlessly into your kitchen to create an elegant look that demonstrates that you've put money into your kitchen and your home.
best built-in combination microwave oven microwaves over ovens are available in a vast variety of sizes, power levels and features to suit any kitchen configuration. Install them underneath the counter in a drawer style to give a more integrated appearance that fits snugly within existing cabinets. It doesn't require any additional space. These microwaves, with their high-end finishes and high-end functions will enhance the look of your kitchen and enhance your dining and cooking experiences.
While the convenience of a built in microwave oven is evident however, you should be aware that these microwaves aren't as versatile as their freestanding counterparts. It may take more space to operate, depending on the place it's placed. They're also not as mobile, and you aren't able to easily switch the model if you want something different.
If you choose to install your microwave over your range, then you will need a larger space in your kitchen to accommodate the ventilation needed by this arrangement. You'll need either a ducting option that directs smoke out to the outside or a recirculating venting system that pulls air from the microwave into the home. Consider a built in oven and microwave combination-in microwave to the kitchen that is small. It can be put into a wall, cabinet or even an island.
Convenient Controls
Microwave ovens come with numerous controls according to the model you choose. Common features include turntables, preset functions like defrosting and reheating as well as 30 second buttons. Some models have child safety features to prevent accidental operation.
Many microwaves come with pre-programmed recipes and cooking times that make the process of making meals faster and easier. This feature is helpful for those who are just beginning to cook and are not sure of the time needed to cook certain foods or who aren't familiar with the cooking techniques used in different cuisines.
KitchenAid provides a variety of built-in microwaves as well as over-the-range microwaves that are designed to match your other appliances in style and design to create seamless appearance. Choose from stainless steel and black finishes that will match any kitchen. These premium microwaves are boldly designed to bring professional-inspired styles into your home, and they're made with high-quality materials for a longer lifespan.
Built-in microwaves, unlike countertop models, are set in a fixed area of your kitchen cabinets or walls for sleek and distinctive appearance. They generally use the same internal components like countertop models, with a few exceptions. These models come in different sizes, Built in Microwave Over Oven and some are designed to fit in smaller spaces. The exteriors of these models may feature doors that open in a swing-out style from left to right or drop-down style.
Certain microwaves in the range, such as the ones made by Whirlpool(r), can also be used as vent hoods. They come with an exhaust system built in to let out fumes outside and recirculate air. Others have a built-in charcoal filter that removes odors and moisture from your kitchen.
Countertop models sit on your counter top and do not require venting hookups, or special installations which makes them a great option for rental properties or anyone who wants to avoid costly modifications to their kitchens. Some options include trim kits to fill in the gap between your microwave and other countertop appliances like coffee pots, bread makers or toaster ovens.
Energy Efficiency
Microwaves use less energy to cook water and food than other cooking methods. They also consume less power than stovetops that are conventional because the microwaves focus their energy on the liquid in instead of heating the air surrounding it. This means that they can cook food much faster than a conventional oven. They can be placed in the upper or lower cabinets, and come with modern or retro styling to match any kitchen style.
In this notice of proposed rulemaking ("SNOPR") The Office of Energy Efficiency and Renewable Energy (DOE) proposes new or modified energy conservation standards for microwave ovens that reduce the cost of operating costs. The Energy Policy and Conservation Act ("EPCA") requires DOE to periodically determine whether stricter standards are economically viable and technologically feasible, as well as result in significant energy savings.
This SNOPR includes DOE's analysis and results to evaluate the effects of new or revised energy standards for microwave ovens on consumers. The analysis includes a technology and market assessment as well as a screening analysis of engineering analysis, and a national impacts analysis.
The energy use analysis calculates the average annual microwave oven operating hours in representative sampled homes. It forms the basis for the energy savings assessments and the other consumer analyses included in this SNOPR. The analysis is best built in combination microwave oven on RECS field data from a variety of regions and considers the different patterns of usage of microwave ovens in various households, as well as the variations in regional electricity prices.
To assess the impact of new or amended standards on household costs, DOE conducted LCC analyses and PBP analyses to estimate the cost over time for purchasing and using a micro-wave oven at different efficiency level. The LCC and PBP calculations are based on the computer model that utilizes a Monte Carlo simulation to incorporate uncertainty and variation into the analyses.
This SNOPR includes an analysis of the impact of amended or new standards at the national scale based on the NIA spreadsheet. The NIA model determines industry net present value ("INPV") in terms of energy savings resulting from potential amended or new standards in terms of site energy savings and FFC energy savings.
