See What Best Places To Buy Bunk Beds Tricks The Celebs Are Making Use…
The Best Places to Buy Bunk Beds
Bunk beds look great in children's bedrooms and are available in a variety of styles. In addition to the traditional twin over twin design, you can also find futon bunks and triple bunks that can be tucked away in small rooms.
Consider the weight capacity when selecting a bunk bed. Most bunk beds have a maximum weight of 400 pounds for each mattress. However there are some options with higher limits on weight for children older than and teenagers.
1. Amazon
Bunk beds are a great option for parents who want to save space in their bedroom or for kids who want to add a fun element to their bedroom. There are many options, including full-overfull and twin-overtwin designs. Some bunk beds come with slides. You could consider a twin over twin with guard rails if your children are under six years old, or a toddler bunk beds.
You'll need to consider whether you require storage or if safety and durability are important. "The most important factor to look for in the bunk bed is its durability," says Nikki Njeri Klugh the principal designer and founder of Nikki Klugh Design Group Inc. The structure must be constructed of metal or wood and should be sturdy enough to support a full-size mattress, she adds.
When you're considering a bunk bed, it's also important to consider the size of your space and how tall you want the upper bed to be. If you have rooms with low ceilings pick an loft bed that is closer to the ground, or one with stairs instead of a ladder. The top bunk should have side rails to ensure the person sleeping in it isn't thrown off and there should be guardrails on both sides of the bottom bed, says Dr. Mehrin Islam, a pediatric emergency medicine specialist at Weill Cornell Medicine and New York-Presbyterian.
If you're searching for a bunk bed that is affordable, consider this option from IKEA that comes with an easy frame and a ladder that mounts on either side of the bed. It also meets CPSC safety standards as well as industry standards. You can upgrade to a bigger model for an additional cost that sleeps two and includes built-in under-bed storage drawers.
2. Target
Lofts and bunk beds are great space savers for kids' rooms and can make the room more enjoyable. There's a broad selection of styles, finishes and configurations at Target. Look for options that offer shelving, storage or other features in addition to sleeping spaces. You'll also find options that can accommodate twin trundle beds underneath which is ideal for sleepovers.
There are the standard twin-over-twin bunk beds available at Target, along with full-over-full beds that work well in larger rooms. It's crucial to take into account the height of your ceiling when choosing the size of the bunk bed. It is important to ensure that the bunks will fit in your space and there's enough room to safely climb into and out of them, says Dr. Colleen Kraft, a pediatric emergency medicine specialist at Weill Cornell Medicine and New York-Presbyterian. If you have a low ceiling, you may want to consider a bunk with ladders specifically designed for this type space.
Another aspect to be considered when you are looking for a bunk or loft bed is the weight limit of the upper bunk. The Daxter best bunk beds from Pottery Barn Kids, for example, are designed to support up to 165 pounds of weight per bed, which is less than some other brands. The Oeuf Perch is made from sustainable Baltic Birch plywood from the Forest Stewardship Council and eco-friendly medium density fiberboard. It has a weight limit of 250 pounds for the top bunk. This is higher than other brands.
Metal or wood can be used to construct bunk and loft beds. Steel beds tend to be more durable, but they may feel more cold and snarlier than wooden alternatives. Some wood bunk bed models are GreenGuard Gold certified.
3. Wayfair
Sturdy, versatile and fashionable Bunk beds are a practical and space-saving sleeping solution for kids and adults alike. There are countless options, from twin-over-twin to full-sized lofts with the lower bed arranged in an L-shaped. Some have additional features, like storage or a futon underneath (like our top pick, the Crate & Barrel Babyletto TipToe White and Washed Natural Wood Kids Bunk Bed).
While deciding on what kind of bunk bed that's suitable for you could be the most difficult thing there are other aspects to take into consideration. You'll need to decide if you have the space for a large bunk bed at the bottom and the type of ladder you'd prefer. You'll need to think about the capacity of your beds. Because bunk beds are heavy, you'll need to make sure that the top and bottom beds can hold at minimum two people.
We asked three experts, including an author and writer of the book on bunkbeds to weigh in. They suggested a few of their favorite frames that range from budget-friendly twin-over-twin models to more expensive models with a slide, and even a futon.
Choose bunk beds that are constructed of solid materials such as plywood or dried kiln-dried wood. Don't forget the security features, such as guardrails that are placed on both sides of the frame, and a sturdy ladder that is not slippery. Also, think about the amount of storage space you'd like to have in your bunk beds, since some come with under-bed trundles which pull out to accommodate extra guests staying over.
4. Crate & Barrel
Loft beds and bunk beds are great for securing space in tiny rooms and creating enjoyable areas for sleeping and playing. They're a great choice for shared bedrooms with kids and for cottage/coastal, farmhouse, rustic cabin and log Barnwood decor styles. There are lofts and bunk beds made of wood in various sizes, including twin over twin and full over full models. Some bunk beds come with storage solutions such as under-bed drawers or a roll-out trundle. Many come with a ladder or staircase which should be sturdy and durable enough to support the weight of the children who climb it.
Some bunk beds and loft beds for kids come with desks that kids can use to complete their homework or do other activities. Some bunk for adults beds and loft beds have built-in wardrobes which can be used as clothing storage. Many loft and bunk beds for children come with a variety of vibrant paint finishes, so parents can select the one that best quality bunk beds suits their kiddos' rooms. Loft and bunk beds for kids can be customized with a variety of features like ladders or stairs as well as storage drawers and an upholstered headboard.
Bunk and loft beds for kids are ideal for rooms with high ceilings. However, they can be difficult to move around in smaller bedrooms. Make sure to choose one with minimum ceiling height of 8 feet to ensure the safety of your child when climbing to the top of the frame. Most standard loft and bunk beds are designed for children aged 6 and over who are able to adhere to a strict bedtime routine while sleeping on top.
Crate and barrel's homewares and furniture stores sell bunk and loft beds for kids that blend with traditional and modern home decor. Crate and Barrel stores in New York's Soho and Manhasset offer a wide selection of kid's furniture, decor and toys. Add the crib to the baby's registry if expecting to get free design assistance and a 10% discount on the crib that is completed.
5. IKEA
Whether you're in the market for a classic twin-over-twin bed or a unique design, IKEA offers a variety of options. Their Daxter cottage-style bunk bed is a great option for families with a tight budget. It comes with angled ladders, guardrails and plenty of room underneath for storage options, but it is slightly smaller than the other choices on our list. It may not be suitable for kids younger than six years old.
Another great option is the Mydal Bunk Bed, which can fit in rooms with lower ceilings thanks to its small size and a shorter ladder height. It's also more affordable than other models and offers a great deal of versatility because of its side panels and drawers. The only drawback is that it doesn't have built-in under-bed storage There's enough space under the bed for you to build your own solutions.
Pottery Barn Kids offers a large selection of twin over full bunk beds that are an ideal choice for siblings who want to share a room, but live close by. These beds are typically equipped with an ordinary ladder or staircase, and rails on top of the bed for safety. They also come in a variety of finishes to complement any decor.
If you want to save space and provide your children with an area to play, pick bunk beds with extra features, like desks, or stairs that can be turned into a storage area. Some bunk beds best beds even accommodate a trundle, which can be pulled out from underneath the bottom, giving you the option of sleeping three or four people in one room.
1. Amazon
2. Target
3. Wayfair
4. Crate & Barrel
5. IKEA
- 이전글What Is Psychiatrists Near Me And Why Is Everyone Talking About It? 25.05.20
- 다음글5 Common Phrases About Add In Adult Women You Should Avoid 25.05.20
