What's The Reason Everyone Is Talking About Built In Microwave Over Oven Right Now > 자유게시판
What's The Reason Everyone Is Talking About Built In Microwave Over Ov…
작성자 Isabelle
댓글 0건 조회 2회 작성일 25-05-20 19:12
Benefits of a Built in Microwave Over Oven
russell-hobbs-rhbm2503-25l-built-in-digital-900w-combination-microwave-stainless-steel-4565-small.jpgA microwave oven that has a built microwave oven combo-in microwave lets you cook and reheat your food quickly and conveniently. GE offers a wide range of styles, cooking technologies and control options that will suit your kitchen.
Countertop microwaves sit on the counter and plug into an outlet or outlet, while built-in models can be placed in a wall with a recess or among cabinets for an elegant, built-in appearance. These types of microwaves require professional installation.
Space Saver
The microwave is one of the most commonly used kitchen appliances, but it can also take up valuable counter space. There are plenty of smart ways to reclaim counter space by moving your microwave to a different place, such as the kitchen island or by recessing it into the wall.
One of the most popular options is an over the range (OTR) microwave. This option is conveniently hidden behind your stove, can be particularly useful in kitchens that are small and have small space. Certain OTR models can also function as a vent for your cooktop. This can help to reduce steam buildup.
Another space-saving solution is to install a built-in microwave that blends into your cabinetry. This gives you a sleek, integrated appearance that can be matched to your kitchen's cabinets and fixtures in color, finish or style. It also helps to create a more minimalist look in your kitchen, which is perfect for homeowners who prefer a clean and uncluttered look.
Installing a built-in microwave might require an expert installation or kitchen remodel. Based on the layout of your home you may be able to cut out a space within walls to accommodate the appliance however, this requires proper framing and reinforcement which should be left to professionals. Also, built-in microwaves require adequate ventilation to ensure that they don't overheat and damaging the appliance. According to Sam Cipiti of R. M. Tunis Kitchens and Baths, in Chevy Chase, Maryland the minimum cabinet depth of a built in double oven and microwave-in oven is 15 inches. However some manufacturers offer trim kits with up to 1 1/2 inches of extra space for ventilation.
A third space-saving option is a drawer-style microwave that can be placed under your counter or inside an island. This configuration is easy-to-access, suitable for everyone and requires less counter space. It also helps prevent hot dishes or containers from falling off the edge of the microwave or being knocked over.
The final aspect to consider for a space-saving microwave is its door design. Many brands offer an open, swing-out or built in double oven and microwave combination slide-out door that opens with the same motion as other kitchen appliances to help you seamlessly integrate your microwave into your cooking routine. Some models come with a sleek and smooth exterior that wards off fingerprints for a cleaner, more attractive appearance.
Convenience
A built-in microwave that is over the oven is attractive, convenient and easy-to-clean design. They are usually placed at eye-level for easier access and come with turntables to make it less necessary to move food from one plate to the next. built in double oven and microwave combination-in microwaves are usually equipped with features that improve their capabilities, like EasyConvection technology to convert ovens and a broiler element that can cook or brown food.
In addition to reducing counter space, a built-in microwave over oven can also boost your home's value and appearance by offering a luxurious look that other appliances may not be able to match. If it's installed above the stove or in a separate cabinet, these microwaves seamlessly blend into your kitchen, creating a tailored appearance that shows you've put in the time to improve your kitchen and home.
Built-in microwaves and ovens are available in a wide variety of dimensions, power levels and features to fit any kitchen layout. You can even install them under your counter with a drawer design to give a more cohesive appearance that blends seamlessly into existing cabinetry and requires no additional space. Made with premium finishes and high-end features they are sure to complement the style of your kitchen and elevate your cooking and entertaining experience.
While the convenience of a built in microwave small in microwave over oven is clear, keep in mind that they aren't as efficient as their freestanding counterparts. It might require more space to operate, depending on the location it's installed. They are also not as portable, and you cannot easily change the model if you want something different.
If you choose to install the microwave on top of your range, then you'll require a bigger space in your kitchen to allow for the ventilation required in this setup. You'll either need a ducting option that directs smoke out to the outside or a ventilation system that recirculates air through the microwave into the house. For smaller kitchens you might want to consider a separate microwave built-in that can be incorporated inside the wall, cabinet or island.
Convenient Controls
Microwave ovens come with a variety of convenient controls according to the model you pick. Common features include turntables, preset functions like defrosting and reheating as well as 30-second buttons. Some models have child safety features that prevent accidental operation of the appliance.
Many microwaves also come with pre-programmed recipes and cooking times to help you prepare meals more efficient and less time-consuming. This feature is beneficial for new cooks who don't know how long to heat certain foods or for those who aren't comfortable with the particular cooking techniques employed in various cuisines.
KitchenAid brand offers a wide selection of built-in and over the-range microwaves that are designed to match the style and appearance of your other appliances for an integrated look to your kitchen. Select from stainless steel and black finishes that will complement any kitchen. These premium microwaves are boldly designed to bring professional-inspired styles into your home, and they're made with high-quality materials for a longer lifespan.
best built in microwave-in microwaves, unlike countertop models, are installed in a fixed location of your kitchen cabinets or walls for a sleek and custom look. The internal components are usually the same as those of traditional countertop models, with some exceptions. These models are available in a variety of sizes, and some are designed to fit in small spaces. Their exteriors could have doors that open in a swing-out from left to right or in drop-down style.
Certain microwaves in the range, such as the ones made by Whirlpool(r) and Whirlpool(r), can be used as vent hoods. They have an exhaust system that is built-in to let fumes out and recirculate the air. Some models come with a charcoal filter to eliminate moisture and odors from your kitchen.
Countertop models are positioned on the counter of the kitchen. They don't need venting or a special installation. This makes them a good choice for people who rent their homes or want to save money on costly changes to their kitchens. Certain models include trim kits to close the gap between your microwave and other freestanding countertop appliances like coffee pots and bread makers, as well as toaster ovens.
Energy Efficiency
Microwaves are more efficient in heating food and water compared to other cooking methods. They also consume less energy than stovetop ovens since they focus the microwave's energy on the liquid within, rather than on heating the air or other elements around it. They can cook food quicker than conventional ovens. They can be placed in the lower or upper cabinets, and are available in modern or retro designs to match any kitchen.
In this supplemental notification of proposed rulemaking ("SNOPR") the Office of Energy Efficiency and Renewable Energy proposes new or revised energy conservation standards for microwave ovens which will help consumers save money on operating costs. The Energy Policy and Conservation Act ("EPCA") requires DOE to evaluate on a regular basis whether stricter standards are economically viable and technologically feasible and result in significant energy savings.
This SNOPR includes the analyses and findings that DOE conducted to assess the impact on consumers of new or amended energy conservation standards for microwave ovens. The analysis includes a technology and market assessment screening and engineering analysis and an analysis of the national impact.
The energy usage analysis calculates the average annual microwave oven operating hours for households from a representative sample. This analysis is the basis of the energy savings assessments as well as the other consumer analyses included in this SNOPR. The analysis is built on RECS field data from a variety of regions, and takes into account the various patterns of use of microwave ovens in different households and also the variations in regional electricity prices.
To evaluate the impact of potential new or amended standards on the cost of operating a household, DOE conducted LCC and PBP analyses to determine the lifetime cost of purchasing and using microwave ovens at different efficiency levels. The LCC and PBP calculations utilize an algorithm that is based on Monte Carlo simulations to incorporate uncertainties and variations into the analyses.
ovens-and-hobs-logo-png-original.jpgThis SNOPR includes an assessment of the impact of amended or new standards on the national level based on the NIA spreadsheet. The NIA model calculates the industry's net present value ("INPV") in terms of energy savings resulting from potential amended or new standards in the form of energy savings at the site and FFC energy savings.
