10 Built In Microwave Over Oven Tips All Experts Recommend
Benefits of a Built in Microwave Over Oven
A built in microwave over oven allows you to cook and heat food quickly and efficiently. GE offers a wide variety of designs, cooking technology and control options that can be adapted to your kitchen.
Built-in microwaves are installed behind cabinets or in recessed walls to give them an elegant and seamless look. These styles require professional installation.
Space Saver
The microwave is among the most used appliances in a kitchen, but it can also take up valuable counter space. There are a variety of clever ways to reclaim countertop space by moving your microwave to a different location, such as in an island in the kitchen or recessing it into the wall.
Over-the-range microwaves (OTRs) are a popular choice. Tucked away neatly above your stove, this model is particularly useful in kitchens with smaller spaces where space is at a premium. Certain OTR models can also function as an exhaust for your cooktop. This can help to reduce steam buildup.
Another option to save space is to install a built-in microwave that blends into the cabinetry. This option provides an elegant, seamless appearance that will match your kitchen's cabinets and fixtures in finish, color or design. It also helps to create a more minimalist look in your kitchen, which is great for those who prefer minimalist and clear design.
However, installing a built-in microwave might require professional installation or a renovation of your kitchen. Depending on the layout of your home you may be able to cut a space in an existing wall to accommodate the appliance, but this requires adequate framing and support and should be left to the professionals. Built-in microwaves also need adequate ventilation to prevent overheating or damaging the appliance. According to Sam Cipiti of R. M. Tunis Kitchens and Baths, in Chevy Chase, Maryland the minimum cabinet depth for an oven with built-ins is 15 inches. However certain manufacturers offer trim kits that provide up to 1 1/2 inch of additional space for ventilation.
A microwave with a drawer design can be installed under the counter or in an island. This configuration is easy-to-access, suitable for everyone and requires less counter space. It also helps to prevent hot dishes or containers from falling off the edge of the microwave or being knocked over.
The design of the door is the final factor to consider when selecting a microwave that is space-saving. A lot of brands have doors that opens in the same way as other kitchen appliances, such as dropping-down or slide-out. This lets you integrate your microwave seamlessly into your cooking workflow. Some models also have a smooth and sleek exterior that is resistant to fingerprints, giving better, cleaner appearance.
Convenience
A built-in microwave over oven has a stylish design, easy to clean and convenient. Contrary to countertop models, they're usually placed at eye level to make it easier to access and come with turntables that reduce the need to move food from plate to plate. In addition, built in oven and microwave in microwaves often come with options that increase functionality, like EasyConvection oven conversion technology, and broil elements that allow you to cook or brown foods.
In addition to reducing counter space, a built-in microwave that is atop an oven can boost your home's value and appeal by giving it a premium look that other appliances may not be capable of matching. The microwaves can be placed on top of your stove or in a separate cupboard. They seamlessly blend into the kitchen to give it a tailored appearance that shows how much you've invested in your kitchen and home.
Built in microwave over ovens are available in a broad variety of sizes as well as power levels and features to suit any kitchen configuration. Install them underneath the counter in a drawers to create an elegant look that can be easily integrated into existing cabinetry. They do not require additional space. Designed with premium finishes and high-end features These Microwaves Built In are guaranteed to complement the style of your kitchen and elevate your cooking and entertaining experience.
While microwaves built into ovens are useful, they are not as versatile as their counterparts that stand alone. Depending on where you install yours, it may require more space than other microwaves. They're also not as portable, and you can't easily switch the model should you want something different.
If you place your microwave above your range, you'll require a larger kitchen to accommodate the ventilation system required by this setup. You'll either need a ducting system that can direct smoke to the outside, or a ventilator that recirculates air from the microwave into the home. Consider a built-in microwave to small kitchens. It can be incorporated to a cabinet, wall or even an island.
Convenient Controls
Microwave ovens have various controls that are convenient depending on the model you pick. Some features are turntables, presets like defrosting or microwaves built in reheating, and buttons that can last for up to 30 minutes. Some models offer child safety features to prevent accidental use of the appliance.
Many microwaves come pre-programmed with recipes and cooking times that make the process of making food faster and easier. This feature is helpful for cooks who are new to cooking and uncertain of the proper time to heat specific foods or are not familiar with the cooking techniques used in different cuisines.
KitchenAid offers a variety of microwaves with built-ins and over-the-range microwaves that can be matched to your other appliances in style and finish for an elegant look. There's a range of stainless steel models, as well as black integrated microwave oven finishes to match any kitchen design. These premium microwaves are boldly designed to bring professional-inspired styles into your home, and they're made with high-quality materials for a longer lifespan.
Built-in microwaves, unlike countertop models, are installed in a fixed area of your walls or cabinets for sleek and distinctive appearance. The internal components are generally similar to traditional countertop models, with some exceptions. They are available in various sizes, including those made to fit in a compact space and their exteriors could feature a door that opens either in a right-to-left swing-out or drop-down style.
Some microwaves that are over-the-range like those from Whirlpool(r) are able to serve as vent hoods for your kitchen stove and use an exhaust system that is built-in to vent fumes outside and recycle air. Certain microwaves have charcoal filters that eliminate moisture and odors from your kitchen.
Countertop models are positioned on the counter of the kitchen. They don't require venting or special installation. This makes them an ideal choice for people who rent their homes or want to save money on costly changes to their kitchens. Certain models also come with trim kits to close the gap between your microwave and other countertop appliances, such as coffee pots bread makers, toaster ovens or bread ovens.
Energy Efficiency
Microwaves are more efficient in heating water and food when compared to other cooking methods. They also use less energy than conventional stovetop ovens due to the fact that they focus microwaves' energy on the liquid in the instead of heating the air or other elements around it. This means that they can heat dishes much faster than a conventional oven. They can be installed in your lower or upper cabinets, and are available with retro or modern style to match any kitchen style.
In this supplemental notice of proposed rulemaking ("SNOPR"), the Office of Energy Efficiency and Renewable Energy (DOE) proposes new or revised energy conservation standards for microwave ovens, which will save consumers money on their operating costs. The Energy Policy and Conservation Act ("EPCA") requires DOE to evaluate on a regular basis whether more-stringent standards would be economically viable and technologically feasible and could result in significant energy savings.
The SNOPR contains DOE's analyses and results to assess the impact of new or amended energy standards for microwave ovens on consumers. The analysis includes a technology and market assessment and screening analysis as well as an engineering analysis and national impacts analysis.
The energy use analysis calculates the average annual microwave oven operating hours in built microwave oven a sample of homes. This analysis is used to calculate energy savings as well as other consumer analyses within this SNOPR. The analysis is based upon RECS field data from multiple regions. It also considers different microwave oven usage patterns in different households, as also regional variations in electricity prices.
In order to assess the effects of new or amended standards on household expenses, DOE conducted LCC analyses and PBP analyses to estimate the cost over time for buying and using a micro-wave oven at different efficiency level. The LCC and PBP calculations use an algorithm based on Monte Carlo simulations to incorporate uncertainty and variation into the analysis.
In addition to the analysis of energy use and the LCC/PBP in this SNOPR includes an assessment of the national impacts of amended or new standards based on the NIA spreadsheet model. The NIA model calculates the industry's net present value (INPV) in terms of energy savings resulting from potential amended or a new standard in terms of energy savings for the site and FFC savings.
Space Saver
Convenience
Convenient Controls
Energy Efficiency
- 이전글10 Tips To Know About Window.Replacement Near Me 25.05.20
- 다음글10 Instagram Accounts On Pinterest To Follow About ADHD Diagnosis Private UK 25.05.20
