See What Built In Microwave Over Oven Tricks The Celebs Are Utilizing
Benefits of a built in microwave over oven (click4r.com)
A microwave oven that has built-in microwaves allows you to cook and reheat your food quickly and conveniently. GE provides a range of styles, cooking technologies and control options that will fit your kitchen's needs.
Built-in microwaves are placed behind cabinets or in recessed walls to give them an elegant and seamless look. These types of microwaves require professional installation.
Space Saver
The microwave is among the most commonly used appliances in a kitchen but it can take up valuable counter space. You can make use of counter space by moving the microwave to a different space, such as an island in your kitchen.
Over-the-range microwaves (OTRs) are a popular choice. This type of microwave, which is neatly tucked under the stove can be extremely useful in kitchens with a small space. Furthermore, certain OTR models can double as a vent hood for your cooktop, which is helpful in reducing steam buildup.
Another way to save space is to install a microwave with a white built in microwave oven-in design that blends in with your cabinetry. This gives you a sleek, white integrated microwave appearance that will match your kitchen's cabinets and fixtures in terms of color, finish or design. It also helps create a more streamlined appearance in your kitchen, which is perfect for homeowners who want an uncluttered and clean look.
However installing a built-in microwave could require a professional installation or renovation of your kitchen. You may be able, depending on the layout of your house to cut a hole in a wall to accommodate the appliance. However it will require professional framing and reinforcement. Built-in microwaves require ventilation to avoid overheating and damaging the appliance. According to Sam Cipiti, vice president of R. M. Tunis Kitchens and Baths in Chevy Chase, Maryland, the minimum cabinet depth for Built in Microwave Over Oven a microwave built in microwaves with grill-in is approximately 15 inches. However, some manufacturers offer trim kits that can provide up to 1 1/2 inches of extra space to let air circulate.
A microwave that is built like a drawer can be installed under the counter or Built in Microwave Over Oven in an island. This configuration is easy-to-access, suitable for all ages and requires less counter space. It can also prevent hot dishes or containers from falling off the edge or being knocked down.
The door's design is an important factor to consider when selecting a microwave that is space-saving. Many brands offer a door that opens in the same way as other kitchen appliances, like a slide-out or drop-down. This allows you to integrate your microwave seamlessly into your cooking workflow. Certain models feature a sleek, smooth exterior that resists fingerprints to give a cleaner and more attractive appearance.
Convenience
A built in microwave over oven offers an attractive design that is easy to clean and convenient. They are usually placed at eye-level for easier access and are equipped with turntables to reduce the need to move food from one plate to the next. Built-in microwaves are usually equipped with features that increase their functionality, such as EasyConvection technology for oven conversion and a broiler that can cook or brown food.
A built-in microwave over the oven will save counter space and increase the value of your home by giving it a sleek and high-end appearance that other appliances may not be able to match. These microwaves can be installed on top of your stove or in a separate cupboard. They seamlessly blend into the kitchen to give an elegant look that shows how much you've invested in your home and kitchen.
Built in microwave over ovens are available in a vast range of dimensions in terms of power levels, features and models to fit any kitchen layout. You can even install them under your counter in a drawer-style for a more integrated look that fits snugly into existing cabinets and doesn't require any additional space. Designed with premium finishes and top-of-the-line features they are sure to complement your kitchen's aesthetic and elevate your cooking and entertaining experience.
Although the built-in microwave over ovens are useful however they aren't as flexible as microwaves that stand on their own. It might require more space for your microwave to operate, depending on where it is installed. They are also not as portable, and you won't be able easily switch out the model to a new one if you decide that you want something different.
If you put your microwave above the range, you'll need an extra kitchen space to accommodate the ventilation system required by this arrangement. You'll need either a ducting system that directs smoke outside or a recirculating system that pulls the air through the microwave and into the home. For smaller kitchens, consider a separate microwave built-in that can be installed into a cabinet, wall or island.
Convenient Controls
Microwave ovens have numerous controls, depending on the model you pick. Some features are turntables, presets like defrosting or reheating, as well as buttons for plus-30 minutes. Certain models come with safety features for children to prevent accidental operation.
Many microwaves come with preset recipes and cooking times that make the process of making meals more efficient and less time-consuming. This feature is beneficial for new cooks who aren't sure how long to cook certain foods or for those who aren't familiar with the specific cooking techniques employed in various cuisines.
KitchenAid provides a variety of microwaves with built-ins and over-the-range microwaves designed to match the other appliances in design and finish to create a seamless look. There's a range of stainless built in microwave steel models, and black finishes to complement any kitchen design. These premium microwaves are boldly designed to bring professional-inspired styles into your home, and they're made with high-quality materials for a longer lifespan.
Contrary to countertop models built-in microwaves are inserted inside a fixed area of your kitchen walls or cabinets for a sleek and custom appearance. The internal components are typically similar to conventional countertop models, with a few exceptions. They are available in various sizes, including some that are designed to be able to fit in smaller spaces. Their exteriors may have a door which opens in a swing-out style from right to left or drop-down design.
Certain microwaves in the range, such as those made by Whirlpool(r), can also be used as vent hoods. They come with an exhaust system built-in to let out fumes outside and recirculate air. Some models come with a charcoal filter to remove odors and moisture from your kitchen.
Countertop models are installed on the counter in the kitchen. They don't require venting or any special installation. This makes them an ideal option for people who rent their homes or wish to avoid expensive modifications to their kitchens. Some options also come with trim kits to fill in the gap between your microwave and other countertop appliances, such as coffee pots, bread makers or toaster ovens.
Energy Efficiency
Microwaves use less energy to cook food and water than other cooking methods. They also use less power than conventional stovetops because microwaves concentrate their energy on the liquid in rather than heating the air surrounding it. They can also heat dishes much faster than conventional ovens. They can be installed either in the lower or upper cabinets, and are available in modern or retro styles to suit any kitchen.
In this additional notification of proposed rulemaking ("SNOPR") the Office of Energy Efficiency and Renewable Energy proposes new or revised energy conservation standards for microwave ovens, which will save consumers money on operating costs. The Energy Policy and Conservation Act (EPCA) requires DOE to evaluate on a regular basis whether stricter standards are technically feasible and economically justified and if they can result in significant energy saving.
This SNOPR contains DOE's analyses and results to assess the impact of the new or modified energy standards for microwave ovens on the consumer. The analysis includes a technology and market assessment screening and engineering analysis and a national impact analysis.
The energy use analysis estimates the annual average microwave ovens operating hours in representative sampled households. It forms the basis for the energy savings assessments as well as the other consumer analyses included in this SNOPR. The analysis is based on RECS field data from multiple regions. It also takes into consideration different patterns of microwave oven use in different households, as and regional variations in electricity prices.
To evaluate the impact of changes or new standards on the cost of operating a household, DOE conducted LCC and PBP analyses to estimate the cost over time of purchasing and using microwave ovens at different efficiency levels. The LCC and PBP calculations are built on the computer model that utilizes a Monte Carlo simulation to incorporate uncertainties and variations into the analysis.
This SNOPR includes an evaluation of the impact of new or amended standards at the national scale based on the NIA spreadsheet. The NIA model calculates the industry's net present value ("INPV") in terms of energy savings from possible new or amended standards in terms of energy savings at the site and FFC energy savings.
Space Saver
Convenience
Convenient Controls
Energy Efficiency
- 이전글Guide To Best Car Locksmiths Watford: The Intermediate Guide Towards Best Car Locksmiths Watford 25.05.20
- 다음글10 Websites To Help You Develop Your Knowledge About Land Rover Key 25.05.20
