10 Double Glazing Window Handles That Are Unexpected
Types of Window Handles
window locking handles handles are an important element to the overall look of your home. It's important to consider not only design but also function. There are numerous kinds of handles that are available, such as Cockspur handles, tilt-and-turn handles and Espag handles.
Espag handles are the most commonly used type of handle found in modern double-glazed windows and work with espagnolete locks that have multi-point security. They can be mounted in-line or cranked.
uPVC
uPVC is an alternative to aluminum and timber that has gained a lot of attention due to its affordable pricing. This product is not only green, but also a wise investment. It is strong, durable and weatherproof. uPVC has been tested at extreme temperatures to ensure that it doesn't fade from solar radiation. It is also resistant to corrosion and other chemicals like acids.
Window handles are generally made from uPVC. They are used to open, close, and lock your windows. They are available in a variety of styles and sizes. They are sold at a variety of hardware shops and are relatively affordable. If your windows aren't closing properly or the locks won't engage, it could be because the handle is damaged or broken. The replacement of the handle will restore your windows' functionality and also make them look amazing.
Before buying new uPVC handles, you will need to measure the backset. This measurement is the distance from the bottom of the handle's nose to the bottom of the screw plate. The most popular uPVC handle has an backset of 43mm. There is also windows that have a smaller or a larger backset based on the type of window you have. It is also important to think about whether you have a cockspur handle, or blade or spade handle. Cockspur handles feature a spindle that extends from the handle, while blade and spade handles are used with fixed windows.
If your uPVC handle is jammed, it's likely that the spindle inside the handle has been worn out. This is a frequent issue that is seen in older windows and can be fixed by replacing the handle. It is possible that the roller on the shoot bolt has separated from the handle.
Timber
If your windows are constructed out of timber, then you'll require window handles that suit this material. Sealco Scotland has a selection of handles specifically designed to work with timber frames. They are available in a range of colours and finishes so you'll be certain to find the ideal one for your home.
There are many different types of handle available for double-glazed windows made of wood that include Espag handles, Cockspur handles and tilt and turn handles. All of them are available in various styles, including designs from the past. The type of handle you choose can impact the ease with which windows can be opened and closed.
When selecting a pair of window handles, you must be aware of the step height. This is the distance from the base of the spindle to handle nose. This will help you determine if the handle can fit your blinds and avoid them from being pierced. You should also examine the spindle of your handle. This is the distance between the base of your handle and the point where the handle screws into the window frame.
Sealco Scotland has experts who can help you choose the ideal window handle for your double-glazed timber windows. Contact us today. We'll be more than happy to answer any questions you have and advise you on the best solution for your needs. You can reach us using our online form or call us at 07875 773433 to speak with one of our team members directly. Our experts can also give you advice on a broad selection of other options for windows, from hinges and glazing beads to insulation.
Aluminium
The handles of your double-glazed windows are a crucial element of the overall design of your home. The handles do not just let you open and close your windows, but also offer security by locking the window in place. This prevents intruders from breaking into your home through the windows.
Window handles are usually made from a durable material such as aluminum. They are available in a variety of different styles and colours to suit any style of home. They are also designed to withstand repeated use for long periods of time. They are available in a variety of finishes and are put on the inside of the window frame or the outside.
There are many kinds of window handles, however they can be divided into three categories which are Cockspur (also called espag) tilt and turn, and the espag. Cockspur window handle systems are latch and catch systems installed on timber, aluminium and uPVC casement windows. The handles of cockspur differ from espags in the sense that they are closed with a latch, whereas the espags close onto wedges.
Both the cockspur handle and the espag handles are designed to work with espagnolette locks. This will increase the security of your home. They are operated with a small lock inside the handle. They are a great option for older homes that have traditional glazing. They can be locked with keys as well which is particularly beneficial to ensure the safety of children.
Aluminium handles are a popular choice due to their durability and aesthetics. Available in a variety colours including grey to match any interior design. They are also less expensive than uPVC and are great for keeping your home warm by retaining the heat. They do not require painting and are easily repaired.
Cockspur
Cockspur handles are found on both timber and upvc windows. The window handles have a nose which locks and locates a plastic striker that is fixed to the frame. The cockspur handle can be deadlocked for added security. Yale Securistyle cockspur handles come in a variety of sizes to match your replacement window.
The cockspur handle is typically used on older style windows but can be installed on newer double-glazed windows too. If you are replacing a window that has a different internal mechanism and you'll need wedges to place the cockspur handle in the frame. Window wedges or cockspur wedges are a simple fix and are available in various sizes to suit your needs.
These window wedges can be attached to the frame of your replacement windows made of timber or upvc to ensure that the handle is placed in the frame. They are often supplied with a cockspur handle and are easily identified by the flat surface on the back. They can also be bought separately and are simple to install.
The cockspur handle can be installed both on the right and left doors. It is a durable handle that can be installed with either a thumb turn or key lock to give added security and privacy. The cockspur is made from high-quality materials that will endure repeated usage for a long time. It comes in various finishes to match existing hardware. This handle is suitable for timber and uPVC windows with casement. It is available with a key or thumb-turn lock.
Espagnolette
Espagnolette handles are present on a variety of double-glazed windows. They function with multi-point locking mechanisms. The spindle at the back of the handle is set inside a gearbox within the window. When it is turned by the gearbox, it moves the shootbolt, which is used to secure the perimeter around the opening window. Espagnolette handles are versatile and can be used with tilt-and-turn windows as well as traditional cock spur Windows. They come in a range of styles like cranked, offset and locking designs Peardrop, monkeytail, reeded and teardrop handles to suit both contemporary and traditional preferences.
The term "cranked" refers to the lever design being a little further away from the frame of the handle thus allowing more hand clearance against the window frame when operating. This can be a benefit in the event that the original handles were placed right up against the frame's edge, making them difficult to manipulate. These cranked designs are offered in right or left handed models based on the orientation of the windows they are being replaced on.
It is crucial to consider the different styles and types of handles that are available when replacing uPVC windows or changing the look of your home. There are many ways to make a door handle replacements or window feel more comfortable, secure and secure. There are a variety of options to suit every budget and preference, whether you prefer modern black handles or traditional charm of cast iron.
Espag handles are typically found on uPVC or old aluminium window handles double glazed window frames. They have a 7mm squared spindle which is controlled by the multi-point lock system when it is moved and can be used in conjunction with both tilt and turn as well as traditional cock spur window systems. They are very versatile, and can be used to secure various window stays.
uPVC
Timber
Aluminium
Cockspur
Espagnolette
- 이전글The Best Auto Locksmith Near Hertfordshire Tricks To Make A Difference In Your Life 25.05.20
- 다음글9 Lessons Your Parents Teach You About French Doors Luton 25.05.20
