See What Built In Microwave Over Oven Tricks The Celebs Are Using > 자유게시판
작성자 Reina Dortch
댓글 0건 조회 10회 작성일 25-05-20 13:30
Benefits of a Built in Microwave Over Oven
A microwave oven that has integrated microwave allows you to cook and reheat your food quickly and efficiently. GE offers a variety of cooking styles, cooking technology and control options to fit your kitchen's needs.
Countertop microwaves are placed on the counter and plug into outlets, while built-in models are placed in a wall with a recess or in cabinets to create an elegant, built-in appearance. These types of microwaves require professional installation.
Space Saver
The microwave is a well-loved appliance in the kitchen, but can also occupy valuable countertop space. There are plenty of smart ways to reclaim counter space by moving the microwave to a different place, like a kitchen island or recessing it into the wall.
Over-the-range microwaves (OTRs) are a popular choice. Hidden away beneath the stove, this option is especially beneficial in kitchens that are smaller and space is limited. Furthermore certain OTR models can double as a vent hood to your cooktop, which can be helpful in reducing steam buildup.
Installing a microwave best integrated microwave oven into your cabinetry will make space. This option offers an elegant, integrated design that can be matched to the style, color, or finish of your kitchen appliances and cabinets. It can also give a more streamlined look in your kitchen. This is great for homeowners that prefer a minimalist, uncluttered look.
However, installing a built-in microwave could require a professional installation or remodeling of your kitchen. Based on the layout of your home, you might be able to cut out a space within an existing wall to accommodate the appliance however, this will require adequate framing and support which should be left to the professionals. Built-in microwaves also need adequate ventilation to prevent overheating or damaging the appliance. According to Sam Cipiti of R. M. Tunis Kitchens and Baths, in Chevy Chase, Maryland the minimum cabinet depth for an oven with built-ins is 15 inches. However, some manufacturers offer trim kits that give up to 1 1/2 inch of additional space for ventilation.
aeg-built-in-microwave-mbe2658sem-26l-capacity-900w-auto-weight-defrost-programmes-digital-display-5-power-levels-touch-activated-door-easy-clean-clock-timer-black-stainless-steel-4948-small.jpgA microwave that is built like a drawer can be set up beneath your counter or within an island. This design is easily accessible, suitable for all ages and requires less counter space. It also helps to prevent hot dishes or containers from falling off the edge of the microwave or getting crushed.
A final consideration for an efficient microwave is its door design. There are many brands that have an open, swing-out or Built in Microwave Over Oven slide-out door that opens using the same motion as other kitchen appliances to allow you to seamlessly integrate your microwave into your cooking process. Some models have an elegant, smooth exterior that resists finger prints for better and cleaner appearance.
Convenience
Built-in microwaves in ovens are attractive, convenient, and easy to clean. Unlike countertop models, they're usually placed at the eye level for easy access and can be equipped with turntables that eliminate the necessity of constantly shifting food from plate to plate. In addition, built in oven and microwave in microwaves are often equipped with features that improve functionality, such as EasyConvection oven conversion technology and broiling elements that allow you to brown or crisp food items.
In addition to reducing counter space, a built in microwave over the oven can improve the value of your home as well as appearance by offering a luxurious appearance that other appliances might not be able to match. If it's installed above the stove or in a separate cabinet these microwaves blend seamlessly into your kitchen, creating an elegant appearance that shows you've put in the time to improve your kitchen and your home.
Built-in microwaves over ovens are available in a vast variety of dimensions in terms of power levels, Built in Microwave Over Oven features and models to match any kitchen configuration. You can even install them under your counter in a drawer-style to create a more seamless design that is a perfect fit into existing cabinetry and doesn't require any additional space. Made with top-quality finishes and features, these microwaves are sure to complement the style of your kitchen and enhance your cooking and entertaining experience.
While the convenience of a built-in microwave over oven is clear, keep in mind that these microwaves aren't as versatile as their freestanding counterparts. It might require more space to operate, depending on the location it's installed. Similarly, they aren't as portable, and you won't be able to easily swap out the model to a new model if you prefer something different.
If you put your microwave above your range, you'll require an additional kitchen space to accommodate the ventilation system required by this arrangement. You'll need either a ducting system that carries smoke to the outside or a recirculating system that pulls the air through the microwave and into the home. If you have a smaller kitchen you might want to consider a separate built-in microwave that can be incorporated in the wall, cabinet or island.
Convenient Controls
Microwaves offer a wide variety of controls depending on the model. The most common features are turntables, preset functions including defrosting and reheating and 30 second buttons. Certain models include child safety features to prevent accidental operation.
Many microwaves have pre-programmed recipes and cooking times, which makes the process of preparing food faster and easier. This feature is beneficial for new cooks who aren't sure of the time to cook certain foods or for those who aren't comfortable with the specific cooking methods that are used in different cuisines.
KitchenAid provides a variety of built-in microwaves as well as over-the-range microwaves that are designed to match your other appliances with style and design to create an elegant look. You can find a selection of stainless steel models and black finishes to complement any kitchen design. These premium microwaves are boldly designed to bring professional-inspired styles into your home, and they're made with high-quality materials for a longer lifespan.
Unlike countertop models built-in microwaves are inserted inside a fixed area of the kitchen cabinets or walls for a sleek, custom appearance. The internal components are usually identical to those of regular countertop models with a few exceptions. They are available in various sizes, and some are designed to be able to fit in small spaces. The exteriors of these models may feature a door which opens in a swing-out from left to right or in drop-down design.
Some microwaves that are over-the-range like those made by Whirlpool(r) are able to double as vent hoods for your kitchen stove and use an exhaust system that is built-in to let fumes out and recirculate air. Some models come with a charcoal filter to remove moisture and odors from your kitchen.
cookology-bm20lnb-built-in-integrated-20-litre-microwave-oven-24-5cm-turntable-with-autocook-menu-auto-defrost-function-and-a-child-lock-in-black-4954-small.jpgCountertop models sit on your kitchen counter and don't require venting hookups or special installation, making them a great option for rental properties or anyone who wants to stay clear of costly renovations to their kitchens. Certain models come with trim kits that can be used to fill the gap between a microwave and other countertop appliances, such as coffee pots, toaster ovens or bread makers.
Energy Efficiency
Microwaves consume less energy to cook water and food than other cooking methods. They also use less power than stovetops that are conventional because microwaves concentrate their energy on the liquid inside instead of heating the air around it. They can cook food faster than conventional ovens. They can be placed in the lower or upper cabinets and are available in modern or retro styles to match any kitchen.
In this supplemental notice of proposed rulemaking ("SNOPR") the Office of Energy Efficiency and Renewable Energy proposes new or modified energy conservation standards for microwave ovens which will help consumers save money in their operating costs. The Energy Policy and Conservation Act ("EPCA") requires DOE to examine on a regular basis whether the more stringent standards are economically viable and technologically feasible and could result in significant energy savings.
This SNOPR contains DOE's analyses and findings to assess the impact of the new or modified energy standards for microwave ovens on consumers. The analysis includes a market and technology assessment as well as a screening analysis as well as an engineering analysis and national impact analysis.
The energy use analysis calculates the annual average of microwave oven operating hours in homes that have been sampled for representativeness. This analysis is used to calculate energy savings as well as other consumer analysis within this SNOPR. The analysis is built on RECS field data from a variety of regions and considers the different usage patterns of combination microwave oven built in ovens in various households and the variations in electricity prices across the region.
To determine the impact of possible changes or new standards on household operating costs, DOE conducted LCC and PBP analyses to estimate the lifetime cost of purchasing and using microwave ovens at different efficiency levels. The LCC and PBP calculations use an algorithm that is based on Monte Carlo simulations to incorporate uncertainty and variation into the analyses.
This SNOPR includes an analysis of the impact of amended or new standards at the national level, based on the NIA spreadsheet. The NIA model calculates the industry's net present value ("INPV") in terms of energy savings resulting from possible new or amended standards in terms of site energy savings and FFC energy savings.
