Learn The Built In Microwave Over Oven Tricks The Celebs Are Using > 자유게시판
작성자 Rachel
댓글 0건 조회 6회 작성일 25-05-20 12:04
Benefits of a built in microwaves with trim kits (blevins-villarreal.technetbloggers.de) in Microwave Over Oven
A built in microwave over oven helps you cook and heat food quickly and efficiently. GE offers a variety of designs, cooking techniques and control options that will fit your kitchen setup.
Built-in microwaves are positioned behind cabinets or in recessed walls to give them a sleek and integrated look. These styles require professional installation.
Space Saver
The microwave is among the most frequently used kitchen appliances however, it can take up valuable counter space. You can reclaim valuable counter space by moving the microwave to a different location, like an island in the kitchen.
One of the most well-known options is an over-the-range (OTR) microwave. Tucked away neatly above the stove, this option is particularly useful in kitchens with smaller spaces where space is at a premium. Certain OTR models can also be used as an exhaust for your cooktop. This can reduce the buildup of steam.
Another space-saving solution is to install a built-in microwave which blends seamlessly into your cabinetry. This can give you an elegant, integrated design that is able to match the color, finish or style of your kitchen appliances and cabinets. It can also to create a more minimalist look in your kitchen, which is perfect for homeowners who prefer minimalist and clear design.
Installing a built-in microwavable might require an expert installation or kitchen remodel. Depending on your home's layout, you might be able to cut a space in walls to accommodate the appliance however, this requires adequate framing and home improvement support and should be left to the professionals. Also, built-in microwaves require sufficient ventilation to prevent overheating and damage the appliance. According to Sam Cipiti, vice president of R. M. Tunis Kitchens and Baths in Chevy Chase, Maryland, the minimum cabinet depth for a microwave built-in is around 15 inches, however certain manufacturers offer trim kits that offer up to 1 1/2 inches of additional space for ventilation.
A microwave with a drawer design can be placed beneath your counter or within an island. This configuration is easy-to-access, suitable for all and requires less counter space. It can also help avoid hot dishes or containers from falling off the edge of the microwave or being knocked over.
cookology-bm20lnb-built-in-integrated-20-litre-microwave-oven-24-5cm-turntable-with-autocook-menu-auto-defrost-function-and-a-child-lock-in-black-4954-small.jpgThe door design is the final factor to consider when selecting a microwave that is space-saving. Many manufacturers offer an open, swing-out or slide-out door that opens with the same motion as other kitchen appliances, allowing you to seamlessly integrate your microwave into your cooking workflow. Some models also have a smooth and sleek exterior that resists fingerprints for better, cleaner appearance.
Convenience
Built-in microwaves that are built into ovens are stylish, convenient and easy to clean. Unlike countertop models, they're usually at the eye level for easy access and come with turntables that eliminate the need to constantly shift food from plate to plate. Built-in microwaves are often equipped with features that improve their functionality, such as EasyConvection technology for oven conversion and a broiler component that can crisp or brown food items.
A built-in microwave on top of the oven can save you counter space, and can also boost the value of your home by giving it a sleek, high-end appearance that other appliances may not be able match. The microwaves can be placed above the stove, or in a separate cabinet. They seamlessly blend into the kitchen, giving it a tailored appearance that demonstrates how much you've invested in your kitchen and home.
Built in microwave over ovens are available in a broad variety of sizes in terms of power levels, features and models to match any kitchen configuration. You can even put them under your counter in a drawer-style to give a more cohesive design that is a perfect fit into existing cabinetry and requires no additional space. Made with top-quality finishes and features, these microwaves are sure to complement your kitchen's aesthetic and enhance your cooking and entertaining experience.
While the benefits of a built-in microwave oven is evident however, you should be aware that these microwaves aren't as versatile as their freestanding counterparts. Depending on where you install yours, it may require more space than other types of microwaves. They are also not as portable, and you cannot easily switch the model should you want something different.
If you decide to place the microwave on top of your range, then you'll need a larger space in your kitchen to accommodate the ventilation required in this setup. You'll need either an ducting system that sends smoke outside or a recirculating system that pulls air through the microwave before transferring it to the home. For smaller kitchens think about a separate built-in microwave that can be installed inside the wall, cabinet or island.
Convenient Controls
Microwaves come with a variety of controls depending on the model. Some common features include turntables, preset functions including defrosting and reheating, and plus-30-second buttons. Some models have child safety features that prevent accidental operation of the appliance.
Many microwaves have pre-programmed recipes and cooking times, which make the process of cooking food quicker and more efficient. This feature is useful for cooks who are new to cooking and not sure of the time needed to heat specific foods or who are unfamiliar with the specific cooking techniques employed in various cuisines.
KitchenAid brand offers a wide selection of built-in and over the-range microwaves that are designed to complement the style and finish of your other appliances for an aesthetically pleasing kitchen. There's a range of stainless steel built in microwave steel models, as well as black integrated microwave and white finishes to match any kitchen design. These premium microwaves are boldly designed to bring professional-inspired styles into your home, and they're made with high-quality materials for a longer lifespan.
Built-in microwaves, unlike countertop models, are set in a fixed area of your kitchen cabinets or walls to give an elegant and unique look. They typically have the same internal components as regular countertop models, with some exceptions. They are available in various sizes, including those designed to fit into a small space, and their exteriors may have doors that open either in a right-to-left swing-out or drop-down style.
Some over-the-range microwaves like those from Whirlpool(r) are able to double ovens with built in microwave as vent hoods for your kitchen stove. They have an exhaust system that is built-in to let fumes out and circulate air. Some models come with a charcoal filter to remove odors and moisture from your kitchen.
Countertop models sit on the counter in your kitchen and do not require venting hookups, or special installations which makes them a great option for rental homes or those who want to stay clear of costly renovations to their kitchens. Some models include trim kits that can be used to fill the gap between the microwave and other countertop appliances, such as coffee pots, toaster ovens or bread makers.
Energy Efficiency
Microwaves consume less energy to cook water and food than other cooking methods. They also use less power than conventional stovetops because microwaves concentrate their energy on the liquid in rather than heating the air surrounding it. They can heat up dishes quicker than conventional ovens. They can be put in in the lower or upper cabinets, and are available in modern or retro styles to match any kitchen.
In this supplemental notice of proposed rulemaking ("SNOPR"), the Office of Energy Efficiency and Renewable Energy (DOE) proposes new or revised energy conservation standards for microwave ovens that will save consumers money on their operating costs. The Energy Policy and Conservation Act (EPCA) requires DOE to periodically assess whether more stringent standards are technologically feasible and economically viable and will yield significant energy savings.
This SNOPR contains the analyses and findings that DOE carried out to assess the impact on consumers of new or revised energy conservation standards for microwave ovens. The analysis includes a technology and market assessment and screening analysis, an engineering analysis and national impacts analysis.
cookology-im20lss-integrated-microwave-800w-built-in-microwave-60cm-20l-8-auto-cooking-presets-child-lock-stainless-steel-4934-small.jpgThe energy usage analysis estimates the annual average of microwave oven operating hours in a sample of homes. It is the basis for the energy savings assessments as well as the other consumer analyses included in this SNOPR. The analysis is based on RECS field data from multiple regions and considers the different usage patterns of microwave ovens in different households, as well as the variations in the regional electricity prices.
To assess the impact of new or amended standards on household expenses, DOE conducted LCC analyses and PBP analyses to estimate the lifetime cost for purchasing and using a micro-wave oven at different efficiency level. The LCC and PBP calculations are built on an algorithm for computer models that employs a Monte Carlo simulation to incorporate uncertainty and variation into the analysis.
In addition to the analyses of energy use and LCC/PBP in this SNOPR contains an evaluation of the national impacts of the new or amended standards that are based on the NIA spreadsheet model. The NIA model calculates the industry's net present value ("INPV") in terms of energy savings resulting from the potential amendment or new standards in the form of site energy savings and FFC energy savings.
