CBD Heat Roll On Pain Relief Cream
$24.99
– $39.99
Drug Facts:<\/strong> Active Ingredients Natural Menthol 4.0%
Uses:<\/strong> Warming temporary relief to areas that need it most.<\/p>
Warnings:<\/strong> For external use only. Avoid damaged skin, wounds, eyes, or mucous membranes. If swallowed, get medical help or contact a Poison Control Center right away. Do not use if pregnant, nursing or taking any medications.
Suggested Use:<\/strong> Apply a small amount to the affected area with a gentle, circular motion until dry. Use every 4-6 hours or as needed. 18 years or younger: ask a doctor.<\/p>
Inactive Ingredients:<\/strong> Hemp Extract cannabidiol oils (CBD), Organic Aloe Leaf Juice, Meadow-foam Seed Oil, Menthol Crystals, Capsicum Fruit Oleoresin, White Camphor Bark Oil, Sweet Basil Leaf Oil, Black Pepper Oil, Roman Chamomile Flower Oil, German Chamomile Flower Oil, Cinnamon Leaf Oil, Citronella Oil, Eucalyptus Leaf Oil, Helichrysum Flower Oil, Ginger Root Oil, Pink Grapefruit
Peel Oil, Juniper Berry Oil, Lemon-grass Oil, Peppermint Oil, Pine Needle Oil, Ravensara Oil, Rose-mary Leaf Oil, Spearmint Oil, Wild Oregano Oil, Glycerin, Witch Hazel Water, Organic Alcohol, Phenoxy-ethanol, Carbomer, Triethanolamine,Tetrasodium Glutamate Diacetate.<\/p>
Caution:<\/strong> Do not exceed the suggested amount. This product is intended for use by healthy adults 18 years and over. Keep out of reach of children. Cannabidiol (CBD*) use while pregnant or breastfeeding may be harmful. Consult a healthcare professional prior to use if you are pregnant, nursing, taking any medication or have any medical condition. Discontinue use immediately if any adverse reactions occur and consult your physician. The Food and Drug Administration has not evaluated this product for safety or efficacy. There is no current dardized CBD* testing methodology for verifying CBD* content. We make available our product testing reports, upon which we base the CBD* amount, to our customers, but test results may vary by individual laboratory and \/ or test method.<\/p>
The results of our testing are available on our website and by scanning the QR code on the package. This product contains a total delta-9 tetrahydrocannabinol (THC) that does not exceed 0.3% on a dry-weight basis. Drug tests vary in sensitivity and you may test positive for THC when taking CBD products. Natural color variations may occur in this product. The amount of mg \/CBD may vary by dose and by the package. May cause drowsiness
<\/p>
<\/div>Read more<\/a><\/p>
","variation_id":7535328,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/A","has_lab_report":true},{"attributes":{"attribute_pa_size":"1500mg"},"availability_html":"
Inactive Ingredients:<\/strong> Hemp Extract Cannabidiol (CBD), Organic Aloe Leaf Juice, Meadow-foam Seed Oil, Menthol Crystals, Capsicum Fruit Oleoresin, White Camphor Bark Oil, Sweet Basil Leaf Oil, Black Pepper Oil, Roman Chamomile Flower Oil, German Chamomile Flower Oil, Cinnamon Leaf Oil, Citronella Oil, Eucalyptus Leaf Oil, Helichrysum Flower Oil, Ginger Root Oil, Pink Grapefruit Peel Oil, Juniper Berry Oil, Lemon-grass Oil, Peppermint Oil, Pine Needle Oil, Ravensara Oil, Rose-mary Leaf Oil, Spearmint Oil, Wild Oregano Oil, Glycerin, Witch Hazel Water, Organic Alcohol, Phenoxy-ethanol, Carbomer, Triethanolamine, Tetrasodium Glutamate Diacetate.<\/p>
","variation_id":7535329,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/A","has_lab_report":true}]">
Nothing relaxes the muscles like some good ol’ heat, but we don’t always have the time for a nice luxurious bath.
Luckily, this CBD cream combines the therapeutic benefits of natural heat with CBD to loosen and soften the muscles. And to make it that much easier, we packed into a roll-on for the utmost convenience of use.
Hit the "pause" button and melt into this blend’s heat-generating magic with the help of cinnamon, ginger, and pepper, and feel your muscles go "ahhhh" as the menthol kicks in to create a cooling, soothing effect. And the best part? You’ll never have to worry about getting any of it on your hands!
Whether your joints are strained and stiff from a day at the office, or overworked from a tough workout, this CBD roll-on gives you the relief you need, fast.
This formula is vegan, fast-absorbing, and quick-drying.
Plant-Powered 350mg CBD* HEAT RELIEF GEL ROLL-ON *87% Organic Content, Parabens, Phthalates & Gluten Free.
Description
This CBD Relief cream combines the therapeutic benefits of natural heat with CBD to loosen and soften the muscles. With the help of cinnamon, ginger, and pepper to heat as well as menthol to create a cooling, soothing effect.
This formula is vegan, fast-absorbing, and quick-drying. Plant-Powered 15000mg CBD* HEAT RELIEF GEL ROLL-ON *87% Organic Content, Parabens, Phthalates & Gluten Free.
*Vegan *Long Lasting *Quick Drying *Keeps Hands Clean
Additional information
350mg, 1500mg
FAQ
Researchers have found that CBD topicals may be helpful for joint tension, and it’s been theorized that it works by targeting the CB1 receptors in the local area, which helps it target specific areas in the body.
CBD cream is becoming increasingly easy to find in person, but it’s still not available everywhere. If you can’t find any CBD creams in your local area, online sellers may still be your best bet. Make sure to shop from reputable sellers that practice third-party testing, and clearly label their products.
CBD cream is a topical that’s infused with CBD, and it’s meant to target tension in the joints and soreness in the muscles.
For those who are using CBD cream to relieve some tension, many users report success from applying CBD cream to the temples.
The time it takes for CBD to kick in will typically vary with each user, but generally, it takes around 15-30 minutes.
When looking for a CBD cream, it’s always recommended to go for the potent products
Depending on how much you apply at a given time, CBD cream generally lasts around 30 uses.
When stored properly, CBD creams can have a shelf life that lasts many months. Always make sure to store in a cool, dry place out of direct sunlight, and always apply with clean hands.
RELATED PRODUCTS
CBD Relief Cream
CBD Roll-On Freeze Cream
CBD+THC Ultra Relief Gel with Menthol 4oz
Ultra Relief CBD Gel
25 First Ave. SW STE A
Watertown, SD 57201
This product is not for use by or sale to persons under the age of 18. This product should be used only as directed on the label. It should not be used if you are pregnant or nursing. Consult with a physician before use if you have a serious medical condition or use prescription medications. A Doctor’s advice should be sought before using this and any other supplement. All trademarks and copyrights are property of their respective owners and are not affiliated with nor do they endorse this product. These statements have not been evaluated by the FDA. This product is not intended to diagnose, treat, cure or prevent any disease. By using this site, you agree to follow the Privacy Policy and all Terms & Conditions printed on this site. Void Where Prohibited by Law. Our products contain less than 0.3% THC.
JustCBD Florida Only Website
Welcome! You must be 21+ to enter this site.
Please enter your date of birth.
- 이전글List Of The Best Betting Websites In Uganda ⫸ All About Online Sports Betting And Critiques Of Bookmaking Companies 25.03.29
- 다음글Best Sports Betting Sites In China For 2025 25.03.29
