What Is Built In Microwave Over Oven? History Of Built In Microwave Over Oven In 10 Milestones > 자유게시판
What Is Built In Microwave Over Oven? History Of Built In Microwave Ov…
작성자 Demetrius
댓글 0건 조회 5회 작성일 25-05-20 08:38
Benefits of a Built in Microwave Over Oven
A built in microwave over oven helps you cook and heat food quickly and conveniently. GE offers a variety of designs, cooking techniques and control options that will fit your kitchen setup.
Countertop microwaves sit on the counter and plug into an outlet and built-in models are installed on a recessed wall or among cabinets for an elegant, built-in appearance. These models require professional installation.
Space Saver
The microwave is among the most commonly used kitchen appliances but it can consume valuable counter space. There are many smart ways to free up countertop space by moving your microwave to a different location, such as in the kitchen island or by recessing it into the wall.
Over-the-range microwaves (OTRs) are a popular option. It is tucked away in a neatly placed above your stove, this option can be especially useful in smaller kitchens where space is at a premium. Some OTR models also double as an exhaust for your cooktop. This can help to reduce steam buildup.
Another option to save space is to install a built-in microwave which blends seamlessly into your cabinetry. This can give you a sleek, integrated appearance that can match the kitchen cabinets and fixtures in finish, color, or style. It can also create a more streamlined appearance in your kitchen, which is great for homeowners who want minimalist and clear design.
Installing a built-in Microwave could require a professional installation or a kitchen remodel. It is possible, depending on the layout of your house to make a hole in a wall to accommodate the appliance. However, this will require professional framing and support. Also, built-in microwaves require sufficient ventilation to prevent overheating and damaging the appliance. According to Sam Cipiti of R. M. Tunis Kitchens and Baths, in Chevy Chase, Maryland the minimum cabinet depth of a built in microwave oven combo-in oven is 15 inches. However some manufacturers offer trim kits that provide up to 1 1/2 inches of extra space for ventilation.
A microwave with a drawer design can be placed under your counter or inside an island. This type of microwave is simple to use, suitable for all users and requires less countertop space. It can also help avoid hot dishes or containers from falling off the edge of the microwave or getting knocked over.
The final aspect to consider for the space-saving microwave is the door design. Many brands offer the option of a swing-out, drop-down, or slide-out door that opens in the same motion as other kitchen appliances to help you seamlessly integrate your microwave into your cooking process. Some models also feature a sleek and smooth exterior that is resistant to fingerprints, giving better, cleaner appearance.
Convenience
hotpoint-31l-1000w-built-in-microwave-and-grill-stainless-steel-4979-small.jpgBuilt-in microwaves over ovens look attractive, practical, and easy to clean. They are typically placed near the eye level to make it easier to access and come with turntables to make it less necessary to move food from one plate to the next. Additionally, built in oven and microwave-in microwaves are often equipped with features that enhance functionality like EasyConvection oven conversion Innovative Technology and a broil element that allows you to cook or brown food items.
A built in microwave for 600mm wall unit-in microwave that is integrated into the oven can help you save counter space and increase the value of your home by giving it a sleek and high-end appearance that other appliances may not be able to match. They can be set up either above your stove, or in a separate cabinet. They blend seamlessly into the kitchen, giving it a tailored appearance that shows how much you have invested in your home and kitchen.
Built-in microwaves and ovens are available in a wide variety of sizes as well as power levels and features to fit any kitchen layout. They can be placed under your counter in a drawer-style for a more integrated design that is a perfect fit into your cabinetry and Keep Reading doesn't require any additional space. These microwaves, with their high-end finishes and high-end functions will enhance the look of your kitchen and your cooking and entertaining experience.
While the convenience of a built in microwave over oven is clear however, you should be aware that they aren't as efficient as their freestanding counterparts. Depending on the place you install yours, it may require more space to operate than other microwaves. They're also not as mobile, and you aren't able to easily alter the model if you need something different.
If you place your microwave above the range, you'll need an additional kitchen space to accommodate the ventilation system required by this configuration. You'll need an option for ducting that directs smoke to the outside, or a ventilation system that recirculates air through the microwave and into the house. If you have a smaller kitchen you might want to consider an additional built-in microwave which can be fitted in cabinets, walls or an island.
Convenient Controls
Microwave ovens are equipped with numerous controls depending on the model you pick. The most common features are turntables, preset functions such as defrosting and reheating, and 30-second buttons. Certain models come with safety features for children that stop accidental operation of the appliance.
Many microwaves come with pre-programmed recipes and cooking times, which make the process of making food faster and simpler. This feature is useful for cooks who don't know how long to cook certain meals or for those who aren't familiar with the specific cooking techniques used in different cuisines.
KitchenAid offers a range of microwaves with built-ins and over-the-range microwaves that can be matched to your other appliances in style and finish for seamless appearance. There's a variety of stainless steel models as well as black and white built in microwave oven finishes to complement any kitchen design. These premium microwaves are boldly designed to bring professional-inspired styles into your home, and they're made with high-quality materials for a longer lifespan.
Built-in microwaves, unlike countertop models, are set in a fixed location of your walls or cabinets for a sleek and custom look. The internal components are usually identical to those of conventional countertop models, with the exception of. These models are available in various sizes, with some designed to fit into a smaller space, and their exteriors may feature a door that opens either in a left-to right swing-out or drop-down fashion.
Certain microwaves over the range like those made by Whirlpool(r) are able to double as vent hoods to your kitchen stove and use an exhaust system built-in to exhaust fumes outside and circulate air. Certain microwaves have charcoal filters that get rid of odors and moisture in your kitchen.
Countertop models can be placed on your kitchen counter and don't require venting hookups or special installation which makes them a great choice for rental homes or those who want to avoid costly changes to their kitchens. Certain models include trim kits that can be used to close the gap between a microwave and other countertop appliances such as coffee pots, toaster ovens or bread makers.
Energy Efficiency
Microwaves use less energy to cook food and water than other cooking methods. They also consume less power than stovetops that are conventional because microwaves concentrate their energy on the liquid inside rather than heating the air surrounding it. Because of this, they can cook food more quickly than a conventional oven. They can be placed in the upper or lower cabinets, and are available with retro or contemporary styles to match any kitchen style.
In this notice of proposed rulemaking ("SNOPR"), the Office of Energy Efficiency and Renewable Energy (DOE) proposes new or amended energy conservation standards for microwave ovens that will reduce the cost of operating costs. The Energy Policy and Conservation Act (EPCA) requires DOE to regularly assess whether more stringent standards are technically feasible and economically viable and if they can result in significant energy savings.
This SNOPR includes the analyses and findings that DOE performed to evaluate the impact on consumers of new or securityholes.science post to a company blog amended energy conservation standards for microwave ovens. The analysis includes a market and technology assessment screening and engineering analysis, and an analysis of the national impact.
The energy usage analysis calculates the average annual microwave oven operating hours in the sample of households. It forms the basis for the energy savings analyses and the other consumer analyses included in this SNOPR. The analysis is based on RECS field data from various regions. It also considers the different patterns of use of microwave ovens in different households, as also regional variations in electricity prices.
To evaluate the impact of changes or new standards on the cost of operating a household, DOE conducted LCC and PBP analyses to determine the lifetime cost of buying and using microwave ovens at various efficiency levels. The LCC and PBP calculations utilize the computer model based on Monte Carlo simulations to incorporate variations and uncertainty into the analyses.
In addition to the analysis of energy use and the LCC/PBP, this SNOPR contains an evaluation of the national impacts of new or amended standards that are based on the NIA spreadsheet model. The NIA model estimates the industry's net present value ("INPV") in terms of energy savings resulting from the potential amendment or new standards in the form of energy savings at the site and FFC energy savings.
