GHB and Heart Health: A Warning > 자유게시판
뒤로가기 자유게시판
작성자 Elaine 작성일 25-05-20 06:42 조회 58 댓글 0
This substance, gamma-hydroxybutyric acid, is used illicitly for its sedative effects and euphoria, but has unpleasant side effects
This illegal substance has gained favor over the years for its euphoric effects
But GHB is also known to have severe effects on the cardiovascular system
ghb bestellen's recreational use can lead to low blood pressure, a condition caused by enlarged blood vessels
This can be alarming, especially for those with pre-existing hypertension or cardiovascular disease
Hypertension is a major risk factor for cardiovascular disease
The substance causes a slower heartbeat, which can be a problem
However, in some individuals, this can lead to a severe drop in heart rate, or bradycardia
Abnormal heartbeats, palpitations, and fainting spells can be life-threatening side effects
Abnormal heart rhythms are a concern with GHB use
Water buildup can exacerbate cardiovascular disease and lead to other problems
Given the severity of these cardiovascular side effects, it is essential to understand the risks associated with GHB use
Heavy use can lead to long-term damage, including damage to the heart's structure and function
The risk of heart failure increases with regular GHB use
People with pre-existing heart conditions should avoid GHB use
Stop using GHB if you experience heart problems
Awareness about GHB's cardiovascular side effects can encourage safer behaviors
댓글목록 0
PC 버전으로 보기
