Delta 8 Gummies Exotic Peaches 250mg > 자유게시판
작성자 Mike
댓글 0건 조회 2회 작성일 25-05-19 21:45
$17.99 $24.99
Corn Syrup (From Corn), Corn Starch, Sugar (From Beets), Water, Gelatin, Citric Acid, Fumaric Acid, Natural and Artificial Flavor, FD&C Yellow #5, FD&C Red #40, Coconut Oil, Delta-8 THC Hemp derivate.
SUPPLEMENT FACTS<\/strong>
Servings: Approx. 10, Serving Size: 1 pcs. (7g), Approx. 25mg Delta8 per gummy. Amount per Serving: Calories: 25, Total Fat: 0g (0% DV), Saturated Fat: 0g (0% DV), Trans Fat: 0g (0% DV), Cholesterol: 0mg (0% DV), Sodium: 15mg (1% DV), Total Carbohydrate: 6g (2% DV), Dietary Fiber 0g (0% DV) Total Sugars: 5g, Added Sugars: 5g (1% DV), Protein: 1g (0% DV), Vit. D: 0mcg (0% DV), Calcium: 0mg (0% DV), Iron: 0mg (0% DV), Potassium: 0mg (0% DV) *Percent daily values based on 2000 calorie diet.<\/p>
SUGGESTED USE<\/strong>
Do not exceed 1 gummy every 8 hours.
All users may not react the same to product use. The onset of effects may be experienced at different times. First time users may experience stronger effects. DO NOT EXCEED SUGGESTED USE.<\/p>
CONTAINS<\/STRONG>
Tree Nuts (Coconuts). Wheat & Traces of milk.<\/p>
CAUTION<\/strong>
This is not cbd distributors. Keep out of reach of children. This product is intended for use by healthy adults age 21 years and over. Consult a healthcare professional prior to use of delta-8 tetrahydrocannabinol (Delta-8 THC ). Delta-8 THC may be harmful if you are pregnant, nursing, taking any medication or have a medical condition. Discontinue use immediately if adverse reaction occurs and consult your physician. Food and drug administration has not evaluated this product for safety or efficacy. There is no current standardized Delta-8 THC methodology for verifying content. We make available our product testing reports on our website and by scanning the QR code on the packaging. Our Delta-8 THC serving size potencies are determined by a laboratory. Test Results may vary by laboratory or test method. This product contains less than 0.3% total delta-9 tetrahydrocannabinol (Delta-9 THC). Drug tests vary in sensitivity and you may test positive for Delta-9 THC when taking Delta-8 THC products. Natural color variations may occur in these products. Amount of mg \/ Delta-8 THC may vary by piece and by package. May cause Drowsiness. When taken in, access THC may cause anxiety, paranoia. Do not operate a vehicle or heavy machinery while consuming Delta 8 THC.
This product is not intended to diagnose, treat, cure, or prevent any disease.<\/p>
<\/div>Read more<\/a><\/p>
","variation_id":7589882,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/A","has_lab_report":false}]">
Is there anything more mouth-watering than a fresh, juicy peach?
Apparently…yes.
Our delta 8 gummies were made to give you a sweet experience for your entire body, starting on the palate. Our gummies combine sweet, peachy goodness with the satisfying chew of a gummy.
Description
Additional information
250mg
FAQ
The right delta 8 gummy potency will ultimately depend on the person. While some may need a 30 mg gummy, plenty of others will feel it enough after half of a 10 mg gummy. This is why it’s important to start out with a low dosage when trying delta 8 for the first time.
Delta 8 gummies have a psychoactive effect that will leave the user feeling high, but the high is not as intense as a delta 9 gummy of the same dosage.
Many report delta 8 giving them a stimulating-effect that can induce focus and creativity, so any kind of delta 8 gummy could be worth trying, as long as they don’t have ingredients meant to assist with sleep, like melatonin or GABA.
The time it takes for delta 8 gummies to kick in depends on the individual, but it generally takes between 45 minutes and three hours.
As a compound shown to help encourage relaxation, some individuals report better sleep when taking delta 8 gummies. But in some cases, delta 8's have been reported to induce a gentle buzz, so this may depend on the individual.
Currently, delta 8 is banned in the following states: Alaska, Arizona, Arkansas, Colorado, Connecticut, Delaware, Kentucky, Idaho, Iowa, Michigan, Mississippi, Montana, New York, North Dakota, Rhode Island, Utah, Vermont, and Washington.
The best delta 8 is going to come from the best hemp, made with the best processing methods. We source our delta 8 from the best hemp farms in the country, and we use CO2 extraction methods with state-of-the-art equipment. All batches are third-party tested, and COAs are readily available on our website.
At this time, delta 8 is interpreted from the language of the Farm Bill as legal. However, some states have banned it.
There is still not enough information to prove that delta 8 can work for pain relief. If you’re seeking to treat chronic pain with delta 8, please do so under the guidance of a doctor.
Delta 8 gummies are known to create a steady, mellow high that can last in the user’s system for several hours.
RELATED PRODUCTS
Delta 8 Gummies Blue Drops (BOGO SALE)
Haze Brain Stew Delta 9 Gummies – Hybrid
Delta 8 Gummies Red Drops (BOGO SALE)
Delta 8 Sour Bears
Delta 8 Gummies Watermelon Supernova
Delta 8 Gummies Rainbow Drops (BOGO SALE)
Delta 8 Sour Blockheads
25 First Ave. SW STE A
Watertown, SD 57201
Products on this site contain a value of 0.3% or less Δ9THC (or no more than 0.3% Δ9THC). FDA Disclosure: This product is not for use by or sale to persons under the age of 21 depending on the laws of your governing state or territory. This product should be used only as directed on the label. It should not be used if you are pregnant or nursing. Consult with a physician before use, especially if you have a medical condition or use prescription medications. A doctor's advice should be sought before using any of these products. All trademarks and copyrights are property of their respective owners and are not affiliated with nor do they endorse this product. These statements have not been evaluated by the FDA. These products are not intended to diagnose, treat, cure or prevent any disease. By using this site you agree to follow the Privacy Policy and all Terms & Conditions printed on this site. Void Where Prohibited By Law.
Autoship powered by qpilot.svg
