See What Built In Microwave Over Oven Tricks The Celebs Are Using
Benefits of a Built in Microwave Over Oven
A built in microwave over oven helps you cook and heat food quickly and efficiently. GE provides a variety of designs, cooking technology and control options to fit your kitchen.
Built-in microwaves are installed behind cabinets or in recessing walls to give them a a sleek and integrated look. These types of microwaves require professional installation.
Space Saver
The microwave is a common appliance in the kitchen, however it can also take up valuable countertop space. You can make use of counter space by moving the microwave to another space, such as an island in the kitchen.
Over-the-range microwaves (OTRs) are an increasingly popular choice. This option is tucked away above your stovetop is particularly helpful in kitchens that are small and have little space. Certain OTR models also double as an air vent for your cooktop. This can help reduce the amount of steam that builds up.
Installing a microwave that is integrated into your cabinetry will save you space. This option provides an elegant, seamless appearance that can be matched to your kitchen fixtures and cabinets in color, finish or style. It can also create an elegant look in your kitchen. This is ideal for homeowners who want an uncluttered, clean appearance.
However installing a built-in microwave could require a professional installation or remodeling of your kitchen. You might be able depending on the layout of your house, to cut an opening in the wall to accommodate the appliance. However it will require professional framing and support. In addition, microwaves with built-ins require sufficient ventilation to prevent overheating and damaging the appliance. According to Sam Cipiti, vice president of R. M. Tunis Kitchens and Baths in Chevy Chase, Maryland, the minimum cabinet depth for a built-in microwave is around 15 inches, however some manufacturers provide trim kits that can provide up to 1 1/2 inches of additional space for ventilation.
A third space-saving option is a drawer-style best inbuilt microwave which can be placed beneath your countertop or within an island. This configuration is simple to use and suitable for everyone and requires less countertop space. It also stops hot dishes or containers from falling off the edge or being knocked down.
Another important aspect to consider when choosing the space-saving microwave is the door design. A lot of brands have doors that opens in the same way as other kitchen appliances, including a slide-out or drop-down. This allows you to integrate your microwave seamlessly into your cooking process. Some models feature a sleek and smooth exterior that resists fingerprints for better, cleaner appearance.
Convenience
A built-in microwave over oven offers an attractive design that is easy to clean and convenient. Unlike countertop models, they're usually at the eye level for easy access and are often equipped with turntables that eliminate the need to constantly shift food from plate to plate. Additionally, built-in microwaves usually have options that enhance functionality like EasyConvection oven conversion technology and broil elements that allow you to brown or crisp food items.
In addition to saving counter space, a built-in microwave over the oven can boost your home's value and appearance by offering a luxurious design that other appliances may not be capable of matching. If it's installed above the stove or in a separate cabinet these microwaves seamlessly blend into your kitchen for an elegant appearance that shows you've put in the time to improve your kitchen and your home.
Built-in microwaves that are over ovens are available in various sizes as well as power levels and features that can be adapted to fit any kitchen. They can be placed under your counter in a drawer-style for a more integrated appearance that blends seamlessly into existing cabinetry and requires no additional space. These microwaves, with their premium finishes and high-end functions, will enhance the aesthetics of your kitchen and enhance your cooking and entertaining experiences.
While the convenience of a built in microwave oven is evident however, you should be aware that these microwaves aren't as versatile as their freestanding counterparts. It may take more space to function, based on where it is installed. Similarly, they aren't as portable, and you won't be able easily swap out the model for a new one if you decide that you want something different.
If you place your microwave above your range, you'll require an additional kitchen space to accommodate the ventilation system that is required by this setup. You'll need either an ducting system that sends smoke outside or a recirculating system that pulls the air through the Microwave Oven Built-in before transferring it to the home. For smaller kitchens, Built in Microwave Over Oven consider an additional built-in microwave that can be incorporated inside a cabinet, wall or island.
Convenient Controls
Microwave ovens are equipped with numerous controls according to the model you select. Some features are turntables, presets such as defrosting or reheating, and buttons that can last for up to 30 minutes. Certain models come with child safety features to prevent accidental use of the appliance.
Many microwaves come pre-programmed with recipes and cooking times that make the process of making food faster and simpler. This feature is beneficial for those who aren't sure how long to cook certain meals or for those who aren't comfortable with the particular cooking techniques employed in various cuisines.
KitchenAid offers a range of built-in microwaves as well as over-the-range microwaves designed to match your other appliances in style and finish for seamless appearance. Choose from stainless steel or black finishes that will complement any kitchen. These premium microwaves are boldly designed to bring professional-inspired styles into your home, and they're made with high-quality materials for a longer lifespan.
In contrast to models for countertop use built-in microwaves are fitted inside a fixed area of the kitchen cabinets or walls to give your kitchen a sleek, customized appearance. The internal components are generally the same as those of conventional countertop models, with a few exceptions. These models are available in various sizes, including those designed to fit in a compact space, and their exteriors may include a door that opens either in a left-to right swing-out or drop-down fashion.
Certain microwaves in built microwave oven the range, Built in Microwave Over Oven such as the ones made by Whirlpool(r) are able to be used as vent hoods. They have an exhaust system that is built in microwave for wall unit-in to let out fumes outside and recirculate the air. Some microwaves come with charcoal filters that eliminate odors and moisture in your kitchen.
Countertop models are positioned on the kitchen counter. They don't require venting or a special installation. This makes them an ideal option for people who rent their homes or save money on costly changes to their kitchens. Certain models also come with trim kits to close the gap between your microwave and other freestanding countertop appliances like coffee pots, bread makers or toaster ovens.
Energy Efficiency
Microwaves consume less energy to cook food and water than other cooking methods. They also use less energy than stovetop ovens because they focus the microwave's energy on the liquid inside instead of heating the air or other elements around it. This means that they can heat food much faster than conventional ovens. They can be installed either within the upper or lower cabinets and come in retro or modern styles to fit any kitchen.
In this notice of proposed rulemaking ("SNOPR"), the Office of Energy Efficiency and Renewable Energy (DOE) proposes new or modified energy conservation standards for microwave ovens that will help consumers save money on their operating costs. The Energy Policy and Conservation Act ("EPCA") requires DOE to evaluate on a regular basis whether the more stringent standards are economically feasible and technologically feasible, as well as result in significant energy savings.
This SNOPR contains the analyses and findings that DOE conducted to assess the effects on consumers of the new or revised energy conservation standards for microwave ovens. The analysis includes a market and technology assessment as well as a screening analysis, an engineering analysis and national impact analysis.
The energy usage analysis calculates the annual average microwave ovens operating hours for the sample of households. This analysis is used to calculate energy savings and other consumer analyses within this SNOPR. The analysis is based upon RECS field data collected from various regions. It also takes into account the different patterns of use of microwave ovens in different households, as well as regional variations in electricity prices.
In order to assess the impact of the new or modified standards on household expenses, DOE conducted LCC analyses and PBP analyses in order to estimate the cost over time of purchasing and using a microwave oven at different efficiency level. The LCC and PBP calculations are built in microwave for wall unit on the computer model that utilizes a Monte Carlo simulation to incorporate uncertainty and variation into the analyses.
In addition to the analysis of energy use and the LCC/PBP, this SNOPR contains an evaluation of the impact on the nation of the new or amended standards that are based on the NIA spreadsheet model. The NIA model calculates the industry net present value (INPV) in terms of energy savings from potential amended or a new standard in the form savings on energy consumption at the site and FFC savings.
Space Saver
Convenience
Energy Efficiency
- 이전글Five Killer Quora Answers To Under Desk Treadmill With Incline 25.05.19
- 다음글Guide To Midsleeper Cabin: The Intermediate Guide For Midsleeper Cabin 25.05.19
