CBD + THC Nighttime Gummies > 자유게시판
작성자 Gina
댓글 0건 조회 16회 작성일 25-05-18 16:48
$49.99
389 in stock
10mg CBD | 10mg THC | 2mg Melatonin
Servings: Approx. 40, Serving Size: 1 pcs. (5g), Amount per Serving: Calories: 15, Total Fat: 0g (0% DV), Saturated Fat: 0g (0% DV), Trans Fat: 0g (0% DV), Cholesterol: 0mg (0% DV), Sodium: 0mg (0% DV), Total Carbohydrate: 4g (1% DV), Dietary Fiber: 0g (0% DV),Total Sugars: 4g, Added Sugars: 4g (8% DV), Protein: 0g (0% DV), Vit. D: 0mcg (0% DV), Calcium: 0mg (0% DV), Iron: 0mg (0% DV),Potassium: 0mg (0% DV).
*Percent daily values based on 2000 calorie diet.
INGREDIENTS:
CORN SYRUP, SUGAR, WATER, PECTIN, CBD (HEMP-DERIVED), DELTA-9 THC (HEMP-DERIVED), MELATONIN, CITRIC ACID, NATURAL RASPBERRY FLAVOR, SODIUM CITRATE, ARTIFICIAL FOOD COLOR.
SUGGESTED USE: DO NOT EXCEED 1 GUMMY EVERY 8 HOURS. ALL USERS MAY NOT REACT THE SAME TO PRODUCT USE. THE ONSET OF EFFECTS MAY BE EXPERIENCED AT DIFFERENT TIMES. FIRST TIME USERS MAY EXPERIENCE STRONGER EFFECTS. DO NOT EXCEED SUGGESTED USE.
GUMMY FLAVORS:
Raspberry.
Caution:
KEEP OUT OF REACH OF CHILDREN. THIS IS A HEMP-DERIVED CBD PRODUCT. This product is intended for use by healthy adults age 21 years & older. THIS PRODUCT CONTAINS MELATONIN. Consult a healthcare professional prior to use of cbd+thc nighttime proprietary blend. may be harmful if you are pregnant, nursing or are taking any medication or have a medical condition. Discontinue use immediately if adverse reaction occurs and consult your physician. The FDA has not evaluated this product for safety or efficacy. There is no current standardized methodology for verifying cbd+thc nighttime proprietary blend content. As required by Florida state law, cbd+thc nighttime proprietary blend potency is verified by an independent third party lab. The results of the independent third party lab tests are available to you on our website and by scanning the QR code on the package. Test results may vary by individual laboratory and/or test method. This product contains less than 0.3% total delta-9 tetrahydrocannabinol (Delta-9 THC). Drug tests vary planet pet lawrenceburg in sensitivity, and you may test positive for Delta-9 THC when taking cbd+thc nighttime proprietary blend products. Over time color variations may occur in this product. The amount (mg) of cbd+thc nighttime proprietary blend may vary by dose and by packaging. If cbd+thc nighttime proprietary blenD is used beyond the expiration date, potency may decrease. May cause drowsiness. Do not drive or operate heavy machinery while taking cbd+thc nighttime proprietary blend. This product is not intended to diagnose, treat, cure, or prevent any disease. CONTAINS: CBD+THC NIGHTTIME PROPRIETARY BLEND (HEMP DERIVED CBD, D9-THC & MELATONIN)NO ARTIFICIAL SWEETENERS, VEGAN.
RELATED PRODUCTS
Calm CBD Gummies
CBD Plus – Calming Gummies – 4000mg
CBD+ Calm Mixed Berry Gummies
CBD+ Sleep Raspberry Gummies
Sleep Gummies
25 First Ave. SW STE A
Watertown, SD 57201
This product is not for use by or sale to persons under the age of 18. This product should be used only as directed on the label. It should not be used if you are pregnant or nursing. Consult with a physician before use if you have a serious medical condition or use prescription medications. A Doctor’s advice should be sought before using this and any other supplement. All trademarks and copyrights are property of their respective owners and are not affiliated with nor do they endorse this product. These statements have not been evaluated by the FDA. This product is not intended to diagnose, treat, cure or prevent any disease. By using this site, you agree to follow the Privacy Policy and all Terms & Conditions printed on this site. Void Where Prohibited by Law. Our products contain less than 0.3% THC.
JustCBD Florida Only Website
Welcome! You must be 21+ to enter this site.
Please enter your date of birth.
Autoship powered by qpilot.svg
