Delta 8 Gummies Blue Drops (BOGO SALE)
$24.99
– $45.00
Do not exceed 1 gummy every 8 hours. All users may not react the same to product use. The onset of effects may be experienced at different times. First time users may experience stronger effects
FLAVORS<\/strong>
Blue Raspberry.<\/p>
INGREDIENTS<\/strong>
Delta-8 THC Hemp-derivate, Corn Syrup, Sugar, Gelatin; Acids: Citric Acid, Lactic Acid; Gelling Agent: Pectins; Natural and Artificial Flavor, Color: Blue 1, Titanium Dioxide.<\/p>
SUPPLEMENT FACTS<\/strong>
Servings:<\/strong> Approx. 12, Serving Size: 1 pcs. (6.4g), Approx. 21mg Delta-8 per gummy. Amount per Serving: Calories: 20, Total Fat: 0g (0% DV), Saturated Fat: 0g (0% DV), Trans Fat: 0g (0% DV), Cholesterol: 0mg (0% DV), Sodium: 3mg (1% DV), Total Carbohydrate: 4.8g (1.8% DV), Dietary Fiber: 0g (0% DV), Total Sugars: 3.6g, Added Sugars: 3.6g (7.2% DV), Protein: <1g (0% DV), Vit. D: 0mcg (0% DV), Calcium: 0g (0% DV), Iron: 0mg (0% DV), Potassium: 0mg (0% DV).
*Percent daily values based on 2000 calorie diet.<\/p>
CAUTION<\/strong>
This is not CBD. Keep out of reach of children. This product is intended for use by healthy adults age 21 years and over. Consult a healthcare professional prior to use of delta-8 tetrahydrocannabinol (Delta-8 THC ). Delta-8 THC may be harmful if you are pregnant, nursing, taking any medication or have a medical condition. Discontinue use immediately if adverse reaction occurs and consult your physician. Food and drug administration has not evaluated this product for safety or efficacy. There is no current standardized Delta-8 THC methodology for verifying content. We make available our product testing reports on our website and by scanning the QR code on the packaging. Our Delta-8 THC serving size potencies are determined by a laboratory. Test Results may vary by laboratory or test method. This product contains less than 0.3% total delta-9 tetrahydrocannabinol (Delta-9 THC).
Drug tests vary in sensitivity and you may test positive for Delta-9 THC when taking Delta-8 THC products. Natural color variations may occur in these products. Amount of mg \/ Delta-8 THC may vary by piece and by package. May cause Drowsiness. When taken in, access THC may cause anxiety, paranoia. Do not operate a vehicle or heavy machinery while consuming Delta 8 THC.<\/p>
FLAVORS<\/strong>
Servings:<\/strong> Approx. 48, Serving Size: 1 pcs. (6.4g), Approx. 21mg Delta-8 per gummy. Amount per Serving: Calories: 20, Total Fat: 0g (0% DV), Saturated Fat: 0g (0% DV), Trans Fat: 0g (0% DV), Cholesterol: 0mg (0% DV), Sodium: 3mg (1% DV), Total Carbohydrate: 4.8g (1.8% DV), Dietary Fiber: 0g (0% DV), Total Sugars: 3.6g, Added Sugars: 3.6g (7.2% DV), Protein: <1g (0% DV), Vit. D: 0mcg (0% DV), Calcium: 0g (0% DV), Iron: 0mg (0% DV), Potassium: 0mg (0% DV).
CAUTION<\/strong>
<\/div>Read more<\/a><\/p>
","variation_id":7589922,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/A","has_lab_report":true}]">
Description
Delta-8 gummies blue drops provide an easy way to enjoy the benefits of delta-8, such as calmness. The blue drops are made from hemp-derived delta-8 THC, corn syrup, gelatin, citric and lactic acids, gelling agents, natural and artificial flavors, titanium dioxide, and food color. Pectin is cbd anti inflammatory used to make gluten-friendly blue drops. A blue drop package contains at least 48 gummies, and each gummy has approximately 21mg of delta-8 THC. A single serving of blue drops has 20g calories, zero fats, cholesterol, dietary fiber, and potassium, 3g sodium, 4.8g carbohydrates, 7.2g sugar, and 1g protein. You should take a gummy 8 hours after the last intake.
Delta-8 derives a milder effect that veteran THC users may find less effective. However, CBD users will find it less edgy; this allows the user to relax. The effect of delta-8 varies from user to user; the effect of the blue drops will kick in after 45 minutes and last at least 8 hours, depending on the user’s metabolism, sex, body weight, and tolerance to cannabinoids. The blue drops package is portable. You should avoid storing cannabinoid products in a bag as they can be subjected to high temperatures that denature cannabinoids.
Additional information
250mg, 1000mg
FAQ
Delta-8 THC and delta-9 THC are very similar; they bind to the ECS to trigger the high feeling. Delta-9 THC is abundant in cannabis plants like marijuana, whereas delta-8 THC is found in trace amounts. Delta-8 THC is produced by converting CBD into delta-8 THC in a lab. Another major difference between delta-8 and delta-9 is the double bond placement; in delta-8, the double bond is on the eighth carbon atom, while in delta-9, it is on the ninth carbon atom.
Delta-8 THC is available in gummies, vapes, shots, and edibles; how soon you will fill the effect depends on the method you will use to take delta-8 THC. The effect of gummies, shots, and edibles is delayed because they undergo metabolism for the delta-8 THC to be absorbed. However, the effect is long-lasting. The delta-8 effect for vapes and disposables is almost instant and powerful due to high bioavailability, but it is short-lived. All these products are effective for the consumer to choose a product to suit their needs.
High-quality products will ensure you get the benefits you want with delta-8 THC. Check for the product’s ingredients; this will ensure you do not buy products with ingredients you are allergic to. Buy delta-8 THC from reputable brands; they can ship hemp products across states where they are legal. Brands also have favorable shipping and return policies. You can find reputable brands by reading their user reviews on its website and other platforms like Reddit. Look for the product’s certificate of analysis, COA. The COA details its cannabinoid profile, tests on heavy metals like lead, organic and chemical pollutants, and product potency. For delta-8 THC, the COA is about the CBD it was derived from.
Delta-8 THC products like gummies and capsules are easy to dose; you only take one gummy or capsule every 8 hours. For delta-8 shots, you can space the doses 2 hours apart. For newer users, you can start with delta-8 shots, oils, or tinctures. Divide the doses into smaller units and gradually increase the doses and see how your body reacts with delta-8 before moving on to other products like vapes, gummies and capsules.
Delta-8 and CBD are cannabis compounds. Delta-8 is found in trace amounts, while CBD is abundant. CBD is extracted from the hemp plant using solvent or alcohol extraction. The extracted CBD is used to produce delta-8 for commercial use. Delta-8 and CBD are available as oils, tinctures, edibles, and capsules. They can both last in the body for at least four weeks. Delta-8 can make you fail a drug test because it does not differentiate isomers. Drug tests do not test for CBD. CBD does not have a high effect like delta-8.
RELATED PRODUCTS
Haze Brain Stew Delta 9 Gummies – Hybrid
Delta 8 Gummies Red Drops (BOGO SALE)
Delta 8 Sour Bears
Delta 8 Gummies Watermelon Supernova
Delta 8 Gummies Rainbow Drops (BOGO SALE)
Delta 8 Gummies Exotic Peaches 250mg
Delta 8 Sour Blockheads
25 First Ave. SW STE A
Watertown, SD 57201
Products on this site contain a value of 0.3% or less Δ9THC (or no more than 0.3% Δ9THC). FDA Disclosure: This product is not for use by or sale to persons under the age of 21 depending on the laws of your governing state or territory. This product should be used only as directed on the label. It should not be used if you are pregnant or nursing. Consult with a physician before use, especially if you have a medical condition or use prescription medications. A doctor's advice should be sought before using any of these products. All trademarks and copyrights are property of their respective owners and are not affiliated with nor do they endorse this product. These statements have not been evaluated by the FDA. These products are not intended to diagnose, treat, cure or prevent any disease. By using this site you agree to follow the Privacy Policy and all Terms & Conditions printed on this site. Void Where Prohibited By Law.
- 이전글A Security Camera Is Fundamental Have For Retailers 25.05.17
- 다음글Boost Your Viagra With The Following Pointers 25.05.17
