Haze Brain Stew Delta 9 Gummies – Hybrid > 자유게시판
작성자 Lazaro
댓글 0건 조회 6회 작성일 25-05-14 06:02
$29.99
Corn Syrup, Sugar, Water, Pectin, Citric Acid, Natural Flavor, THC Brain Stew Blend, Sodium Citrate, Artificial Colors.
SUPPLEMENT FACTS<\/strong>
Approx. 15mg Brain Stew Blend per gummy Serving size 1pc,(5.5) Calories per serving 15 Total Fat 0g 0% Saturated Fat 0g 0% Trans Fat 0g 0% Cholesterol 0mg 0% Sodium 0mg <0% Total Carbohydrate 4g 1% Dietary Fiber 0g 0% Total Sugars 3g Includes 3g Added Sugars 6% Protein 1g 0% Vitamin D 0mcg 0% Calcium 0mg 0% Iron 0mg 0% Potassium 0mg 0%. *Percent daily values based on 2000 calorie diet.<\/p>
APPROX 40 Gummies Per Jar.
<\/p>
SUGGESTED USE<\/strong>
Do not exceed 1 gummy every 8 hours. All users may not react the same to product use. The onset of effects may be experienced at different times. First time users may experience stronger effects. DO NOT EXCEED SUGGESTED USE.<\/p>
CAUTION<\/strong>
THIS IS NOT CBD. KEEP OUT OF REACH OF CHILDREN. THIS IS A HEMP-DERIVED PRODUCT.<\/strong>This product is intended for use by healthy adults age 21 years & older. Consult a healthcare professional prior to use of THC Brain Stew Blend: Hemp-Derived (Delta-9 THC) Delta-9 Tetrahydrocannabinol. THC Brain Stew Blend may be harmful if you are pregnant, nursing, taking any medication or have a medical condition. Discontinue use immediately if adverse reaction occurs and consult your physician. The FDA has not evaluated this product for safety or efficacy. As required by Florida state law, THC Brain Stew Blend potency is verified by an independent third party lab. The results of the independent third party lab tests are available to you on our website and by scanning the QR code on the package. There is no current standardized methodology for verifying THC Brain Stew Blend content therefore test results may vary by individual laboratory and\/or test method. This product contains less than 0.3% total Delta-9 Tetrahydrocannabinol (Delta-9 THC). Drug tests vary in sensitivity, and you may test positive for Delta-9 THC when taking THC Brain Stew Blend products. Over time color variations may occur in this product. The amount (mg) of THC Brain Stew Blend may vary by dose and by packaging. If THC Brain Stew Blend is used beyond the expiration date, potency may decrease. May cause drowsiness. Do not drive or operate heavy machinery while taking THC Brain Stew Blend. THC Brain Stew Blend has pure concentrated cannabinoids which is not intended to diagnose, treat, cure, or prevent any disease<\/p>
<\/div>Read more<\/a><\/p>
","variation_id":7662898,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/A","has_lab_report":true}]">
Additional information
Red Raspberry
600mg
RELATED PRODUCTS
HAZE – Pre-Roll – Blueberry Muffin – 3.5g
HAZE – Pre-Roll – Cereal Milk – 3.5g
HAZE – Pre-Roll – Maui Wowie – 3.5g
Meditation Blend Live Resin Disposable Vape Hawaiian Haze – 3 grams
Delta 8 Gummies Blue Drops (BOGO SALE)
Fantasy Blend Live Resin Disposable Vape Gelato – 3 grams
Surreal Blend Live Resin Disposable Vape Cotton Candy 3 grams
25 First Ave. SW STE A
Watertown, SD 57201
Products on this site contain a value of 0.3% or less Δ9THC (or no more than 0.3% Δ9THC). FDA Disclosure: This product is not for use by or sale to persons under the age of 21 depending on the laws of your governing state or territory. This product should be used only as directed on the label. It should not be used if you are pregnant or nursing. Consult with a physician before use, especially if you have a medical condition or use prescription medications. A doctor's advice should be sought before using any of these products. All trademarks and copyrights are property of their respective owners and are not affiliated with nor do they endorse this product. These statements have not been evaluated by the FDA. These products are not intended to diagnose, treat, cure or prevent any disease. By using this site you agree to follow the Privacy Policy and all Terms & Conditions printed on this site. Void where to find hemp seeds at walmart Prohibited By Law.
Autoship powered by qpilot.svg
