Guide To Ghost Immobiliser Car: The Intermediate Guide In Ghost Immobi…
BMW Ghost Immobiliser
The Ghost uses the CAN data bus for communication with your vehicle. This stops thieves adding a new key or even replacing the ECU to bypass your security system since it requires a correct PIN code to start the engine.
The auto ghost immobiliser is unlike other immobilisers as it doesn't rely on key fobs or LED indicators. It makes use of the buttons on your vehicle to allow you access to a unique disarming sequence that you can only remember.
Stop & Start
If you've ever driven a BMW or utilized its stop-start feature, you may have noticed the engine continues to run for about 30 seconds after you release the brake pedal. The BMW engine management system continues to watch the vehicle for signals emanating from the ignition key. When it detects this the vehicle will continue to run. The autowatch ghost immobiliser cost 2 Ghost is a device that stops this by stopping the vehicle when you hit the button.
Our BMW ghost immobiliser, a next-generation device, does not require you to cut OEM wires or add aftermarket alarms and key fobs. It is connected to your BMW's CAN data network and programmed with an encrypted, secure PIN code that is accessible via buttons that are installed in your car. This lets you enter the key push sequence that isn't found in the normal menus for media, like volume up/down, source, cruise control or turning on air conditioning that prevents your car from starting unless this is entered. The PIN can range between 4 and 20 numbers and is therefore difficult for thieves to guess or crack.
In addition to this we can also add a service/ valet mode to the system, this is activated when the car is in for servicing so that the Ghost is hidden from the garage. This can be achieved by pressing the service button on your infotainment system 5 times (the system will flash to confirm this) and when you return, the Ghost will automatically arm again.
High-end cars being more prone to being targeted than ever before, we strongly recommend the Ghost immobiliser ghost to be installed. It is completely undetectable, does not require cutting any original factory wires and is able to shut down your cars engine when an incorrect pin code is entered. It is a simple but efficient method to prevent your vehicle from being stolen, even with cloned keys. Check out social media sites to see how quickly new vehicles can be stolen by using tools for cloning that are available on the internet for less than PS80.
Service Mode / Valet Mode
The Ghost is a market leading immobiliser designed to prevent your vehicle from being taken by key cloning and hacking. It works by utilising the factory buttons on your vehicle to create an unique sequence of pushes that only you know, much as the pin code security of your mobile phone. It's discreet, incredibly effective and deterrence for even the most obstinate thieves!
If you're parked at your home or in a meet and greet when you are at a meet and greet, the Ghost can be set to service mode. This lets you start the car using your keys, but it stops the engine from starting again until the correct code is entered. This is a great option for those who need to turn their cars to valet services or other trusted friends and family members. It also allows you to bring the vehicle into the garage for repairs, maintenance etc without having to worry about it being tampered with or stolen by a mechanic while you wait.
When the service or valet mode is activated it will block your BMW from being driven after it has been started. This prevents anyone from test driving it whilst you are away. After you return, it will revert back to normal, preventing your vehicle from being tampered with or stolen again.
We can mount the Ghost to any BMW, all you need is the correct keys as it doesn't require the original remotes, and can be used with them. We are TASSA-registered, DBS-security-checked and fully certified in system installation. You can be confident that the installation will be completed correctly and your Ghost device will function according to the specifications. Your vehicle will also be registered on a database, and you will receive documentation that you can show to your insurance company, they will love these devices and often see substantial discounts!
We can also provide an optional Bluetooth tag which can be used to disable the Ghost by using an app on your smartphone (IOS & Android) or in case you don't have a smartphone or aren't familiar with it, just press the emergency card one time. This is an extra cost of ghost immobiliser and requires a separate Bluetooth pairing.
Anti-Hijack
With high-tech thieves becoming more and more sophisticated, the security technology has to evolve, this is why Ghost has created this discrete and non-obtrusive immobiliser. It is designed to stop thieves from adding a key or replacing the ECU to start your vehicle and drive it off. Ghost connects to your CAN network, and uses buttons on your vehicle to create a unique push-sequence that must be entered before the engine can begin.
When the anti-hijacking feature is activated the attempt to restart the engine will be thwarted. If the system detects that the vehicle is no longer moving, it will honk the horn and flash the indicators, if it is not able to locate the correct code, it will also stop the engine (where it is). The Anti-Hijack feature can be removed by entering your push sequence, or by entering service mode that allows your car to temporarily begin and drive, without having to enter your PIN.
If you own an GPS device connected to your BMW it can be used to turn off the Anti-Hijack feature, allowing you to still use the navigation system in your car whilst the vehicle is parked unattended. You can also use your smartphone to control the anti-theft feature as well as other functions.
This is a Tassa approved product that is recognized by a majority of insurance companies. It can help to reduce the chance of your prized possessions being stolen. It is completely invisible and will not interfere with the operation of your vehicle. It does not require any programming expertise to install or use. It is totally undetectable by tools for detecting that thieves employ, and it is invulnerable to key cloning because it connects directly to your vehicles CAN data network.
Remote Control
We can connect the Ghost device with your mobile app to enable remote control of keyless start and go functions. This is helpful when you need to be somewhere else and valet or mechanic need to start your vehicle. The system lets you start the vehicle, select drive and quit the service mode without using your key fobs. You can also see your vehicle's location in real-time on a map on your smartphone, which is ideal for tracking your car when moving around.
The Ghost can be positioned on the dashboard or in the centre console. It is completely concealed, tamperproof, and doesn't require any additional wiring. The device is connected to the vehicle's CAN Data Network (similar to an Ethernet cable) and a unique PIN code is embedded into it. This pin code needs to be selected before the vehicle is started. This prevents thieves from using a cloned key or replacing the ECU in order to bypass this system.
If the vehicle is being taken away, the Ghost will enter service mode and disable all functions unless you have a PIN code or can use the mobile application to disable it. This is a feature that was designed to protect your vehicle from high tech thieves who are using relay boxes to steal your car. This will stop thieves from using their mobile phones to turn on your sat-nav system or mp3 player to track your vehicle!
Ghost can also stop the 'Relay Style Frequency Amplifier'. This is the most popular method of stealing a vehicle with a keyfob that's been cloned, or stolen through hacking. Ghost lets you stop this theft by installing a device called Secure-A Key inside your vehicle. The device is installed inside the key-fob in your vehicle and disconnects the battery after a few minutes of inactivity. This can be done on the majority of modern PKE key-fobs.
We are TASSA accredited (Tracking and Aftermarket Security Systems Association), a recognised body that a few insurance companies acknowledge and provide discounts for fitting the device. We are also DBS security-checked and fully system-trained to install the ghost immobiliser car stolen with ghost immobiliser (this site), ensuring that all work is carried out to the highest standards. Once installed you will receive documentation that you can present to your insurance company as proof of installation and allowing you to receive the best deal possible on your car cover.
Stop & Start
Anti-Hijack
Remote Control
- 이전글See What Double Glazed Windows Luton Tricks The Celebs Are Using 25.05.05
- 다음글How Treadmill With Incline Can Be Your Next Big Obsession 25.05.05
