A Comprehensive Guide To Item Upgrade. Ultimate Guide To Item Upgrade > 자유게시판
작성자 Elaine
댓글 0건 조회 37회 작성일 25-04-03 11:55
WoW Upgrades - The item upgrade Upgrader
Upgrades give you boosts in certain statistics. Each upgrade boosts the level of an Item Level Upgrade by 3. Each upgrade also increases the random substatus.
The more modernized gear generally has a greater value for trade as long as it meets low requirements (like the FB shield of the sorc) or has a high stat variation (like eth titan weapons). These types of gear get less value from upgrading due to the requirement to roll to get a perfect version.
Recycle Points
The upgrader for items allows players to upgrade their gear to a higher level by supplying the appropriate currency to the NPC. Upgrades can be made on any kind of armor or weapons. However, the item that is used for the upgrade item will remain in use for a long time and cannot be used again. Upgrades can also be used to create enhancements.
You can upgrade your gear at any time by visiting the upgrader in any major city. It is recommended to visit the upgrader at least once every couple of weeks to keep your equipment up to date.
The cost of upgrading will vary based on the current level of the equipment being upgraded, but will always be cheaper than buying new gear from other sources. Upgrades such as upgrading a Benthic chest up to 385 ilvl will cost you 20 recycle points. Buying a similar item will cost you 105.
Valorstones
Upgrades are items that can be used to upgrade weapon, armor, tool, and accessory upgrades. They can be bought by players through NPCs that sell upgrades to items in exchange for different currencies, and can be found in random treasure lists. Once an upgrade has been purchased, it can be applied to any weapon or tool using the help of The button will display a preview of an item's next upgrade level, in the event that there are enough materials.
The cost of upgrading is based on the slot of the item and the current item level, with weapons costing more than gloves or bracers, for instance. Each step costs 15 Flightstones and a variety of crests, with certain upgrades offering discounts to reduce the cost of the Flightstones or the crests used. Once an item is upgraded to a certain amount it is able to be downgraded and sold to the upgrader at a lower price.
Upgraders for items are available in many places including the main island, as well as a few outposts. The NPCs provide an upgrade discount and the chance to obtain a new upgrade recipe. The discount on upgrades increases as more items are upgraded. It can also be increased by having players finish certain achievements or quests.
Icewind Dale does not have an item upgrader at beginning, unlike Cromwell from Baldur's Gate II. The NPCs that can assist with upgrades are only accessible through a variety means. This is both a benefit and a disadvantage.
In Season 3, a number of new features have been added to the upgrade system. Once a player obtains an upgrade to a specific item level for a particular armor slot, upgrading additional items to that same item level will be less expensive, even in the event that they belong to another set of gear.
The discount is available to all accounts. The amount of Harbinger Crests needed for upgrades is reduced too, but it is only available after certain milestones are reached.
Crests
Players have a variety of options when it comes to upgrading their gear in WoW. Flightstones are a currency that is available to everyone for upgrading. Crests are more special, and are used during specific item level upgrades. Crests are an integral part of the Dragonflight Gear Progression System introduced in version 10.1. They come in four ranks.
The first thing to remember is that crests are only available for gear that is of a particular rank. Each rank comes with an upgrade path that is different. The most basic and straightforward upgrade path costs 15 crests, while the more complex one can require as much as 20 crests, based on the type of equipment that is being upgraded.
Players can earn crests through working through content that is of the appropriate level, which means walking around and doing outdoor activities to get lower-tier gear, raids or dungeons of any difficulty for higher-tier items, or Mythic+ heroic raid bosses and dungeons to obtain endgame gear. These crests can then be exchanged at an item upgrade upgrader NPC like Cuzolth in Dornogal or Vaskarn in Valdrakken, for the appropriate upgrade routes and steps.
The new currency system isn't too difficult to use, however it will bring some modifications to the upgrade process. When a piece has reached the highest level of upgrade for any rank (Explorer or Adventurer) it will no longer require Flightstones. This change is designed to allow players to get their gear up to the highest level possible on all their characters instead of relying only on seasonal loot.
It's also important to use crests with care, since they have only one purpose. For instance, it's a good idea use all of your Whelpling-rank crests on the top equipment you have and then keep Drake and Wyrm crests to use for the next set of upgrades you plan to create. This is especially true for items like rings and trinkets that take up multiple slots on the character, that will be able to take advantage of the account-wide discount if all of the slots are filled with top-quality equipment.
